I just installed TADP 4.0r1 and there is a mismatch between the installed Eclipse, which is for java 32-bit, and the JDK, which is java 1.7.0_71 64-Bit.
Of course that means Eclipse doesn’t start. Instead I get a panel with the “Java was started but returned exit code=13” message.
Can I install Eclipse over the one installed? or should I install it elsewere?
Additionally, could I install Eclipse Luna (with a separate JDK 8)?
There’s is another problem, the installed Eclipse is customized, that’s why I was asking about installing over the wrong version, so the customization can be preserved.
I’ve already done the separate installation, no problem with that. But being an Android newbie I don’t know if its enough to follow the documentation’s “Development Tools” section (since the docs talk about the already customized version).
