[TAO Deploy] INT8 Calibration Fails for RT-DETR with MultiscaleDeformableAttnPlugin_TRT – Assertion context->executeV2 Error
Dear @Morganh
I trained teacher and student model inside 6.26 containers and then I created notebook for training using tao.
I am able to train model both teacher and student and able to generate fp16 engine file.
But when I try to generate calibration cache and int8 file using !tao deploy rtdetr gen_trt_engine -e /workspace/tao-experiments/specs/deploy.yaml
I am getting following error.
2026-06-23 12:30:41,457 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2026-06-23 12:30:41,535 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 360: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:6.26.3-deploy
2026-06-23 12:30:41,558 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 303:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/smarg/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
2026-06-23 12:30:41,558 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 316: Printing tty value True
2026-06-23 07:00:43,126 - nvidia_tao_core.microservices.utils.job_utils.workflow - INFO - Logging configured at level: INFO
2026-06-23 07:00:45,669 [TAO Toolkit] [INFO] nvidia_tao_core.microservices.utils.job_utils.workflow 61: Logging configured at level: INFOsys:1: UserWarning:
'deploy.yaml' is validated against ConfigStore schema with the same name.
This behavior is deprecated in Hydra 1.1 and will be removed in Hydra 1.2.
See https://hydra.cc/docs/1.2/upgrades/1.0_to_1.1/automatic_schema_matching for migration instructions.
/usr/local/lib/python3.12/dist-packages/nvidia_tao_deploy/cv/common/hydra/hydra_runner.py:99: UserWarning:
  _run_hydra(
/usr/local/lib/python3.12/dist-packages/hydra/_internal/hydra.py:119: UserWarning: Future Hydra versions will no longer change working directory at job runtime by default.
See https://hydra.cc/docs/1.2/upgrades/1.1_to_1.2/changes_to_job_working_dir/ for more information.
  ret = run_job(
Gen_trt_engine results will be saved at: /workspace/tao-experiments/results/trt_engine_logs
Log file already exists at /workspace/tao-experiments/results/trt_engine_logs/status.json
Starting rtdetr gen_trt_engine.
No QDQ quantization operators found in ONNX model.
[06/23/2026-07:00:47] [TRT] [I] [MemUsageChange] Init builder kernel library: CPU +989, GPU +4, now: CPU 1278, GPU 894 (MiB)Setting up QAT mode: False
[06/23/2026-07:00:47] [TRT] [I] Successfully created plugin: MultiscaleDeformableAttnPlugin_TRTParsing ONNX modelin_namespace:istil_TeR50_StR18_Res352x576_FP32_V2.1.pth.onnx
List inputs:
Input 0 -> inputs.
(3, 352, 576).
-1.
Network Description
Input 'inputs' with shape (-1, 3, 352, 576) and dtype DataType.FLOAT
Output 'pred_logits' with shape (-1, 300, 4) and dtype DataType.FLOAT
Output 'pred_boxes' with shape (-1, 300, 4) and dtype DataType.FLOAT
Calibrating using ImageBatcher
TensorRT engine build configurations:
  OptimizationProfile:
    "inputs": (1, 3, 352, 576), (50, 3, 352, 576), (50, 3, 352, 576)
  BuilderFlag.FP16
  BuilderFlag.INT8
  BuilderFlag.TF32
  Note: max representabile value is 2,147,483,648 bytes or 2GB.
  MemoryPoolType.WORKSPACE = 2147483648 bytes
  MemoryPoolType.DLA_MANAGED_SRAM = 0 bytes
  MemoryPoolType.DLA_LOCAL_DRAM = 1073741824 bytes
  MemoryPoolType.DLA_GLOBAL_DRAM = 536870912 bytes
  MemoryPoolType.TACTIC_DRAM = 16606232576 bytes
  MemoryPoolType.TACTIC_SHARED_MEMORY = 1073741824 bytes
  Tactic Sources = 24
[06/23/2026-07:01:00] [TRT] [I] Starting Calibration.orRT-managed allocation in IExecutionContext creation: CPU +1, GPU +1867, now: CPU 1, GPU 2030 (MiB)Calibrating image 8 / 400
[06/23/2026-07:01:00] [TRT] [E] [calibrator.cpp::calibrateEngine::1219] Error Code 2: Internal Error (Assertion context->executeV2(bindings.data()) failed.  In calibrateEngine at optimizer/api/calibrator.cpp:1219)Parameter validation error: 'NoneType' object does not support the context manager protocol
Error executing job with overrides: []Traceback (most recent call last):
  File "/usr/local/lib/python3.12/dist-packages/nvidia_tao_deploy/cv/common/decorators.py", line 115, in _func
    raise e
  File "/usr/local/lib/python3.12/dist-packages/nvidia_tao_deploy/cv/common/decorators.py", line 76, in _func
    runner(cfg, **kwargs)
  File "/usr/local/lib/python3.12/dist-packages/nvidia_tao_deploy/cv/rtdetr/scripts/gen_trt_engine.py", line 72, in main
    builder.create_engine(**create_engine_kwargs)
  File "/usr/local/lib/python3.12/dist-packages/nvidia_tao_deploy/engine/builder.py", line 507, in create_engine
    self._write_engine(engine_path)
  File "/usr/local/lib/python3.12/dist-packages/nvidia_tao_deploy/engine/builder.py", line 519, in _write_engine
    with self.builder.build_serialized_network(self.network, self.config) as engine_bytes, \
TypeError: 'NoneType' object does not support the context manager protocol
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
PyCUDA WARNING: a clean-up operation failed (dead context maybe?)
cuMemFree failed: an illegal memory access was encountered
2026-06-23 07:01:01,182 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - Telemetry data couldn't be sent, but the command ran successfully.
2026-06-23 07:01:01,182 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - 'str' object has no attribute 'decode'
2026-06-23 12:31:01,560 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 381: Stopping container.
Below is my deploy.yaml file
# deploy_spec.yaml
gen_trt_engine:
  results_dir: /workspace/tao-experiments/results/trt_engine_logs
  onnx_file: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_FP32_V2.1.pth.onnx
  trt_engine: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_int8_V2.1.pth.engine
  # input_channel: 3
  # input_width: 576
  # input_height: 352
  tensorrt:
    data_type: int8
    # data_type: fp16
    workspace_size: 2048
    min_batch_size: 1
    opt_batch_size: 50
    max_batch_size: 50
    calibration:
      cal_image_dir:
        - /workspace/tao-experiments/dataset/calibration_data/image_2
      cal_cache_file: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_FP32_V2.1.pth.cache
      cal_batch_size: 8
      cal_batches: 50
I had tried directly run inside container but same issue.
Script for calib data generation.
import json
import shutil
import os
from pathlib import Path
# Paths
val_json = '../dataset/val/val_annotations_coco.json'
val_images = '../dataset/val/image_2'
output_dir = '../calibration_data'
output_json = '../calibration_data/calib_annotations.json'
# Create output directory
os.makedirs(output_dir, exist_ok=True)
# Load validation annotations
with open(val_json, 'r') as f:
    coco_data = json.load(f)
# Take first 500 images (or use random sampling)
num_images = 2000
selected_images = coco_data['images'][:num_images]
selected_img_ids = {img['id'] for img in selected_images}
# Filter annotations
selected_annotations = [ann for ann in coco_data['annotations'] if ann['image_id'] in selected_img_ids]
# Create new COCO data structure
calib_data = {
    'images': selected_images,
    'annotations': selected_annotations,
    'categories': coco_data['categories']
# Save new JSON
with open(output_json, 'w') as f:
    json.dump(calib_data, f, indent=2)
# Copy corresponding images
for img in selected_images:
    src = os.path.join(val_images, img['file_name'])
    dst = os.path.join(output_dir, img['file_name'])
    if os.path.exists(src):
        shutil.copy(src, dst)
print(f"Created calibration set with {len(selected_images)} images")
print(f"JSON saved to: {output_json}")
print(f"Images saved to: {output_dir}")
Can u please suggest how to resolve this issue so that I can generate calib file and please let me know if further details are needed.
