Tao classification tf1 could not load optimizer with init_epoch flag
• Hardware: ubuntu 20 x86 with RTX 3060
• Network Type: Classification tf1 (VehicleMakeNet - Resnet18)
• TLT Version: http://nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
• Training spec file:
train_car_make.txt (1.3 KB)
• The issue:
!tao model classification_tf1 train -e $SPECS_DIR/train_car_make.cfg \
                                    -r $USER_EXPERIMENT_DIR/unpruned_train \
                                    -c $USER_EXPERIMENT_DIR/unpruned_train/classmap.json \
                                    --init_epoch 12 -v
I tried to resume my training from epoch 12 but the optimizer of the pretrained model could not be loaded. I have a modified makenet with 35 outputs instead of the default. This is my output log:
To resume from a checkpoint, use --init_epoch along with your checkpoint configured in the spec file.
Please make sure that the model_path in the spec file is now updated to the '.hdf5' file of the correspondingepoch you wish to resume from. You may choose from the files found under, '$USER_EXPERIMENT_DIR/output/weights' folder.
2024-08-08 09:54:46,475 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2024-08-08 09:54:46,527 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 361: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
2024-08-08 09:54:46,724 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 301: Printing tty value True
Using TensorFlow backend.
2024-08-08 07:54:47.199036: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2024-08-08 07:54:47,229 [TAO Toolkit] [WARNING] tensorflow 40: Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2024-08-08 07:54:47,977 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable  TF_ALLOW_IOLIBS=1.
2024-08-08 07:54:48,005 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable  TF_ALLOW_IOLIBS=1.
2024-08-08 07:54:48,007 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable  TF_ALLOW_IOLIBS=1.
/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/utils/helper.py:150: NumbaDeprecationWarning: The 'nopython' keyword argument was not supplied to the 'numba.jit' decorator. The implicit default value for this argument is currently False, but it will be changed to True in Numba 0.59.0. See https://numba.readthedocs.io/en/stable/reference/deprecation.html#deprecation-of-object-mode-fall-back-behaviour-when-using-jit for details.
  def random_hue(img, max_delta=10.0):
/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/utils/helper.py:173: NumbaDeprecationWarning: The 'nopython' keyword argument was not supplied to the 'numba.jit' decorator. The implicit default value for this argument is currently False, but it will be changed to True in Numba 0.59.0. See https://numba.readthedocs.io/en/stable/reference/deprecation.html#deprecation-of-object-mode-fall-back-behaviour-when-using-jit for details.
  def random_saturation(img, max_shift):
/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/utils/helper.py:183: NumbaDeprecationWarning: The 'nopython' keyword argument was not supplied to the 'numba.jit' decorator. The implicit default value for this argument is currently False, but it will be changed to True in Numba 0.59.0. See https://numba.readthedocs.io/en/stable/reference/deprecation.html#deprecation-of-object-mode-fall-back-behaviour-when-using-jit for details.
  def random_contrast(img, center, max_contrast_scale):
/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/utils/helper.py:192: NumbaDeprecationWarning: The 'nopython' keyword argument was not supplied to the 'numba.jit' decorator. The implicit default value for this argument is currently False, but it will be changed to True in Numba 0.59.0. See https://numba.readthedocs.io/en/stable/reference/deprecation.html#deprecation-of-object-mode-fall-back-behaviour-when-using-jit for details.
