This is my third attempt to fix this problem, and I was just redirected back here. Really feel like I’m alone on this one :( Here’s the last thread:
System: MSI Apache Pro G70 with a GeForce GTX 860M (01:00.0) and a Intel 4th-gen integrated graphics controller (00:02.0). Nvidia driver is 346.16. OS is a late beta Fedora 21, kernel 3.17.4-301.fc21.x86_64 stock.
Problem, short summary: new laptop, purchased to do graphics work, trying to get the nvidia driver working for X with optimus, it starts up without a backlight, and when I use xrandr to connect it, X crashes or otherwise refuses to work.
The current status: I’m using the following xorg config:
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “nvidia”
Inactive “intel”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Device”
Identifier “nvidia”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BusID “PCI:1:0:0”
EndSection
Section “Device”
Identifier “intel”
Driver “modesetting”
BusID “PCI:0:2:0”
EndSection
Section “Screen”
Identifier “nvidia”
Device “nvidia”
Option “UseDisplayDevice” “none”
Option “AddARGBGLXVisuals” “True”
EndSection
Section “Screen”
Identifier “intel”
Device “intel”
Monitor “Monitor0”
EndSection
So, your standard modesetting config. Which of course requires the following xrandr lines at startup:
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
I’ve taken to issuing them of the form “DISPLAY=:0 xrandr…” so that I can control the timing and see the output.
I’ve gotten things to the point that X starts up without crashing (but, of course, without the backlight). And now I can even issue the first statement - no error returned. X somewhat randomly either continues, continues for a while then crashes, or crashes immediately. The second line fails with:
DISPLAY=:0 xrandr --auto
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 139 (RANDR)
Minor opcode of failed request: 7 (RRSetScreenSize)
Serial number of failed request: 29
Current serial number in output stream: 30
xrandr with no arguments yields:
Screen 0: minimum 8 x 8, current 640 x 480, maximum 16384 x 16384
eDP-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.01 +
1400x1050 59.98
1280x1024 60.02
1280x960 60.00
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
800x600 60.00 60.32 56.25
700x525 59.98
640x512 60.02
640x480 60.00 59.94
512x384 60.00
400x300 60.32 56.34
320x240 60.05
VGA-1-0 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
The problem seems to be NVidia trying to shared a non-shared pixmap. The relevant parts of the Xorg.0.log:
[ 82.586] (II) modesetting(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 82.586] (==) modesetting(G0): DPMS enabled
[ 82.586] (WW) modesetting(G0): Option “UseDisplayDevice” is not used
[ 82.872] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 82.872] (II) NVIDIA: access.
[ 82.881] (II) NVIDIA(0): Setting mode “NULL”
[ 82.902] (II) NVIDIA(0): Built-in logo is bigger than the screen.
[ 82.906] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 82.906] (==) NVIDIA(0): Backing store enabled
[ 82.906] (==) NVIDIA(0): Silken mouse enabled
[ 82.906] (==) NVIDIA(0): DPMS enabled
And then, when I get a crash…
[ 114.855] reporting 3 3 20 149
[ 114.857] reporting 3 3 20 149
[ 116.086] reporting 3 3 20 149
[ 118.157] reporting 3 3 20 149
[ 118.158] have a master to look out for
[ 118.158] (EE) NVIDIA(0): The X server tried to share a non-shareable pixmap
[ 118.158] need to create shared pixmap 0(EE)
[ 133.239] (EE) Backtrace:
[ 133.239] (EE) 0: /usr/libexec/Xorg.bin (OsLookupColor+0x119) [0x59bfd9]
[ 133.240] (EE) 1: /lib64/libc.so.6 (__restore_rt+0x0) [0x7f052dbac94f]
[ 133.240] (EE) 2: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x3dcd0) [0x7f05273e8650]
[ 133.240] (EE) 3: /usr/lib64/xorg/modules/libwfb.so (wfbBlt+0x13d) [0x7f0526ca066d]
[ 133.240] (EE) 4: /usr/lib64/xorg/modules/libwfb.so (wfbCopyNtoN+0x30b) [0x7f0526ca48bb]
[ 133.240] (EE) 5: /usr/libexec/Xorg.bin (miCopyRegion+0x1a7) [0x5773e7]
[ 133.240] (EE) 6: /usr/libexec/Xorg.bin (miDoCopy+0x45e) [0x57798e]
[ 133.240] (EE) 7: /usr/lib64/xorg/modules/libwfb.so (wfbCopyArea+0x2d) [0x7f0526ca5a5d]
[ 133.240] (EE) 8: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x514259) [0x7f0527d950a9]
[ 133.240] (EE) 9: /usr/libexec/Xorg.bin (DamageRegionAppend+0x33ed) [0x52495d]
[ 133.275] (EE) 10: /usr/libexec/Xorg.bin (CompositeRegisterImplicitRedirectionException+0x26d5) [0x4cdd25]
[ 133.275] (EE) 11: /usr/libexec/Xorg.bin (CompositeRegisterImplicitRedirectionException+0x34f5) [0x4cfb15]
[ 133.275] (EE) 12: /usr/libexec/Xorg.bin (CompositeRegisterImplicitRedirectionException+0x1fcd) [0x4cd0bd]
[ 133.275] (EE) 13: /usr/libexec/Xorg.bin (SwapConnClientPrefix+0x1e96) [0x464656]
[ 133.275] (EE) 14: /usr/libexec/Xorg.bin (MapWindow+0x117) [0x465697]
[ 133.275] (EE) 15: /usr/libexec/Xorg.bin (ProcBadRequest+0x5f5) [0x433d95]
[ 133.275] (EE) 16: /usr/libexec/Xorg.bin (SendErrorToClient+0x2f7) [0x439037]
[ 133.275] (EE) 17: /usr/libexec/Xorg.bin (remove_fs_handlers+0x416) [0x43d196]
[ 133.275] (EE) 18: /lib64/libc.so.6 (__libc_start_main+0xf0) [0x7f052db97fe0]
[ 133.276] (EE) 19: /usr/libexec/Xorg.bin (_start+0x29) [0x42761e]
[ 133.276] (EE) 20: ? (?+0x29) [0x29]
[ 133.276] (EE)
[ 133.276] (EE) Segmentation fault at address 0x0
[ 133.276] (EE)
Fatal server error:
[ 133.276] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 133.276] (EE)
[ 133.276] (EE)
Please consult the Fedora Project support
at http://wiki.x.org
for help.
[ 133.276] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 133.276] (EE)
[ 133.326] (EE) Server terminated with error (1). Closing log file.
But why is NVIDIA disabling it? That seems to be the question, no?
Xorg.0.log (29.1 KB)
nvidia-bug-report.log.gz (170 KB)