Could you set all to 1 and retry? I am afraid it is due to OOM.
Yes with max batch size 1 I am able to to generate engine.
The engine generated successfully but when I evaluate that engine file then the MAP is nearly zero.
Command For Engine Evaluation:
!tao deploy rtdetr evaluate \
    -e /workspace/tao-experiments/specs/eval_engine.yaml \
    results_dir=/workspace/tao-experiments/results/trt_evaluation \
    evaluate.trt_engine=/workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_int8_b8_V2.1.pth.engine
eval_engine.yaml
# /workspace/tao-experiments/specs/eval_engine.yaml
dataset:
  # ***IMPORTANT: Change this to your TEST dataset for final validation***
  test_data_sources:
    image_dir: /workspace/tao-experiments/dataset/val/image_2
    json_file: /workspace/tao-experiments/dataset/val/val_annotations_coco.json
  num_classes: 4
  batch_size: 8  # Batch size for evaluation
evaluate:
  # Path to the .engine file you generated
  trt_engine: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_int8_b8_V2.1.pth.engine
  conf_threshold: 0.3
  input_width: 576
  input_height: 352
Output:
5207000/5207700
creating index...
index created!
Running per image evaluation...
Evaluate annotation type *bbox*
DONE (t=94.51s).
Accumulating evaluation results...
DONE (t=13.07s).
Average Recall     (AR) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.011AP: 0.000004455
AP50: 0.000022938
AP75: 0.000000468
APl: 0.000012118
APm: 0.000009010
APs: 0.000000000
ARl: 0.011173207
ARm: 0.000544091
ARmax1: 0.000062366
ARmax10: 0.000470478
ARmax100: 0.003145635
ARs: 0.000000000
Finished evaluation.
Trt_evaluate finished successfully.
2026-06-23 13:53:49,292 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - Telemetry data couldn't be sent, but the command ran successfully.
2026-06-23 13:53:49,292 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - 'str' object has no attribute 'decode'
2026-06-23 19:23:49,822 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 381: Stopping container.
Can u help me with this why the values are nearly zero?
I checked my evaluation dataset also and it seems correct because I had trained one model with input size 960x544 and the int8 engine was generate successfully even with the large batch size and the MAP drop was around 2-3% (Inital MAP ~0.7 after int8 ~0.68) only but when I have trained model with 576x352 to get high fps I am only able to generate int8 engine with max batch size of 8 and the map of int8 is nearly zero (Orignal and Fp16 MAP ~0.64 after int8 ~0.0000). Please suggest where are the gaps. Machine is same 5080 GPU and the dataset is also same.
Please provide your thoughts on this. Why this is zero and what changes can improve this?
So,
For 960x544, the initial MAP ~0.7 and after int8 ~0.68.
For 576x352, the fp16 MAP ~0.64 and after int8 ~0.0. Could you set to below and generate int8 engine to recheck the mAP?
    min_batch_size: 1
    opt_batch_size: 1
    max_batch_size: 1
Yes Initially I Checked with batch size 1 and got the zero MAP then I moved to batch size 8 and generate engine and the same results zero MAP.
Please find logs below with batch size 1
Config:
# deploy_spec.yaml
gen_trt_engine:
  trt_engine: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_int8_b1_V2.1.pth.engine
  # input_channel: 3
  # input_width: 960
  # input_height: 544
  tensorrt:
    data_type: int8
    # data_type: fp16
    min_batch_size: 1
    opt_batch_size: 1
    max_batch_size: 1
    calibration:
      cal_image_dir:
      cal_cache_file: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_FP32_b1_V2.1.pth.cache
      cal_batch_size: 8
      cal_batches: 50
Command:
Output:
2026-06-24 12:21:53,317 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2026-06-24 12:21:53,401 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 360: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:6.26.3-deploy
2026-06-24 12:21:53,438 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 303:
terminal.
2026-06-24 12:21:53,438 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 316: Printing tty value True
2026-06-24 06:51:55,984 - nvidia_tao_core.microservices.utils.job_utils.workflow - INFO - Logging configured at level: INFO
2026-06-24 06:51:58,834 [TAO Toolkit] [INFO] nvidia_tao_core.microservices.utils.job_utils.workflow 61: Logging configured at level: INFOsys:1: UserWarning:
  _run_hydra(
  ret = run_job(
[06/24/2026-06:52:00] [TRT] [I] [MemUsageChange] Init builder kernel library: CPU +989, GPU +8, now: CPU 1278, GPU 1035 (MiB)Setting up QAT mode: False
[06/24/2026-06:52:00] [TRT] [I] Successfully created plugin: MultiscaleDeformableAttnPlugin_TRTParsing ONNX modelin_namespace:istil_TeR50_StR18_Res352x576_FP32_V2.1.pth.onnx
List inputs:
Input 0 -> inputs.
(3, 352, 576).
-1.
Network Description
    "inputs": (1, 3, 352, 576), (1, 3, 352, 576), (1, 3, 352, 576)
  BuilderFlag.FP16
  BuilderFlag.INT8
  BuilderFlag.TF32
  Tactic Sources = 24
[06/24/2026-06:52:12] [TRT] [I] Starting Calibration.orRT-managed allocation in IExecutionContext creation: CPU +1, GPU +37, now: CPU 1, GPU 200 (MiB)Calibrating image 8 / 400
[06/24/2026-06:52:13] [TRT] [I]   Calibrated batch 0 in 0.128627 seconds.Calibrating image 16 / 400
[06/24/2026-06:52:13] [TRT] [I]   Calibrated batch 1 in 0.100551 seconds.Calibrating image 24 / 400
[06/24/2026-06:52:13] [TRT] [I]   Calibrated batch 2 in 0.0901082 seconds.Calibrating image 32 / 400
[06/24/2026-06:52:13] [TRT] [I]   Calibrated batch 3 in 0.091215 seconds.Calibrating image 40 / 400
[06/24/2026-06:52:13] [TRT] [I]   Calibrated batch 4 in 0.106261 seconds.Calibrating image 48 / 400
[06/24/2026-06:52:13] [TRT] [I]   Calibrated batch 5 in 0.0999125 seconds.Calibrating image 56 / 400
[06/24/2026-06:52:13] [TRT] [I]   Calibrated batch 6 in 0.112776 seconds.Calibrating image 64 / 400
[06/24/2026-06:52:14] [TRT] [I]   Calibrated batch 7 in 0.0924718 seconds.Calibrating image 72 / 400
[06/24/2026-06:52:14] [TRT] [I]   Calibrated batch 8 in 0.0929985 seconds.Calibrating image 80 / 400
[06/24/2026-06:52:14] [TRT] [I]   Calibrated batch 9 in 0.090808 seconds.Calibrating image 88 / 400
[06/24/2026-06:52:14] [TRT] [I]   Calibrated batch 10 in 0.0915062 seconds.Calibrating image 96 / 400
[06/24/2026-06:52:14] [TRT] [I]   Calibrated batch 11 in 0.0975997 seconds.Calibrating image 104 / 400
