• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi, I wanted to know how to pass input url to deepstream -app from the config file? instead of the “python3 python_rtsp-in-out.py -i file:////opt/nvidia/deepstream…”.
You can refer deepstream_test1 sample code (deepstream/sources/apps/sample_apps/deepstream-test1) in deepstream-6.1 on how it handles direct input or config file.
You can search “ymal” in the souce code, if the argv[1] includes ymal, it will enter the ymal config file parsing logic.
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks
