hi, what’s the camera mipi csi data flow? where we can find it
does the camera mipi need to go into GPU or CPU?
thanks and br
thanks and br
Check below document for the detail.
Hello afd0001,
Here are two additional references that may help:
Regarding your second question, the MIPI CSI data does not go directly to the CPU or GPU. It first enters the dedicated NVCSI hardware, then passes through the VI (and optionally the ISP) before being stored in system memory. From there, the CPU, GPU, or other accelerators can access the image data for processing.
I hope this helps.
Jose Morera
Embedded Software Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
get it!
thanks and br