[06/24/2026-06:52:14] [TRT] [I]   Calibrated batch 12 in 0.107555 seconds.Calibrating image 112 / 400
[06/24/2026-06:52:14] [TRT] [I]   Calibrated batch 13 in 0.103318 seconds.Calibrating image 120 / 400
[06/24/2026-06:52:14] [TRT] [I]   Calibrated batch 14 in 0.0959733 seconds.Calibrating image 128 / 400
[06/24/2026-06:52:15] [TRT] [I]   Calibrated batch 15 in 0.0930836 seconds.Calibrating image 136 / 400
[06/24/2026-06:52:15] [TRT] [I]   Calibrated batch 16 in 0.0919292 seconds.Calibrating image 144 / 400
[06/24/2026-06:52:15] [TRT] [I]   Calibrated batch 17 in 0.0961359 seconds.Calibrating image 152 / 400
[06/24/2026-06:52:15] [TRT] [I]   Calibrated batch 18 in 0.107729 seconds.Calibrating image 160 / 400
[06/24/2026-06:52:15] [TRT] [I]   Calibrated batch 19 in 0.0931712 seconds.Calibrating image 168 / 400
[06/24/2026-06:52:15] [TRT] [I]   Calibrated batch 20 in 0.0900611 seconds.Calibrating image 176 / 400
[06/24/2026-06:52:15] [TRT] [I]   Calibrated batch 21 in 0.0930732 seconds.Calibrating image 184 / 400
[06/24/2026-06:52:15] [TRT] [I]   Calibrated batch 22 in 0.102 seconds.Calibrating image 192 / 400
[06/24/2026-06:52:16] [TRT] [I]   Calibrated batch 23 in 0.0962684 seconds.Calibrating image 200 / 400
[06/24/2026-06:52:16] [TRT] [I]   Calibrated batch 24 in 0.0924618 seconds.Calibrating image 208 / 400
[06/24/2026-06:52:16] [TRT] [I]   Calibrated batch 25 in 0.0951119 seconds.Calibrating image 216 / 400
[06/24/2026-06:52:16] [TRT] [I]   Calibrated batch 26 in 0.0953239 seconds.Calibrating image 224 / 400
[06/24/2026-06:52:16] [TRT] [I]   Calibrated batch 27 in 0.092313 seconds.Calibrating image 232 / 400
[06/24/2026-06:52:16] [TRT] [I]   Calibrated batch 28 in 0.0912027 seconds.Calibrating image 240 / 400
[06/24/2026-06:52:16] [TRT] [I]   Calibrated batch 29 in 0.0964786 seconds.Calibrating image 248 / 400
[06/24/2026-06:52:16] [TRT] [I]   Calibrated batch 30 in 0.0977117 seconds.Calibrating image 256 / 400
[06/24/2026-06:52:17] [TRT] [I]   Calibrated batch 31 in 0.0949506 seconds.Calibrating image 264 / 400
[06/24/2026-06:52:17] [TRT] [I]   Calibrated batch 32 in 0.0930039 seconds.Calibrating image 272 / 400
[06/24/2026-06:52:17] [TRT] [I]   Calibrated batch 33 in 0.0922292 seconds.Calibrating image 280 / 400
[06/24/2026-06:52:17] [TRT] [I]   Calibrated batch 34 in 0.0927255 seconds.Calibrating image 288 / 400
[06/24/2026-06:52:17] [TRT] [I]   Calibrated batch 35 in 0.0936367 seconds.Calibrating image 296 / 400
[06/24/2026-06:52:17] [TRT] [I]   Calibrated batch 36 in 0.095768 seconds.Calibrating image 304 / 400
[06/24/2026-06:52:17] [TRT] [I]   Calibrated batch 37 in 0.090016 seconds.Calibrating image 312 / 400
[06/24/2026-06:52:17] [TRT] [I]   Calibrated batch 38 in 0.094425 seconds.Calibrating image 320 / 400
[06/24/2026-06:52:18] [TRT] [I]   Calibrated batch 39 in 0.089812 seconds.Calibrating image 328 / 400
[06/24/2026-06:52:18] [TRT] [I]   Calibrated batch 40 in 0.0904792 seconds.Calibrating image 336 / 400
[06/24/2026-06:52:18] [TRT] [I]   Calibrated batch 41 in 0.0898385 seconds.Calibrating image 344 / 400
[06/24/2026-06:52:18] [TRT] [I]   Calibrated batch 42 in 0.0911815 seconds.Calibrating image 352 / 400
[06/24/2026-06:52:18] [TRT] [I]   Calibrated batch 43 in 0.10301 seconds.Calibrating image 360 / 400
[06/24/2026-06:52:18] [TRT] [I]   Calibrated batch 44 in 0.0936118 seconds.Calibrating image 368 / 400
[06/24/2026-06:52:18] [TRT] [I]   Calibrated batch 45 in 0.0902328 seconds.Calibrating image 376 / 400
[06/24/2026-06:52:18] [TRT] [I]   Calibrated batch 46 in 0.0888147 seconds.Calibrating image 384 / 400
[06/24/2026-06:52:19] [TRT] [I]   Calibrated batch 47 in 0.0922852 seconds.Calibrating image 392 / 400
[06/24/2026-06:52:19] [TRT] [I]   Calibrated batch 48 in 0.090562 seconds.Calibrating image 400 / 400
[06/24/2026-06:52:19] [TRT] [I]   Calibrated batch 49 in 0.0912483 seconds.Finished calibration batches
[06/24/2026-06:54:22] [TRT] [I] Writing Calibration Cache for calibrator: TRT-101303-EntropyCalibration2Writing calibration cache data to: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_FP32_b1_V2.1.pth.cache
[06/24/2026-06:57:33] [TRT] [I] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 16 MiB, GPU 200 MiBequiring 17818624 bytes.or any layer consuming or producing given tensoroducing given tensororn tensorEngine build finished successfully.
Gen_trt_engine finished successfully.
2026-06-24 06:57:34,596 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - Telemetry data couldn't be sent, but the command ran successfully.
2026-06-24 06:57:34,596 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - 'str' object has no attribute 'decode'
2026-06-24 12:27:35,044 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 381: Stopping container.
Engine Evaluation:
Command:
    evaluate.trt_engine=/workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_int8_b1_V2.1.pth.engine
Config:
dataset:
  test_data_sources:
  num_classes: 4
  batch_size: 1  # Batch size for evaluation
evaluate:
  conf_threshold: 0.3
  input_width: 576
  input_height: 352
Output:
2026-06-24 12:28:34,661 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2026-06-24 12:28:34,741 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 360: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:6.26.3-deploy
2026-06-24 12:28:34,764 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 303:
terminal.
2026-06-24 12:28:34,764 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 316: Printing tty value True
2026-06-24 06:58:36,388 - nvidia_tao_core.microservices.utils.job_utils.workflow - INFO - Logging configured at level: INFO
2026-06-24 06:58:38,856 - nvidia_tao_core.microservices.utils.job_utils.workflow - INFO - Logging configured at level: INFO
sys:1: UserWarning:
'eval_engine.yaml' is validated against ConfigStore schema with the same name.
  _run_hydra(
  ret = run_job(
Trt_evaluate results will be saved at: /workspace/tao-experiments/results/trt_evaluation/trt_evaluate
Log file already exists at /workspace/tao-experiments/results/trt_evaluation/trt_evaluate/status.json
Starting rtdetr trt_evaluate.
loading annotations into memory...
Done (t=0.48s)
creating index...
index created!
Done (t=0.33s)
creating index...
index created!
Producing predictions: 100%|██████████| 17359/17359 [03:08<00:00, 91.95it/s]]Loading and preparing results...
