T5000 with jetpack7.2 flash fail
硬件:T5000 + 自研载板
软件:Jetpack7.2(R39.2.0)
修改1:arch/arm64/configs/defconfig 增加raid/wifi/bluetooth相关选项
修改2:使能25G,ODMDATA=“uphy1-config-8,mgbe0-speed-3,mgbe1-speed-3,mgbe2-speed-3,mgbe3-speed-3”;(基于官网文档:Enable 25 Gigabit Ethernet on QSFP Port — NVIDIA Jetson Linux Developer Guide
刷机命令:sudo ./l4t_initrd_flash.sh jetson-agx-thor-devkit internal
问题现象:刷机失败,提示似乎是ADB超时。附上完整刷机信息
20260630_171256_r3920_flash_fail.txt (428.3 KB)
补充一下,同一块板子,用基于R38.4.0的环境刷机可以顺利完成。
如下两个配置都尝试过,结果一样
cvb_eeprom_read_size = <0x0>
SKIP_EEPROM_CHECK=1
在R38.4环境下看到的nvme容量如下,超过234G的最低要求了。
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 16M 1 loop
nvme0n1 259:0 0 238.5G 0 disk
├─nvme0n1p1 259:1 0 235.8G 0 part /
├─nvme0n1p2 259:2 0 100M 0 part
├─nvme0n1p3 259:3 0 768K 0 part
├─nvme0n1p4 259:4 0 512M 0 part /boot/efi
├─nvme0n1p5 259:5 0 384.8M 0 part
├─nvme0n1p6 259:6 0 100M 0 part
├─nvme0n1p7 259:7 0 768K 0 part
├─nvme0n1p8 259:8 0 512M 0 part
├─nvme0n1p9 259:9 0 384.8M 0 part
├─nvme0n1p10 259:10 0 400M 0 part
└─nvme0n1p11 259:11 0 335M 0 part
vivibit@M114:~$
附上串口信息,似乎板子这边crash了,这是什么问题?
20260630_171256_r3920_serial_fail.txt (49.7 KB)
制作image的命令换成了:sudo SKIP_EEPROM_CHECK=1 BOARDID=3834 BOARDSKU=0008 ./l4t_initrd_flash.sh --no-flash jetson-agx-thor-devkit internal
刷机命令:sudo SKIP_EEPROM_CHECK=1 BOARDID=3834 BOARDSKU=0008 ./l4t_initrd_flash.sh --flash-only jetson-agx-thor-devkit internal
同样串口这边会crash,串口log如附件,PC侧错误信息和之前一致。
20260630_1904_r3920_serial_fail.txt (42.7 KB)
Could you try to disable your MGBE node in device tree and see if it could boot up first?
还没有尝试禁用mgbe节点的方法。先纠正了两处有关pcie C3的设备树配置,目前刷机的主体部分貌似成功了,串口顺利显示进到了bash-5.2#:
但是板子第一次重启失败了,串口上比较明显的异常信息如下,请帮忙分析一下是什么情况?禁用mgbe的方法还需要尝试吗?后面会附上完整的串口log
20260701_1015_r3920_serial_first_boot_fail.txt (179.3 KB)
Please list out what interface that you need on your custom board.
主要使用的接口如下:
MGBE: 25G x4
PCIe: C1 for boot nvme, C2 for 10GE, C3 for nvme, C5 for nvme
USB: usb2-0 for flash & otg, usb2-1+usb3-0 for 10GE, usb2-2+usb3-1 for usb port, usb2-3+usb3-2 for usb port
HDMI
Serial: ttyTCU0 for console, ttyAMA10 for connect to other
尝试禁用4个MGBE,修改 source/hardware/nvidia/t264/nv-public/nv-platform/tegra264-p4071-0000.dtsi ,给mgbe0/1/2/3添加了status = “disabled”;
重新刷机,结果和刚才一样,刷机看似成功了,但是重启时出现同样的错误提示然后挂住
How did you enable the PCIE C3 here?
I don’t see any UPHY0 setting in ODMDATA.
为了使能pcie C3,修改了3个地方:
1 source/hardware/nvidia/t264/nv-public/nv-platform/tegra264-p4071-0000.dtsi
2 bootloader/generic/tegra264-bpmp-3834-0008-4071-xxxx.dts
这是继承了之前在Jetpack7.0和7.1版本中的方法
Did you remember to follow above doc to set UPHY_CONFIG to null?
修改了 UPHY_CONFIG=”“ 之后,板子能启动起来了。非常感谢您的及时提示!
板子起来之后还有个问题,串口上大约每2秒打印3行信息,这是哪里出错了吗?
[ 1370.281496] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1370.281528] tegra-mc 8108020000.memory-controller: gpcdmar: non-secure read @0x0000fffffffff000: EMEM address decode error (EMEM decode)
[ 1370.293318] tegra-mc 8108020000.memory-controller: gpcdmaw: non-secure write @0x0000fffffffff000: EMEM address decode error (EMEM decod)
