T5000 with SFP+
Hi NVIDIA Forum,
we’re having a custom board design with the T5000 - XFI-C0 routed to a SFP28 Port. We successfully verified the 25GBit/s connection following this: Jetson Thor Adaptation and Bring-Up — NVIDIA Jetson Linux Developer Guide
We’ve used a QSFP-100G to a 4SFP28 DAC Cable - this worked.
Then we reverted to 10GBit/s:
        uphy {
                status = "okay";
                //uphy0-config = <0x07>; //original
                uphy1-config = <0x07>; //original
                //25Gbit/s
                uphy0-config = <0x06>;
                //uphy1-config = <0x08>;
                mgbe0-speed = <0x02>;
                mgbe1-speed = <0x02>;
                mgbe2-speed = <0x02>;
                mgbe3-speed = <0x02>;
                mgbe0-speed = <0x03>;
                mgbe1-speed = <0x03>;
                mgbe2-speed = <0x03>;
                mgbe3-speed = <0x03>;
Using the same board, but flashed to 10Gbit/s we got issues, during using a 10Gbit/s SFP+ DAC Cable. Now the Link mgbe0_0 is displayed all the time as “down”.
I mean it’s quite easy connected - and the QSFP or the SFP+ should not have physically any difference. This is the schematic:
And here the output of mgbe0_0, we’re not getting the Link detected to “yes”.
root@t5000:/boot/overlays# ethtool mgbe0_0
Settings for mgbe0_0:
	Supported ports: [ TP	 MII ]
	Supported link modes:   Not reported
	Supported pause frame use: Symmetric Receive-only
	Supports auto-negotiation: Yes
	Supported FEC modes: Not reported
	Advertised link modes:  Not reported
	Advertised pause frame use: No
	Advertised auto-negotiation: Yes
	Advertised FEC modes: Not reported
	Speed: 10000Mb/s
	Duplex: Full
	Auto-negotiation: on
	Port: MII
	PHYAD: 0
	Transceiver: external
	Supports Wake-on: d
	Wake-on: d
        Current message level: 0x00000000 (0)
	Link detected: no
Also plese find the running .dtb for the mgbe0_0:
 ethernet@a808a10000 {
                        mac-address = [4c bb 47 dc c5 3c];
                        compatible = "nvidia,tegra264-mgbe";
                        status = "okay";
                        reg = <0xa8 0x8a10000 0x00 0x10000 0xa8 0x8aa0000 0x00 0x10000 0xa8 0x8ad0000 0x00 0x10000 0xa8 0x8a00000 0x00 0x10000>;
                        reg-names = "mac\0xpcs\0macsec-base\0hypervisor";
                        interrupts = <0x00 0x366 0x04 0x00 0x369 0x04 0x00 0x36a 0x04 0x00 0x36b 0x04 0x00 0x36c 0x04 0x00 0x36d 0x04 0x00 0x368 0x04 0x00 0x367 0x04>;
                        interrupt-names = "common\0vm0\0vm1\0vm2\0vm3\0vm4\0macsec-ns-irq\0macsec-s-irq";
                        resets = <0x02 0x3f 0x02 0x3e 0x02 0x40>;
                        reset-names = "mac\0pcs\0macsec_ns_rst";
                        clocks = <0x02 0xd8 0x02 0x164 0x02 0xda 0x02 0xd9 0x02 0xd7 0x02 0xd5 0x02 0x168 0x02 0x166 0x02 0x165 0x02 0x169 0x02 0x167 0x02 0x130 0x02 0x12c 0x02 0x1cb 0x02 0x1cf>;
                        clock-names = "mac\0tx\0mgbe\0macsec\0tx-pcs\0ptp-ref\0rx-input\0rx-pcs-input\0tx-m\0rx-input-m\0rx-pcs-m\0utmi_pll1_clk\0pll_bpmpcam\0tx_ser\0rx_ser";
                        power-domains = <0x02 0x0d>;
                        nvidia,num-dma-chans = <0x04>;
                        nvidia,dma-chans = <0x00 0x01 0x02 0x03>;
                        iommus = <0x139 0x1300>;
                        nvidia,num-mtl-queues = <0x0a>;
                        nvidia,mtl-queues = <0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 0x08 0x09>;
                        nvidia,tc-mapping = <0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 0x00 0x01>;
                        nvidia,residual-queue = <0x01>;
                        nvidia,rxq_enable_ctrl = <0x02 0x02 0x02 0x02 0x02 0x02 0x02 0x02 0x02 0x02>;
                        nvidia,vm-irq-config = <0x151>;
                        nvidia,vm-vdma-config = <0x152>;
                        nvidia,tx-queue-prio = <0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 0x00 0x00>;
                        nvidia,rx-queue-prio = <0x01 0x02 0x04 0x08 0x10 0x20 0x40 0x80 0x00 0x00>;
                        nvidia,dcs-enable = <0x01>;
                        nvidia,macsec-enable = <0x01>;
                        nvidia,mgbe-riit-config = <0x153>;
                        nvidia,rx_riwt = <0x200>;
                        nvidia,rx_frames = <0x40>;
                        nvidia,tx_usecs = <0x100>;
                        nvidia,tx_frames = <0x10>;
                        //10G XFI
                        nvidia,phy-iface-mode = <0x00>;