0/5207700
1000/5207700
2000/5207700
3000/5207700
4000/5207700
5000/5207700
6000/5207700
7000/5207700
8000/5207700
9000/5207700
10000/5207700
11000/5207700
12000/5207700
13000/5207700
14000/5207700
15000/5207700
16000/5207700
17000/5207700
18000/5207700
19000/5207700
20000/5207700
21000/5207700
22000/5207700
23000/5207700
24000/5207700
25000/5207700
26000/5207700
27000/5207700
28000/5207700
29000/5207700
30000/5207700
31000/5207700
32000/5207700
33000/5207700
34000/5207700
35000/5207700
36000/5207700
37000/5207700
38000/5207700
39000/5207700
40000/5207700
41000/5207700
42000/5207700
43000/5207700
44000/5207700
45000/5207700
46000/5207700
47000/5207700
48000/5207700
49000/5207700
50000/5207700
51000/5207700
52000/5207700
53000/5207700
54000/5207700
55000/5207700
56000/5207700
57000/5207700
58000/5207700
59000/5207700
60000/5207700
61000/5207700
62000/5207700
63000/5207700
64000/5207700
65000/5207700
66000/5207700
67000/5207700
68000/5207700
69000/5207700
70000/5207700
71000/5207700
72000/5207700
73000/5207700
74000/5207700
75000/5207700
76000/5207700
77000/5207700
78000/5207700
79000/5207700
80000/5207700
81000/5207700
82000/5207700
83000/5207700
84000/5207700
85000/5207700
86000/5207700
87000/5207700
88000/5207700
89000/5207700
90000/5207700
91000/5207700
92000/5207700
93000/5207700
94000/5207700
95000/5207700
96000/5207700
97000/5207700
98000/5207700
99000/5207700
100000/5207700
101000/5207700
102000/5207700
103000/5207700
104000/5207700
105000/5207700
106000/5207700
107000/5207700
108000/5207700
109000/5207700
110000/5207700
111000/5207700
112000/5207700
113000/5207700
114000/5207700
115000/5207700
116000/5207700
117000/5207700
118000/5207700
119000/5207700
120000/5207700
121000/5207700
122000/5207700
123000/5207700
124000/5207700
125000/5207700
126000/5207700
127000/5207700
128000/5207700
129000/5207700
130000/5207700
131000/5207700
132000/5207700
133000/5207700
134000/5207700
135000/5207700
136000/5207700
137000/5207700
138000/5207700
139000/5207700
140000/5207700
141000/5207700
142000/5207700
143000/5207700
144000/5207700
145000/5207700
146000/5207700
147000/5207700
148000/5207700
149000/5207700
150000/5207700
151000/5207700
152000/5207700
153000/5207700
154000/5207700
155000/5207700
156000/5207700
157000/5207700
158000/5207700
159000/5207700
160000/5207700
161000/5207700
162000/5207700
163000/5207700
164000/5207700
165000/5207700
166000/5207700
167000/5207700
168000/5207700
169000/5207700
170000/5207700
171000/5207700
172000/5207700
173000/5207700
174000/5207700
175000/5207700
176000/5207700
177000/5207700
178000/5207700
179000/5207700
180000/5207700
181000/5207700
182000/5207700
183000/5207700
184000/5207700
185000/5207700
186000/5207700
187000/5207700
188000/5207700
189000/5207700
190000/5207700
191000/5207700
192000/5207700
193000/5207700
194000/5207700
195000/5207700
196000/5207700
197000/5207700
198000/5207700
199000/5207700
200000/5207700
201000/5207700
202000/5207700
203000/5207700
204000/5207700
205000/5207700
206000/5207700
207000/5207700
208000/5207700
209000/5207700
210000/5207700
211000/5207700
212000/5207700
213000/5207700
214000/5207700
215000/5207700
216000/5207700
217000/5207700
218000/5207700
219000/5207700
220000/5207700
221000/5207700
222000/5207700
223000/5207700
224000/5207700
225000/5207700
226000/5207700
227000/5207700
228000/5207700
229000/5207700
230000/5207700
231000/5207700
232000/5207700
233000/5207700
234000/5207700
235000/5207700
236000/5207700
237000/5207700
238000/5207700
239000/5207700
240000/5207700
241000/5207700
242000/5207700
243000/5207700
244000/5207700
245000/5207700
246000/5207700
247000/5207700
248000/5207700
249000/5207700
250000/5207700
251000/5207700
252000/5207700
253000/5207700
254000/5207700
255000/5207700
256000/5207700
257000/5207700
258000/5207700
259000/5207700
260000/5207700
261000/5207700
262000/5207700
263000/5207700
264000/5207700
265000/5207700
266000/5207700
267000/5207700
268000/5207700
269000/5207700
270000/5207700
271000/5207700
272000/5207700
273000/5207700
274000/5207700
275000/5207700
276000/5207700
277000/5207700
278000/5207700
279000/5207700
280000/5207700
281000/5207700
282000/5207700
283000/5207700
284000/5207700
285000/5207700
286000/5207700
287000/5207700
288000/5207700
289000/5207700
290000/5207700
291000/5207700
292000/5207700
293000/5207700
294000/5207700
295000/5207700
296000/5207700
297000/5207700
298000/5207700
299000/5207700
300000/5207700
301000/5207700
302000/5207700
303000/5207700
304000/5207700
305000/5207700
306000/5207700
307000/5207700
308000/5207700
309000/5207700
310000/5207700
311000/5207700
312000/5207700
313000/5207700
314000/5207700
315000/5207700
316000/5207700
317000/5207700
318000/5207700
319000/5207700
320000/5207700
321000/5207700
322000/5207700
323000/5207700
324000/5207700
325000/5207700
326000/5207700
327000/5207700
328000/5207700
329000/5207700
330000/5207700
331000/5207700
332000/5207700
333000/5207700
334000/5207700
335000/5207700
336000/5207700
337000/5207700
338000/5207700
339000/5207700
340000/5207700
341000/5207700
342000/5207700
343000/5207700
344000/5207700
345000/5207700
346000/5207700
347000/5207700
348000/5207700
349000/5207700
350000/5207700
351000/5207700
352000/5207700
353000/5207700
354000/5207700
355000/5207700
356000/5207700
357000/5207700
358000/5207700
359000/5207700
360000/5207700
361000/5207700
362000/5207700
363000/5207700
364000/5207700
365000/5207700
366000/5207700
367000/5207700
368000/5207700
369000/5207700
370000/5207700
371000/5207700
372000/5207700
373000/5207700
374000/5207700
375000/5207700
376000/5207700
377000/5207700
378000/5207700
379000/5207700
380000/5207700
381000/5207700
382000/5207700
383000/5207700
384000/5207700
385000/5207700
386000/5207700
387000/5207700
388000/5207700
389000/5207700
390000/5207700
391000/5207700
392000/5207700
393000/5207700
394000/5207700
395000/5207700
396000/5207700
397000/5207700
398000/5207700
399000/5207700
400000/5207700
401000/5207700
402000/5207700
403000/5207700
404000/5207700
405000/5207700
406000/5207700
407000/5207700
408000/5207700
409000/5207700
410000/5207700
411000/5207700
412000/5207700
413000/5207700
414000/5207700
415000/5207700
416000/5207700
417000/5207700
418000/5207700
419000/5207700
420000/5207700
421000/5207700
422000/5207700
423000/5207700
424000/5207700
425000/5207700
426000/5207700
427000/5207700
428000/5207700
429000/5207700