  def random_shift(x_img, shift_stddev):
2024-08-08 07:54:49.114284: I tensorflow/core/platform/profile_utils/cpu_utils.cc:109] CPU Frequency: 2592000000 Hz
2024-08-08 07:54:49.115429: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x9a5e060 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2024-08-08 07:54:49.115453: I tensorflow/compiler/xla/service/service.cc:176]   StreamExecutor device (0): Host, Default Version
2024-08-08 07:54:49.116374: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcuda.so.1
2024-08-08 07:54:49.147173: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-08-08 07:54:49.147322: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x9557410 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2024-08-08 07:54:49.147340: I tensorflow/compiler/xla/service/service.cc:176]   StreamExecutor device (0): NVIDIA GeForce RTX 3060, Compute Capability 8.6
2024-08-08 07:54:49.147491: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-08-08 07:54:49.147566: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1674] Found device 0 with properties:
name: NVIDIA GeForce RTX 3060 major: 8 minor: 6 memoryClockRate(GHz): 1.807
pciBusID: 0000:01:00.0
2024-08-08 07:54:49.147591: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2024-08-08 07:54:49.147638: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcublas.so.12
2024-08-08 07:54:49.148595: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcufft.so.11
2024-08-08 07:54:49.148638: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcurand.so.10
2024-08-08 07:54:49.150291: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcusolver.so.11
2024-08-08 07:54:49.150836: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcusparse.so.12
2024-08-08 07:54:49.150874: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudnn.so.8
2024-08-08 07:54:49.150943: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-08-08 07:54:49.151059: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-08-08 07:54:49.151118: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1802] Adding visible gpu devices: 0
2024-08-08 07:54:49.151139: I tensorflow/stream_executor/platform/default/dso_loader.cc:50] Successfully opened dynamic library libcudart.so.12
2024-08-08 07:54:49.156277: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1214] Device interconnect StreamExecutor with strength 1 edge matrix:
2024-08-08 07:54:49.156305: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1220]      0
2024-08-08 07:54:49.156312: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1233] 0:   N
2024-08-08 07:54:49.156465: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-08-08 07:54:49.156581: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1082] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2024-08-08 07:54:49.156657: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1359] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 8925 MB memory) -> physical GPU (device: 0, name: NVIDIA GeForce RTX 3060, pci bus id: 0000:01:00.0, compute capability: 8.6)
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable  TF_ALLOW_IOLIBS=1.
2024-08-08 07:54:50,186 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use sklearn by default. This improves performance in some cases. To enable sklearn export the environment variable  TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable  TF_ALLOW_IOLIBS=1.
2024-08-08 07:54:50,212 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable  TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable  TF_ALLOW_IOLIBS=1.
2024-08-08 07:54:50,215 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable  TF_ALLOW_IOLIBS=1.
2024-08-08 07:54:50,996 [TAO Toolkit] [INFO] __main__ 388: Loading experiment spec at /specs/train_car_make.cfg.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:398: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2024-08-08 07:54:50,998 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:398: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:407: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2024-08-08 07:54:50,998 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:407: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2024-08-08 07:54:51,062 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.common.logging.logging 197: Log file already exists at /workspace/tao-experiments/unpruned_train/status.json
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:431: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2024-08-08 07:54:51,062 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:431: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:431: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
2024-08-08 07:54:51,063 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py:431: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
Found 131924 images belonging to 35 classes.
2024-08-08 07:54:52,535 [TAO Toolkit] [INFO] __main__ 294: Processing dataset (train): /data/training_set
Found 22040 images belonging to 35 classes.
2024-08-08 07:54:52,789 [TAO Toolkit] [INFO] __main__ 311: Processing dataset (validation): /data/val_set
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:74: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2024-08-08 07:54:52,789 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:74: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2024-08-08 07:54:52,789 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2024-08-08 07:54:52,790 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2024-08-08 07:54:52,804 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:133: The name tf.placeholder_with_default is deprecated. Please use tf.compat.v1.placeholder_with_default instead.
