TADP 3.0r4 installation failed on Nexus 9 (Linux x64)
I try to install TADP 3.0r4 but unsccessully on Nexus 9 but unsuccessfully.
My Nexus 9 is rooted with superSU by chainfire. But it doesn’t have root permission for remote shell.
The error happend when the installer pushes files into /data/ partition
“failed to copy ‘./NVPACK/cuda_android/bin/nvprof’ to ‘/data/cuda-toolkit-6.0/bin/nvporf’ Permission denied.”
I push CUDA Runtime to some places in Nexus 9 and copy into /data/cuda-toolkit-6.0 but I don’t know it is a right solution or not.
After that the installer stucked at installing samples because it must push files into /data.
Sorry about the inconvenience that has taken to you. Actually Nexus 9 doesn’t support CUDA. So we do not suggest you to push the cuda runtime to Nexus 9.
The installer stucked at installing samples because it must push files into /data.
Thanks for your information. I will look into this immediately. As a workaround , you can choose “No” in the compile samples page to avoid deploy samples to your devices.
Hi Amyl,
It is sad to hear that.
I intended to use Nexus 9 to experiment some gpu functions. Now I should throw it into trash :(
Do you have plan to support in future?
I want to confirm some info.
Is it possible to use CUDA or OpenCL functions of OpenCV in NVIDIA Shield Tablet 8?
If yes, I will consider to buy a NVIDIA Shield Tablet 8
