TADP-2.0r9 install failed on MacOS while installing Eclipse4.3, CDT 8.2.0 and ADT 22.6.2
pop the message:
Failed to load the JNI shared library “/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/bin/…/jre/lib/server/libjvm.dylib”.
Hi bluekylin,
When installing TADP, it will open eclipse. it seems that your eclipse cannot open normally. So I think you must have been installed jdk1.7.0_45.jdk before you install the TADP. So this error is maybe caused by the JDK environment path is not right. You can try to use terminal to go into eclipse folder path and then
mkdir jre
cd jre
ln -s JDKPath/bin bin
After then, reinstall TADP.
Any more question please let me know.
Amy.
