Tao-client fail to cancel job
$ tao-client --version
tao-client, version 4.0.0
$ tao-client lprnet model-job-cancel
job: 0fcde70b-4187-493e-8424-a9b612081c09
  File "/home/nvidiatao/.local/bin/tao-client", line 8, in <module>
    sys.exit(cli())
  File "/home/nvidiatao/.local/lib/python3.8/site-packages/click/core.py", line 1130, in __call__
    return self.main(*args, **kwargs)
  File "/home/nvidiatao/.local/lib/python3.8/site-packages/click/core.py", line 1055, in main
    rv = self.invoke(ctx)
  File "/home/nvidiatao/.local/lib/python3.8/site-packages/click/core.py", line 1657, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/home/nvidiatao/.local/lib/python3.8/site-packages/click/core.py", line 1404, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/home/nvidiatao/.local/lib/python3.8/site-packages/click/core.py", line 760, in invoke
    return __callback(*args, **kwargs)
  File "/home/nvidiatao/.local/lib/python3.8/site-packages/tao_cli/networks/lprnet.py", line 151, in model_job_cancel
    model_obj.model_job_cancel(id, job)
AttributeError: 'Model' object has no attribute 'model_job_cancel'
Could you share the full notebook as well?
How about other commands? Are they successful?
Hi @Morganh,
Only model_create works all others command does not work.
I have check the python code and found some issues.
The class Model() have only one function despite call others functions such as model_job_cancel.
from tao_cli.cli_actions.model import Model
dataset_obj = Dataset()
model_obj = Model()
@lprnet.command()
@click.option('--id', prompt='id', help='The model ID.', required=True)
@click.option('--job', prompt='job', help='The job ID.', required=True)
def model_job_cancel(id, job):
    click.echo(f"{job}")
The content of tao_cli.cli_actions.model
# SPDX-FileCopyrightText: Copyright (c) 2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
import json
import requests
from tao_cli.cli_actions.actions import Actions
class Model(Actions):
    def __init__(self):
        super().__init__()
    def model_create(self, network_arch, encryption_key):
        data = json.dumps( {"network_arch": network_arch, "encryption_key": encryption_key} )
        endpoint = self.base_url + "/model"
        response = requests.post(endpoint, data=data, headers=self.headers)
        id = response.json()["id"]
        return id
If you follow notebook to run the commands, may I know which jupyter notebook did you follow?
I’m using tao-getting-started_v4.0.0/notebooks/tao_api_starter_kit/client/automl/lprnet.ipynb.
The notebook have no issue all is working well.
The question is what is procedure to stop a training since all method (tao-client and tao-api) that I have used does not work and there is no procedure on notebook to stop the training.
By mistake I started 2 training. I ran the cell twice and I really need to stop one of the trainings.
I had to find process training on OS and kill all process on OS.
Using tao-client I can create a job but I cannot cancel a job due erros raised.
BASE_URL=http://localhost:32080/default/api/v1
tao-client login --ngc-api-key <api_key>
USER="user_id"
TOKEN="token_id"
tao-client lprnet model-train --id ## IT Works
tao-client lprnet model-job-cancel  ## IT FAIL
Using Tao API
Cancel don’t works its return nothing and does not stop the job.
curl "http://myhost.amazonaws.com:32080/api/v1/user/<userid>/model/59fd22a8-57bc-489e-8530-3a346c1177f9/job/0847956d-7ceb-4cc3-85b1-9cf1dd7cffe3/cancel" \
  -X POST \
  -H "authorization: Bearer  <auth_key>"
Delete Job works well. Job is deleted if not running.
curl "http://myhost.amazonaws.com:32080/api/v1/user/<user_id>/model/59fd22a8-57bc-489e-8530-3a346c1177f9/job/e0df15e0-222b-4daa-83bf-c562fc044cdf" \
  -X DELETE \
It query job status without issues.
curl "http://myhost.amazonaws.com:32080/api/v1/user/<user_id>/model/59fd22a8-57bc-489e-8530-3a346c1177f9/job/0847956d-7ceb-4cc3-85b1-9cf1dd7cffe3" \
  -H "authorization: Bearer <auth_key>  "
I can reproduce with above command. Will check internally.
We will provide new tao client wheel. Please stay tune.
News?
Currently, there is not any update yet.