430000/5207700
431000/5207700
432000/5207700
433000/5207700
434000/5207700
435000/5207700
436000/5207700
437000/5207700
438000/5207700
439000/5207700
440000/5207700
441000/5207700
442000/5207700
443000/5207700
444000/5207700
445000/5207700
446000/5207700
447000/5207700
448000/5207700
449000/5207700
450000/5207700
451000/5207700
452000/5207700
453000/5207700
454000/5207700
455000/5207700
456000/5207700
457000/5207700
458000/5207700
459000/5207700
460000/5207700
461000/5207700
462000/5207700
463000/5207700
464000/5207700
465000/5207700
466000/5207700
467000/5207700
468000/5207700
469000/5207700
470000/5207700
471000/5207700
472000/5207700
473000/5207700
474000/5207700
475000/5207700
476000/5207700
477000/5207700
478000/5207700
479000/5207700
480000/5207700
481000/5207700
482000/5207700
483000/5207700
484000/5207700
485000/5207700
486000/5207700
487000/5207700
488000/5207700
489000/5207700
490000/5207700
491000/5207700
492000/5207700
493000/5207700
494000/5207700
495000/5207700
496000/5207700
497000/5207700
498000/5207700
499000/5207700
500000/5207700
501000/5207700
502000/5207700
503000/5207700
504000/5207700
505000/5207700
506000/5207700
507000/5207700
508000/5207700
509000/5207700
510000/5207700
511000/5207700
512000/5207700
513000/5207700
514000/5207700
515000/5207700
516000/5207700
517000/5207700
518000/5207700
519000/5207700
520000/5207700
521000/5207700
522000/5207700
523000/5207700
524000/5207700
525000/5207700
526000/5207700
527000/5207700
528000/5207700
529000/5207700
530000/5207700
531000/5207700
532000/5207700
533000/5207700
534000/5207700
535000/5207700
536000/5207700
537000/5207700
538000/5207700
539000/5207700
540000/5207700
541000/5207700
542000/5207700
543000/5207700
544000/5207700
545000/5207700
546000/5207700
547000/5207700
548000/5207700
549000/5207700
550000/5207700
551000/5207700
552000/5207700
553000/5207700
554000/5207700
555000/5207700
556000/5207700
557000/5207700
558000/5207700
559000/5207700
560000/5207700
561000/5207700
562000/5207700
563000/5207700
564000/5207700
565000/5207700
566000/5207700
567000/5207700
568000/5207700
569000/5207700
570000/5207700
571000/5207700
572000/5207700
573000/5207700
574000/5207700
575000/5207700
576000/5207700
577000/5207700
578000/5207700
579000/5207700
580000/5207700
581000/5207700
582000/5207700
583000/5207700
584000/5207700
585000/5207700
586000/5207700
587000/5207700
588000/5207700
589000/5207700
590000/5207700
591000/5207700
592000/5207700
593000/5207700
594000/5207700
595000/5207700
596000/5207700
597000/5207700
598000/5207700
599000/5207700
600000/5207700
601000/5207700
602000/5207700
603000/5207700
604000/5207700
605000/5207700
606000/5207700
607000/5207700
608000/5207700
609000/5207700
610000/5207700
611000/5207700
612000/5207700
613000/5207700
614000/5207700
615000/5207700
616000/5207700
617000/5207700
618000/5207700
619000/5207700
620000/5207700
621000/5207700
622000/5207700
623000/5207700
624000/5207700
625000/5207700
626000/5207700
627000/5207700
628000/5207700
629000/5207700
630000/5207700
631000/5207700
632000/5207700
633000/5207700
634000/5207700
635000/5207700
636000/5207700
637000/5207700
638000/5207700
639000/5207700
640000/5207700
641000/5207700
642000/5207700
643000/5207700
644000/5207700
645000/5207700
646000/5207700
647000/5207700
648000/5207700
649000/5207700
650000/5207700
651000/5207700
652000/5207700
653000/5207700
654000/5207700
655000/5207700
656000/5207700
657000/5207700
658000/5207700
659000/5207700
660000/5207700
661000/5207700
662000/5207700
663000/5207700
664000/5207700
665000/5207700
666000/5207700
667000/5207700
668000/5207700
669000/5207700
670000/5207700
671000/5207700
672000/5207700
673000/5207700
674000/5207700
675000/5207700
676000/5207700
677000/5207700
678000/5207700
679000/5207700
680000/5207700
681000/5207700
682000/5207700
683000/5207700
684000/5207700
685000/5207700
686000/5207700
687000/5207700
688000/5207700
689000/5207700
690000/5207700
691000/5207700
692000/5207700
693000/5207700
694000/5207700
695000/5207700
696000/5207700
697000/5207700
698000/5207700
699000/5207700
700000/5207700
701000/5207700
702000/5207700
703000/5207700
704000/5207700
705000/5207700
706000/5207700
707000/5207700
708000/5207700
709000/5207700
710000/5207700
711000/5207700
712000/5207700
713000/5207700
714000/5207700
715000/5207700
716000/5207700
717000/5207700
718000/5207700
719000/5207700
720000/5207700
721000/5207700
722000/5207700
723000/5207700
724000/5207700
725000/5207700
726000/5207700
727000/5207700
728000/5207700
729000/5207700
730000/5207700
731000/5207700
732000/5207700
733000/5207700
734000/5207700
735000/5207700
736000/5207700
737000/5207700
738000/5207700
739000/5207700
740000/5207700
741000/5207700
742000/5207700
743000/5207700
744000/5207700
745000/5207700
746000/5207700
747000/5207700
748000/5207700
749000/5207700
750000/5207700
751000/5207700
752000/5207700
753000/5207700
754000/5207700
755000/5207700
756000/5207700
757000/5207700
758000/5207700
759000/5207700
760000/5207700
761000/5207700
762000/5207700
763000/5207700
764000/5207700
765000/5207700
766000/5207700
767000/5207700
768000/5207700
769000/5207700
770000/5207700
771000/5207700
772000/5207700
773000/5207700
774000/5207700
775000/5207700
776000/5207700
777000/5207700
778000/5207700
779000/5207700
780000/5207700
781000/5207700
782000/5207700
783000/5207700
784000/5207700
785000/5207700
786000/5207700
787000/5207700
788000/5207700
789000/5207700
790000/5207700
791000/5207700
792000/5207700
793000/5207700
794000/5207700
795000/5207700
796000/5207700
797000/5207700
798000/5207700
799000/5207700
800000/5207700
801000/5207700
802000/5207700
803000/5207700
804000/5207700
805000/5207700
806000/5207700
807000/5207700
808000/5207700
809000/5207700
810000/5207700
811000/5207700
812000/5207700
813000/5207700
814000/5207700
815000/5207700
816000/5207700
817000/5207700
818000/5207700
819000/5207700
820000/5207700
821000/5207700
822000/5207700
823000/5207700
824000/5207700
825000/5207700
826000/5207700
827000/5207700
828000/5207700
829000/5207700
830000/5207700
831000/5207700
832000/5207700
833000/5207700
834000/5207700
835000/5207700
836000/5207700
837000/5207700
838000/5207700
839000/5207700
840000/5207700
841000/5207700
842000/5207700
843000/5207700
844000/5207700
845000/5207700
846000/5207700
847000/5207700
848000/5207700
849000/5207700
850000/5207700
851000/5207700
852000/5207700
