When I was in the system of jetson nano, the following log suddenly appeared:
What I want to know is what caused this? Or is there any deb that I did not install correctly?
Note: My root file system is cropped
[ 221.986602] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 669.986367] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 871.987393] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 911.986452] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 1063.987190] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 1107.987349] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
And what is the PWM value before hitting this issue? Did you trigger any loading on the board to make the FAN spin faster to hit this error? or even put it in idle would trigger the error?
I checked it when it was unloaded and I found that its value does not seem to be in a stable range. Sometimes the value is large, sometimes it is small. I use the automatic control service of the fan. log.txt (7.9 KB)
Thanks ~0604