2024-08-08 07:54:52,807 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:133: The name tf.placeholder_with_default is deprecated. Please use tf.compat.v1.placeholder_with_default instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/third_party/keras/tensorflow_backend.py:199: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2024-08-08 07:54:53,345 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/third_party/keras/tensorflow_backend.py:199: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2024-08-08 07:54:53,882 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2024-08-08 07:54:53,882 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2024-08-08 07:54:53,882 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2024-08-08 07:54:54,196 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
input_1 (InputLayer)            (None, 3, 224, 224)  0
conv1 (Conv2D)                  (None, 64, 112, 112) 9408        input_1[0][0]
bn_conv1 (BatchNormalization)   (None, 64, 112, 112) 256         conv1[0][0]
activation_1 (Activation)       (None, 64, 112, 112) 0           bn_conv1[0][0]
block_1a_conv_1 (Conv2D)        (None, 64, 56, 56)   36864       activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 56, 56)   256         block_1a_conv_1[0][0]
block_1a_relu_1 (Activation)    (None, 64, 56, 56)   0           block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D)        (None, 64, 56, 56)   36864       block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 56, 56)   4096        activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 56, 56)   256         block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 56, 56)   256         block_1a_conv_shortcut[0][0]
add_1 (Add)                     (None, 64, 56, 56)   0           block_1a_bn_2[0][0]
        block_1a_bn_shortcut[0][0]
block_1a_relu (Activation)      (None, 64, 56, 56)   0           add_1[0][0]
block_1b_conv_1 (Conv2D)        (None, 64, 56, 56)   36864       block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 56, 56)   256         block_1b_conv_1[0][0]
block_1b_relu_1 (Activation)    (None, 64, 56, 56)   0           block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D)        (None, 64, 56, 56)   36864       block_1b_relu_1[0][0]
block_1b_conv_shortcut (Conv2D) (None, 64, 56, 56)   4096        block_1a_relu[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 56, 56)   256         block_1b_conv_2[0][0]
block_1b_bn_shortcut (BatchNorm (None, 64, 56, 56)   256         block_1b_conv_shortcut[0][0]
add_2 (Add)                     (None, 64, 56, 56)   0           block_1b_bn_2[0][0]
        block_1b_bn_shortcut[0][0]
block_1b_relu (Activation)      (None, 64, 56, 56)   0           add_2[0][0]
block_2a_conv_1 (Conv2D)        (None, 128, 28, 28)  73728       block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 28, 28)  512         block_2a_conv_1[0][0]
block_2a_relu_1 (Activation)    (None, 128, 28, 28)  0           block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D)        (None, 128, 28, 28)  147456      block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 28, 28)  8192        block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 28, 28)  512         block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 28, 28)  512         block_2a_conv_shortcut[0][0]
add_3 (Add)                     (None, 128, 28, 28)  0           block_2a_bn_2[0][0]
        block_2a_bn_shortcut[0][0]
block_2a_relu (Activation)      (None, 128, 28, 28)  0           add_3[0][0]
block_2b_conv_1 (Conv2D)        (None, 128, 28, 28)  147456      block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 28, 28)  512         block_2b_conv_1[0][0]
block_2b_relu_1 (Activation)    (None, 128, 28, 28)  0           block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D)        (None, 128, 28, 28)  147456      block_2b_relu_1[0][0]
block_2b_conv_shortcut (Conv2D) (None, 128, 28, 28)  16384       block_2a_relu[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 28, 28)  512         block_2b_conv_2[0][0]
block_2b_bn_shortcut (BatchNorm (None, 128, 28, 28)  512         block_2b_conv_shortcut[0][0]
add_4 (Add)                     (None, 128, 28, 28)  0           block_2b_bn_2[0][0]
        block_2b_bn_shortcut[0][0]
block_2b_relu (Activation)      (None, 128, 28, 28)  0           add_4[0][0]
block_3a_conv_1 (Conv2D)        (None, 256, 14, 14)  294912      block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 14, 14)  1024        block_3a_conv_1[0][0]
block_3a_relu_1 (Activation)    (None, 256, 14, 14)  0           block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D)        (None, 256, 14, 14)  589824      block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 14, 14)  32768       block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 14, 14)  1024        block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 14, 14)  1024        block_3a_conv_shortcut[0][0]