853000/5207700
854000/5207700
855000/5207700
856000/5207700
857000/5207700
858000/5207700
859000/5207700
860000/5207700
861000/5207700
862000/5207700
863000/5207700
864000/5207700
865000/5207700
866000/5207700
867000/5207700
868000/5207700
869000/5207700
870000/5207700
871000/5207700
872000/5207700
873000/5207700
874000/5207700
875000/5207700
876000/5207700
877000/5207700
878000/5207700
879000/5207700
880000/5207700
881000/5207700
882000/5207700
883000/5207700
884000/5207700
885000/5207700
886000/5207700
887000/5207700
888000/5207700
889000/5207700
890000/5207700
891000/5207700
892000/5207700
893000/5207700
894000/5207700
895000/5207700
896000/5207700
897000/5207700
898000/5207700
899000/5207700
900000/5207700
901000/5207700
902000/5207700
903000/5207700
904000/5207700
905000/5207700
906000/5207700
907000/5207700
908000/5207700
909000/5207700
910000/5207700
911000/5207700
912000/5207700
913000/5207700
914000/5207700
915000/5207700
916000/5207700
917000/5207700
918000/5207700
919000/5207700
920000/5207700
921000/5207700
922000/5207700
923000/5207700
924000/5207700
925000/5207700
926000/5207700
927000/5207700
928000/5207700
929000/5207700
930000/5207700
931000/5207700
932000/5207700
933000/5207700
934000/5207700
935000/5207700
936000/5207700
937000/5207700
938000/5207700
939000/5207700
940000/5207700
941000/5207700
942000/5207700
943000/5207700
944000/5207700
945000/5207700
946000/5207700
947000/5207700
948000/5207700
949000/5207700
950000/5207700
951000/5207700
952000/5207700
953000/5207700
954000/5207700
955000/5207700
956000/5207700
957000/5207700
958000/5207700
959000/5207700
960000/5207700
961000/5207700
962000/5207700
963000/5207700
964000/5207700
965000/5207700
966000/5207700
967000/5207700
968000/5207700
969000/5207700
970000/5207700
971000/5207700
972000/5207700
973000/5207700
974000/5207700
975000/5207700
976000/5207700
977000/5207700
978000/5207700
979000/5207700
980000/5207700
981000/5207700
982000/5207700
983000/5207700
984000/5207700
985000/5207700
986000/5207700
987000/5207700
988000/5207700
989000/5207700
990000/5207700
991000/5207700
992000/5207700
993000/5207700
994000/5207700
995000/5207700
996000/5207700
997000/5207700
998000/5207700
999000/5207700
1000000/5207700
1001000/5207700
1002000/5207700
1003000/5207700
1004000/5207700
1005000/5207700
1006000/5207700
1007000/5207700
1008000/5207700
1009000/5207700
1010000/5207700
1011000/5207700
1012000/5207700
1013000/5207700
1014000/5207700
1015000/5207700
1016000/5207700
1017000/5207700
1018000/5207700
1019000/5207700
1020000/5207700
1021000/5207700
1022000/5207700
1023000/5207700
1024000/5207700
1025000/5207700
1026000/5207700
1027000/5207700
1028000/5207700
1029000/5207700
1030000/5207700
1031000/5207700
1032000/5207700
1033000/5207700
1034000/5207700
1035000/5207700
1036000/5207700
1037000/5207700
1038000/5207700
1039000/5207700
1040000/5207700
1041000/5207700
1042000/5207700
1043000/5207700
1044000/5207700
1045000/5207700
1046000/5207700
1047000/5207700
1048000/5207700
1049000/5207700
1050000/5207700
1051000/5207700
1052000/5207700
1053000/5207700
1054000/5207700
1055000/5207700
1056000/5207700
1057000/5207700
1058000/5207700
1059000/5207700
1060000/5207700
1061000/5207700
1062000/5207700
1063000/5207700
1064000/5207700
1065000/5207700
1066000/5207700
1067000/5207700
1068000/5207700
1069000/5207700
1070000/5207700
1071000/5207700
1072000/5207700
1073000/5207700
1074000/5207700
1075000/5207700
1076000/5207700
1077000/5207700
1078000/5207700
1079000/5207700
1080000/5207700
1081000/5207700
1082000/5207700
1083000/5207700
1084000/5207700
1085000/5207700
1086000/5207700
1087000/5207700
1088000/5207700
1089000/5207700
1090000/5207700
1091000/5207700
1092000/5207700
1093000/5207700
1094000/5207700
1095000/5207700
1096000/5207700
1097000/5207700
1098000/5207700
1099000/5207700
1100000/5207700
1101000/5207700
1102000/5207700
1103000/5207700
1104000/5207700
1105000/5207700
1106000/5207700
1107000/5207700
1108000/5207700
1109000/5207700
1110000/5207700
1111000/5207700
1112000/5207700
1113000/5207700
1114000/5207700
1115000/5207700
1116000/5207700
1117000/5207700
1118000/5207700
1119000/5207700
1120000/5207700
1121000/5207700
1122000/5207700
1123000/5207700
1124000/5207700
1125000/5207700
1126000/5207700
1127000/5207700
1128000/5207700
1129000/5207700
1130000/5207700
1131000/5207700
1132000/5207700
1133000/5207700
1134000/5207700
1135000/5207700
1136000/5207700
1137000/5207700
1138000/5207700
1139000/5207700
1140000/5207700
1141000/5207700
1142000/5207700
1143000/5207700
1144000/5207700
1145000/5207700
1146000/5207700
1147000/5207700
1148000/5207700
1149000/5207700
1150000/5207700
1151000/5207700
1152000/5207700
1153000/5207700
1154000/5207700
1155000/5207700
1156000/5207700
1157000/5207700
1158000/5207700
1159000/5207700
1160000/5207700
1161000/5207700
1162000/5207700
1163000/5207700
1164000/5207700
1165000/5207700
1166000/5207700
1167000/5207700
1168000/5207700
1169000/5207700
1170000/5207700
1171000/5207700
1172000/5207700
1173000/5207700
1174000/5207700
1175000/5207700
1176000/5207700
1177000/5207700
1178000/5207700
1179000/5207700
1180000/5207700
1181000/5207700
1182000/5207700
1183000/5207700
1184000/5207700
1185000/5207700
1186000/5207700
1187000/5207700
1188000/5207700
1189000/5207700
1190000/5207700
1191000/5207700
1192000/5207700
1193000/5207700
1194000/5207700
1195000/5207700
1196000/5207700
1197000/5207700
1198000/5207700
1199000/5207700
1200000/5207700
1201000/5207700
1202000/5207700
1203000/5207700
1204000/5207700
1205000/5207700
1206000/5207700
1207000/5207700
1208000/5207700
1209000/5207700
1210000/5207700
1211000/5207700
1212000/5207700
1213000/5207700
1214000/5207700
1215000/5207700
1216000/5207700
1217000/5207700
1218000/5207700
1219000/5207700
1220000/5207700
1221000/5207700
1222000/5207700
1223000/5207700
1224000/5207700
1225000/5207700
1226000/5207700
1227000/5207700
1228000/5207700
1229000/5207700
1230000/5207700
1231000/5207700
1232000/5207700
1233000/5207700
1234000/5207700
1235000/5207700
1236000/5207700
1237000/5207700
1238000/5207700
1239000/5207700
1240000/5207700
1241000/5207700
1242000/5207700
1243000/5207700
1244000/5207700
1245000/5207700
1246000/5207700
1247000/5207700
1248000/5207700
1249000/5207700
1250000/5207700
1251000/5207700
1252000/5207700
1253000/5207700
1254000/5207700
1255000/5207700
1256000/5207700
1257000/5207700
1258000/5207700
