Freshly installed TADP on brand new computer. 3 errors while trying to run Hello World:
all help is appreciated
Description Resource Path Location Type
error: Error retrieving parent for item: No resource found that matches the given name ‘android:Widget.Material.ActionButton’. styles_base.xml /appcompat_v7/res/values-v21 line 75 Android AAPT Problem
The container ‘Android Dependencies’ references non existing library ‘C:\Users\Justin\workspace\appcompat_v7\bin\appcompat_v7.jar’ myFirstApp Build path Build Path Problem
The project cannot be built until build path errors are resolved myFirstApp Unknown Java Problem
