- I’m using TAO API 5.3 on AWS EKS, T4 GPU hardware.
- I’m training YOLOv4 on a custom kitti image dataset.
- I’ve successfully run the
dataset_convert
action on my train and val sets. - To obtain YOLOv4 anchors, I’ve modified the
kmeans
default spec to includesize_x
andsize_y
, and successfully run thekmeans
action over my dataset. The job runs successfully, but the output does not contain anchor shapes that I need foryolov4_config
in the training spec file.
Question: Via the API, how do I retrieve anchor shapes that result from running kmeans action?
Specifically referring to this step. Output is expected to be 3 tuples, something like this:
Code:
## Default specs; from {base_url}/datasets/{dataset_id}/specs/kmeans/schema"
specs = response.json()["default"]
specs["size_x"] = 512
specs["size_y"] = 512
## Kick off the kmeans job
parent = parent_id
action = "kmeans"
data = json.dumps({"parent_job_id": parent, "action": action, "specs": specs})
endpoint = f"{base_url}/datasets/{dataset_id}/jobs"
response = requests.post(endpoint, data=data, headers=headers, verify=False)
print(response)
Output (notice how job status=SUCCESS, but anchor shapes are not present):
{'action': 'kmeans',
'created_on': '2024-10-23T01:45:46.834550',
'dataset_id': 'ccfaa892-c6bc-4d4d-a87e-9f3cc7fe1195',
'description': '',
'id': '5adfacfe-8432-442f-90e0-d40feb3045c6',
'job_tar_stats':
{'file_size': 625,
'sha256_digest': 'af7be32bec080af4fa4b04ba9429ce5a5215749b41cf090047164c6a556672ce'
'last_modified': '2024-10-23T01:47:22.136608',
'name': '',
'parent_id': 'ec204a96-5f08-4fdf-8b32-4cb828d60cc6', 'result': {
'categorical': [],
'cur_iter': None,
'detailed_status': {
'date': '10/23/2024',
'message': 'K-means finished successfully.',
'status': 'SUCCESS',
'time': '1:47:8'
'epoch': None,
'eta': None,
'graphical': [],
'key_metric': 0.0,
'kpi': [],
'max_epoch': None,
'time_per_epoch': None,
'time_per_iter': None
'specs': {
'max_steps': 10000,
'min_x': 0,
'min_y': 0,
'num_clusters': 9,
'size_x': 512,
'size_y': 512
'status': 'Done'