                        nvidia,promisc_mode = <0x01>;
                        nvidia,slot_num_check = <0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00>;
                        nvidia,slot_intvl_vals = <0x00 0x7d 0x7d 0x7d 0x7d 0x7d 0x7d 0x7d 0x7d>;
                        nvidia,ptp_ref_clock_speed = <0x12a05f20>;
                        nvidia,instance_id = <0x00>;
                        nvidia,ptp-rx-queue = <0x03>;
                        nvidia,dma_rx_ring_sz = <0x1000>;
                        nvidia,dma_tx_ring_sz = <0x1000>;
                        dma-coherent;
                        nvidia,mac-addr-idx = <0x01>;
                        //10G Mode 0x01
                        nvidia,uphy-gbe-mode = <0x01>;
                        nvidia,max-platform-mtu = <0x2328>;
                        nvidia,pps_op_ctrl = <0x08>;
                        nvidia,if-name = "mgbe0_0";
                        nvidia,force-restart-lane-bringup = <0x01>;
                        phandle = <0x15f>;
                        fixed-link {
                                full-duplex;
                                speed = <0x2710>;
We also verified on the Thor DevKit that the same cable like mentioned above (QSFP28 to SFP28) works with just one SFP28 connected to another switch.
What is interesting, when we disconnect the SFP, inserted in the custom board then we got following messages in the dmesg:
[ 2144.875109] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2145.387147] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2145.483121] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2145.931120] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2146.443172] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2146.541141] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2146.987005] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2147.498841] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2147.595003] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 2148.043029] nvethernet a808a10000.ethernet: [xpcs_lane_bring_up][827][type:0x4][loga-0x0] PCS block lock SUCCESS
So how to enable 10Gbit/s XFI for the mgbe0_0 for the T5000?
Did you revert the other settings delineated at JetsonModuleAdaptationAndBringUp for all 4 mgbe
+     nvidia,uphy-gbe-mode = <1>;
+     nvidia,phy-iface-mode = <0x0>;
+         speed = <10000>;
# And edited tegra264-p4071-0000+p3834-0008-nv.dtb
+       uphy1-config = <7>;      // Configure UPHY1-Lane0-3 for C5 to enable mgbe
+       mgbe0-speed = <2>;       /* 0 for 2.5G, 1 for 5G, 2 for 10G, 3 for 25G */
+       mgbe1-speed = <2>;
+       mgbe2-speed = <2>;
+       mgbe3-speed = <2>;
Yes, it was changed for all 4 mgbe. We also verified everything in the running .dtb
Just want to clarify. So what was the first day before you enabled 25GBE on your board?
Did that work or not?
We only have users asking how to enable 25GB here but won’t have anyone asking 10GB question because that thing was the default setting on NV devkit and shall no need to get asked.
Hi Wayne,
we successfully tested the 10GBE on the DevKit with QSFP28 to 4x SFP28 → Worked (with unmodified DevKit JP).
we successfully tested the 25GBE on our custom carrierboard to the DevKit using on the DevKit QSFP28 to 4x SFP28 → worked (with modified DevKit JP).
Now we want to test on our custom carrier-board 10GBE with a SFP+ (XFI - 10GBe) with the same config like for the DevKit - the only change right now is that we’re not having a QSFP28 anymore in the system - here we got problems. Our expectation would also be: Placing the DevKit Image on our custom carrier, there the 10GBe should work - but we don’t have any link-detection. We’re using mgbe0_0 only, the other 3x mgbe are not connected on the custom carrier.
Just to clarify. So the same image + SOM would work just when it is put on NV devkit but failed right after moving the same SOM from devkit to your board? without changing anything in software?
Hi we tested it again, we flashed now the original DevKit images to the DevKit - using the QSFP28 to 4x SFP28 - this worked.
We took the NVMe (not the SOM) and put it into our own carrier board, which doesn’t worked. (No SFP+ Link).
Now we reflashed the NVMe and the SOM in the own carrier board with the DevKit Images (Just changed the EEPROM Configuration to 0x0). Now the Link is working. We take as a learning to flash SOM & SSD at the same time and replacing just the SSD is not working for 10GBE Interface.
Thanks for the support!