add_5 (Add)                     (None, 256, 14, 14)  0           block_3a_bn_2[0][0]
        block_3a_bn_shortcut[0][0]
block_3a_relu (Activation)      (None, 256, 14, 14)  0           add_5[0][0]
block_3b_conv_1 (Conv2D)        (None, 256, 14, 14)  589824      block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 14, 14)  1024        block_3b_conv_1[0][0]
block_3b_relu_1 (Activation)    (None, 256, 14, 14)  0           block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D)        (None, 256, 14, 14)  589824      block_3b_relu_1[0][0]
block_3b_conv_shortcut (Conv2D) (None, 256, 14, 14)  65536       block_3a_relu[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 14, 14)  1024        block_3b_conv_2[0][0]
block_3b_bn_shortcut (BatchNorm (None, 256, 14, 14)  1024        block_3b_conv_shortcut[0][0]
add_6 (Add)                     (None, 256, 14, 14)  0           block_3b_bn_2[0][0]
        block_3b_bn_shortcut[0][0]
block_3b_relu (Activation)      (None, 256, 14, 14)  0           add_6[0][0]
block_4a_conv_1 (Conv2D)        (None, 512, 14, 14)  1179648     block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 14, 14)  2048        block_4a_conv_1[0][0]
block_4a_relu_1 (Activation)    (None, 512, 14, 14)  0           block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D)        (None, 512, 14, 14)  2359296     block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 14, 14)  131072      block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 14, 14)  2048        block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 14, 14)  2048        block_4a_conv_shortcut[0][0]
add_7 (Add)                     (None, 512, 14, 14)  0           block_4a_bn_2[0][0]
        block_4a_bn_shortcut[0][0]
block_4a_relu (Activation)      (None, 512, 14, 14)  0           add_7[0][0]
block_4b_conv_1 (Conv2D)        (None, 512, 14, 14)  2359296     block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 14, 14)  2048        block_4b_conv_1[0][0]
block_4b_relu_1 (Activation)    (None, 512, 14, 14)  0           block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D)        (None, 512, 14, 14)  2359296     block_4b_relu_1[0][0]
block_4b_conv_shortcut (Conv2D) (None, 512, 14, 14)  262144      block_4a_relu[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 14, 14)  2048        block_4b_conv_2[0][0]
block_4b_bn_shortcut (BatchNorm (None, 512, 14, 14)  2048        block_4b_conv_shortcut[0][0]
add_8 (Add)                     (None, 512, 14, 14)  0           block_4b_bn_2[0][0]
        block_4b_bn_shortcut[0][0]
block_4b_relu (Activation)      (None, 512, 14, 14)  0           add_8[0][0]
avg_pool (AveragePooling2D)     (None, 512, 1, 1)    0           block_4b_relu[0][0]
flatten (Flatten)               (None, 512)          0           avg_pool[0][0]
predictions (Dense)             (None, 35)           17955       flatten[0][0]
Total params: 11,560,419
Trainable params: 11,539,363
Non-trainable params: 21,056
2024-08-08 07:55:08,722 [TAO Toolkit] [INFO] root 2102: type 'NoneType' is not an acceptable base type
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py", line 668, in <module>
    main()
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py", line 717, in return_func
    raise e
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/utils.py", line 705, in return_func
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py", line 664, in main
    raise e
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py", line 645, in main
    run_experiment(config_path=args.experiment_spec_file,
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/train.py", line 580, in run_experiment
    opt = hvd.DistributedOptimizer(opt)
  File "/usr/local/lib/python3.8/dist-packages/horovod/keras/__init__.py", line 102, in DistributedOptimizer
    return _impl.create_distributed_optimizer(
  File "/usr/local/lib/python3.8/dist-packages/horovod/_keras/__init__.py", line 252, in create_distributed_optimizer
    cls = type(optimizer.__class__.__name__, (optimizer.__class__,),
TypeError: type 'NoneType' is not an acceptable base type
Execution status: FAIL
2024-08-08 09:55:12,358 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 363: Stopping container.
Since you already trained a model of 12th epoch, and the class number is the expected 35, please resume training by using original docker instead of a modified docker.
I am training the model using the original docker. I only trained the first epoch with the modified docker. I take this modified net and train with the original docker 12 epochs. Then, I wanted to resume the training from epoch 12 but i get that error.
This is an issue for original docker. There is problem in resume training.
Please set a larger epochs to train.
Or you can use classification_pytorch network instead.
For TAO5.0, you can change https://github.com/NVIDIA/tao_tensorflow1_backend/blob/main/nvidia_tao_tf1/cv/makenet/utils/helper.py#L138 to below.
keras.models.load_model(str(model_path), compile=True)
It can resume training.
