T5000- Separate management bus for using 4 different 25Gbps port
I am planning to use 4 separate SFP port each supporting speed up to 25Gbps. Could you let me know if there are separate individual management bus for using 4 different 25Gbps port? Are there any constraint in implementing these in my carrier board with the T5000 SoM ?
Refer to the table below from Jetson Thor Series Modules Interface Design Guide for the mapping of four MGBE channels and section 7.3 MGBE.