1259000/5207700
1260000/5207700
1261000/5207700
1262000/5207700
1263000/5207700
1264000/5207700
1265000/5207700
1266000/5207700
1267000/5207700
1268000/5207700
1269000/5207700
1270000/5207700
1271000/5207700
1272000/5207700
1273000/5207700
1274000/5207700
1275000/5207700
1276000/5207700
1277000/5207700
1278000/5207700
1279000/5207700
1280000/5207700
1281000/5207700
1282000/5207700
1283000/5207700
1284000/5207700
1285000/5207700
1286000/5207700
1287000/5207700
1288000/5207700
1289000/5207700
1290000/5207700
1291000/5207700
1292000/5207700
1293000/5207700
1294000/5207700
1295000/5207700
1296000/5207700
1297000/5207700
1298000/5207700
1299000/5207700
1300000/5207700
1301000/5207700
1302000/5207700
1303000/5207700
1304000/5207700
1305000/5207700
1306000/5207700
1307000/5207700
1308000/5207700
1309000/5207700
1310000/5207700
1311000/5207700
1312000/5207700
1313000/5207700
1314000/5207700
1315000/5207700
1316000/5207700
1317000/5207700
1318000/5207700
1319000/5207700
1320000/5207700
1321000/5207700
1322000/5207700
1323000/5207700
1324000/5207700
1325000/5207700
1326000/5207700
1327000/5207700
1328000/5207700
1329000/5207700
1330000/5207700
1331000/5207700
1332000/5207700
1333000/5207700
1334000/5207700
1335000/5207700
1336000/5207700
1337000/5207700
1338000/5207700
1339000/5207700
1340000/5207700
1341000/5207700
1342000/5207700
1343000/5207700
1344000/5207700
1345000/5207700
1346000/5207700
1347000/5207700
1348000/5207700
1349000/5207700
1350000/5207700
1351000/5207700
1352000/5207700
1353000/5207700
1354000/5207700
1355000/5207700
1356000/5207700
1357000/5207700
1358000/5207700
1359000/5207700
1360000/5207700
1361000/5207700
1362000/5207700
1363000/5207700
1364000/5207700
1365000/5207700
1366000/5207700
1367000/5207700
1368000/5207700
1369000/5207700
1370000/5207700
1371000/5207700
1372000/5207700
1373000/5207700
1374000/5207700
1375000/5207700
1376000/5207700
1377000/5207700
1378000/5207700
1379000/5207700
1380000/5207700
1381000/5207700
1382000/5207700
1383000/5207700
1384000/5207700
1385000/5207700
1386000/5207700
1387000/5207700
1388000/5207700
1389000/5207700
1390000/5207700
1391000/5207700
1392000/5207700
1393000/5207700
1394000/5207700
1395000/5207700
1396000/5207700
1397000/5207700
1398000/5207700
1399000/5207700
1400000/5207700
1401000/5207700
1402000/5207700
1403000/5207700
1404000/5207700
1405000/5207700
1406000/5207700
1407000/5207700
1408000/5207700
1409000/5207700
1410000/5207700
1411000/5207700
1412000/5207700
1413000/5207700
1414000/5207700
1415000/5207700
1416000/5207700
1417000/5207700
1418000/5207700
1419000/5207700
1420000/5207700
1421000/5207700
1422000/5207700
1423000/5207700
1424000/5207700
1425000/5207700
1426000/5207700
1427000/5207700
1428000/5207700
1429000/5207700
1430000/5207700
1431000/5207700
1432000/5207700
1433000/5207700
1434000/5207700
1435000/5207700
1436000/5207700
1437000/5207700
1438000/5207700
1439000/5207700
1440000/5207700
1441000/5207700
1442000/5207700
1443000/5207700
1444000/5207700
1445000/5207700
1446000/5207700
1447000/5207700
1448000/5207700
1449000/5207700
1450000/5207700
1451000/5207700
1452000/5207700
1453000/5207700
1454000/5207700
1455000/5207700
1456000/5207700
1457000/5207700
1458000/5207700
1459000/5207700
1460000/5207700
1461000/5207700
1462000/5207700
1463000/5207700
1464000/5207700
1465000/5207700
1466000/5207700
1467000/5207700
1468000/5207700
1469000/5207700
1470000/5207700
1471000/5207700
1472000/5207700
1473000/5207700
1474000/5207700
1475000/5207700
1476000/5207700
1477000/5207700
1478000/5207700
1479000/5207700
1480000/5207700
1481000/5207700
1482000/5207700
1483000/5207700
1484000/5207700
1485000/5207700
1486000/5207700
1487000/5207700
1488000/5207700
1489000/5207700
1490000/5207700
1491000/5207700
1492000/5207700
1493000/5207700
1494000/5207700
1495000/5207700
1496000/5207700
1497000/5207700
1498000/5207700
1499000/5207700
1500000/5207700
1501000/5207700
1502000/5207700
1503000/5207700
1504000/5207700
1505000/5207700
1506000/5207700
1507000/5207700
1508000/5207700
1509000/5207700
1510000/5207700
1511000/5207700
1512000/5207700
1513000/5207700
1514000/5207700
1515000/5207700
1516000/5207700
1517000/5207700
1518000/5207700
1519000/5207700
1520000/5207700
1521000/5207700
1522000/5207700
1523000/5207700
1524000/5207700
1525000/5207700
1526000/5207700
1527000/5207700
1528000/5207700
1529000/5207700
1530000/5207700
1531000/5207700
1532000/5207700
1533000/5207700
1534000/5207700
1535000/5207700
1536000/5207700
1537000/5207700
1538000/5207700
1539000/5207700
1540000/5207700
1541000/5207700
1542000/5207700
1543000/5207700
1544000/5207700
1545000/5207700
1546000/5207700
1547000/5207700
1548000/5207700
1549000/5207700
1550000/5207700
1551000/5207700
1552000/5207700
1553000/5207700
1554000/5207700
1555000/5207700
1556000/5207700
1557000/5207700
1558000/5207700
1559000/5207700
1560000/5207700
1561000/5207700
1562000/5207700
1563000/5207700
1564000/5207700
1565000/5207700
1566000/5207700
1567000/5207700
1568000/5207700
1569000/5207700
1570000/5207700
1571000/5207700
1572000/5207700
1573000/5207700
1574000/5207700
1575000/5207700
1576000/5207700
1577000/5207700
1578000/5207700
1579000/5207700
1580000/5207700
1581000/5207700
1582000/5207700
1583000/5207700
1584000/5207700
1585000/5207700
1586000/5207700
1587000/5207700
1588000/5207700
1589000/5207700
1590000/5207700
1591000/5207700
1592000/5207700
1593000/5207700
1594000/5207700
1595000/5207700
1596000/5207700
1597000/5207700
1598000/5207700
1599000/5207700
1600000/5207700
1601000/5207700
1602000/5207700
1603000/5207700
1604000/5207700
1605000/5207700
1606000/5207700
1607000/5207700
1608000/5207700
1609000/5207700
1610000/5207700
1611000/5207700
1612000/5207700
1613000/5207700
1614000/5207700
1615000/5207700
1616000/5207700
1617000/5207700
1618000/5207700
1619000/5207700
1620000/5207700
1621000/5207700
1622000/5207700
1623000/5207700
1624000/5207700
1625000/5207700
1626000/5207700
1627000/5207700
1628000/5207700
1629000/5207700
1630000/5207700
1631000/5207700
1632000/5207700
1633000/5207700
1634000/5207700
1635000/5207700
1636000/5207700
1637000/5207700
1638000/5207700
1639000/5207700
1640000/5207700
1641000/5207700
1642000/5207700
1643000/5207700
1644000/5207700
1645000/5207700
1646000/5207700
1647000/5207700
1648000/5207700
1649000/5207700
1650000/5207700
1651000/5207700
1652000/5207700
1653000/5207700
1654000/5207700
