RTX 3090
retinanet
tao 3.22
{‘version’: ‘1’,
‘initial_epoch’: 0,
‘random_seed’: 42,
‘dataset_config’: {‘target_class_mapping’: [{‘key’: ‘person’,
‘value’: ‘person’}]},
‘training_config’: {‘batch_size_per_gpu’: 8,
‘num_epochs’: 1,
‘enable_qat’: False,
‘learning_rate’: {‘soft_start_annealing_schedule’: {‘min_learning_rate’: 4e-05,
‘max_learning_rate’: 0.015,
‘soft_start’: 0.1,
‘annealing’: 0.3}},
‘regularizer’: {‘type’: ‘L1’, ‘weight’: 2e-05},
‘checkpoint_interval’: 10,
‘n_workers’: 2,
‘optimizer’: {‘sgd’: {‘momentum’: 0.9, ‘nesterov’: False}}},
‘eval_config’: {‘average_precision_mode’: ‘SAMPLE’,
‘validation_period_during_training’: 10,
‘batch_size’: 8,
‘matching_iou_threshold’: 0.5},
‘nms_config’: {‘confidence_threshold’: 0.01,
‘clustering_iou_threshold’: 0.6,
‘top_k’: 200},
‘augmentation_config’: {‘output_width’: 1248,
‘output_height’: 384,
‘output_channel’: 3},
‘retinanet_config’: {‘aspect_ratios_global’: ‘[1.0, 2.0, 0.5]’,
‘two_boxes_for_ar1’: False,
‘clip_boxes’: False,
‘variances’: ‘[0.1, 0.1, 0.2, 0.2]’,
‘scales’: ‘[0.045, 0.09, 0.2, 0.4, 0.55, 0.7]’,
‘arch’: ‘resnet’,
‘nlayers’: 18,
‘freeze_bn’: False,
‘loss_loc_weight’: 0.8,
‘focal_loss_alpha’: 0.25,
‘focal_loss_gamma’: 2.0,
‘feature_size’: 256,
‘n_anchor_levels’: 1,
‘n_kernels’: 1}}
message:
“id”: “75a4b05d-56f0-4d69-84c3-e7c60c88089c”,
“parent_id”: null,
“action”: “train”,
“created_on”: “2022-08-30T23:11:05.709947”,
“last_modified”: “2022-08-30T23:11:29.206582”,
“status”: “Done”,
“result”: {
“detailed_status”: {
“date”: “8/30/2022”,
“time”: “23:11:19”,
“status”: “FAILURE”,
“message”: “The index file /shared/users/645b9950-2947-4240-a438-2d58c9be1989/datasets/d289a44a-39b9-4ebc-b548-43bf8a684f57/tfrecords/idx-tfrecords-fold-000-of-002-shard-00000-of-00010 for /shared/users/645b9950-2947-4240-a438-2d58c9be1989/datasets/d289a44a-39b9-4ebc-b548-43bf8a684f57/tfrecords/tfrecords-fold-000-of-002-shard-00000-of-00010 does not exist.”
“categorical”: ,
“kpi”: ,
“graphical”: ,
“epoch”: null,
“max_epoch”: null,
“eta”: null
When using retinanet, a message is output.
i have tfrecords-fold-000-of-002-shard-00000-of-00010 file.
not idx-tfrecords-fold-000-of-002-shard-00000-of-00010.
when i changed file name idx-* in tfrecord.
error message is “ZeroDivisionError: float division by zero”
What command should I give to recognize the file name or antoher command?
Thank you