1655000/5207700
1656000/5207700
1657000/5207700
1658000/5207700
1659000/5207700
1660000/5207700
1661000/5207700
1662000/5207700
1663000/5207700
1664000/5207700
1665000/5207700
1666000/5207700
1667000/5207700
1668000/5207700
1669000/5207700
1670000/5207700
1671000/5207700
1672000/5207700
1673000/5207700
1674000/5207700
1675000/5207700
1676000/5207700
1677000/5207700
1678000/5207700
1679000/5207700
1680000/5207700
1681000/5207700
1682000/5207700
1683000/5207700
1684000/5207700
1685000/5207700
1686000/5207700
1687000/5207700
1688000/5207700
1689000/5207700
1690000/5207700
1691000/5207700
1692000/5207700
1693000/5207700
1694000/5207700
1695000/5207700
1696000/5207700
1697000/5207700
1698000/5207700
1699000/5207700
1700000/5207700
1701000/5207700
1702000/5207700
1703000/5207700
1704000/5207700
1705000/5207700
1706000/5207700
1707000/5207700
1708000/5207700
1709000/5207700
1710000/5207700
1711000/5207700
1712000/5207700
1713000/5207700
1714000/5207700
1715000/5207700
1716000/5207700
1717000/5207700
1718000/5207700
1719000/5207700
1720000/5207700
1721000/5207700
1722000/5207700
1723000/5207700
1724000/5207700
1725000/5207700
1726000/5207700
1727000/5207700
1728000/5207700
1729000/5207700
1730000/5207700
1731000/5207700
1732000/5207700
1733000/5207700
1734000/5207700
1735000/5207700
1736000/5207700
1737000/5207700
1738000/5207700
1739000/5207700
1740000/5207700
1741000/5207700
1742000/5207700
1743000/5207700
1744000/5207700
1745000/5207700
1746000/5207700
1747000/5207700
1748000/5207700
1749000/5207700
1750000/5207700
1751000/5207700
1752000/5207700
1753000/5207700
1754000/5207700
1755000/5207700
1756000/5207700
1757000/5207700
1758000/5207700
1759000/5207700
1760000/5207700
1761000/5207700
1762000/5207700
1763000/5207700
1764000/5207700
1765000/5207700
1766000/5207700
1767000/5207700
1768000/5207700
1769000/5207700
1770000/5207700
1771000/5207700
1772000/5207700
1773000/5207700
1774000/5207700
1775000/5207700
1776000/5207700
1777000/5207700
1778000/5207700
1779000/5207700
1780000/5207700
1781000/5207700
1782000/5207700
1783000/5207700
1784000/5207700
1785000/5207700
1786000/5207700
1787000/5207700
1788000/5207700
1789000/5207700
1790000/5207700
1791000/5207700
1792000/5207700
1793000/5207700
1794000/5207700
1795000/5207700
1796000/5207700
1797000/5207700
1798000/5207700
1799000/5207700
1800000/5207700
1801000/5207700
1802000/5207700
1803000/5207700
1804000/5207700
1805000/5207700
1806000/5207700
1807000/5207700
1808000/5207700
1809000/5207700
1810000/5207700
1811000/5207700
1812000/5207700
1813000/5207700
1814000/5207700
1815000/5207700
1816000/5207700
1817000/5207700
1818000/5207700
1819000/5207700
1820000/5207700
1821000/5207700
1822000/5207700
1823000/5207700
1824000/5207700
1825000/5207700
1826000/5207700
1827000/5207700
1828000/5207700
1829000/5207700
1830000/5207700
1831000/5207700
1832000/5207700
1833000/5207700
1834000/5207700
1835000/5207700
1836000/5207700
1837000/5207700
1838000/5207700
1839000/5207700
1840000/5207700
1841000/5207700
1842000/5207700
1843000/5207700
1844000/5207700
1845000/5207700
1846000/5207700
1847000/5207700
1848000/5207700
1849000/5207700
1850000/5207700
1851000/5207700
1852000/5207700
1853000/5207700
1854000/5207700
1855000/5207700
1856000/5207700
1857000/5207700
1858000/5207700
1859000/5207700
1860000/5207700
1861000/5207700
1862000/5207700
1863000/5207700
1864000/5207700
1865000/5207700
1866000/5207700
1867000/5207700
1868000/5207700
1869000/5207700
1870000/5207700
1871000/5207700
1872000/5207700
1873000/5207700
1874000/5207700
1875000/5207700
1876000/5207700
1877000/5207700
1878000/5207700
1879000/5207700
1880000/5207700
1881000/5207700
1882000/5207700
1883000/5207700
1884000/5207700
1885000/5207700
1886000/5207700
1887000/5207700
1888000/5207700
1889000/5207700
1890000/5207700
1891000/5207700
1892000/5207700
1893000/5207700
1894000/5207700
1895000/5207700
1896000/5207700
1897000/5207700
1898000/5207700
1899000/5207700
1900000/5207700
1901000/5207700
1902000/5207700
1903000/5207700
1904000/5207700
1905000/5207700
1906000/5207700
1907000/5207700
1908000/5207700
1909000/5207700
1910000/5207700
1911000/5207700
1912000/5207700
1913000/5207700
1914000/5207700
1915000/5207700
1916000/5207700
1917000/5207700
1918000/5207700
1919000/5207700
1920000/5207700
1921000/5207700
1922000/5207700
1923000/5207700
1924000/5207700
1925000/5207700
1926000/5207700
1927000/5207700
1928000/5207700
1929000/5207700
1930000/5207700
1931000/5207700
1932000/5207700
1933000/5207700
1934000/5207700
1935000/5207700
1936000/5207700
1937000/5207700
1938000/5207700
1939000/5207700
1940000/5207700
1941000/5207700
1942000/5207700
1943000/5207700
1944000/5207700
1945000/5207700
1946000/5207700
1947000/5207700
1948000/5207700
1949000/5207700
1950000/5207700
1951000/5207700
1952000/5207700
1953000/5207700
1954000/5207700
1955000/5207700
1956000/5207700
1957000/5207700
1958000/5207700
1959000/5207700
1960000/5207700
1961000/5207700
1962000/5207700
1963000/5207700
1964000/5207700
1965000/5207700
1966000/5207700
1967000/5207700
1968000/5207700
1969000/5207700
1970000/5207700
1971000/5207700
1972000/5207700
1973000/5207700
1974000/5207700
1975000/5207700
1976000/5207700
1977000/5207700
1978000/5207700
1979000/5207700
1980000/5207700
1981000/5207700
1982000/5207700
1983000/5207700
1984000/5207700
1985000/5207700
1986000/5207700
1987000/5207700
1988000/5207700
1989000/5207700
1990000/5207700
1991000/5207700
1992000/5207700
1993000/5207700
1994000/5207700
1995000/5207700
1996000/5207700
1997000/5207700
1998000/5207700
1999000/5207700
2000000/5207700
2001000/5207700
2002000/5207700
2003000/5207700
2004000/5207700
2005000/5207700
2006000/5207700
2007000/5207700
2008000/5207700
2009000/5207700
2010000/5207700
2011000/5207700
2012000/5207700
2013000/5207700
2014000/5207700
2015000/5207700
2016000/5207700
2017000/5207700
2018000/5207700
2019000/5207700
2020000/5207700
2021000/5207700
2022000/5207700
2023000/5207700
2024000/5207700
2025000/5207700
2026000/5207700
2027000/5207700
2028000/5207700
2029000/5207700
2030000/5207700
2031000/5207700
2032000/5207700
2033000/5207700
2034000/5207700
2035000/5207700
2036000/5207700
2037000/5207700
2038000/5207700
2039000/5207700
2040000/5207700
2041000/5207700
2042000/5207700
2043000/5207700
2044000/5207700
2045000/5207700
2046000/5207700
2047000/5207700
2048000/5207700
2049000/5207700
2050000/5207700
2051000/5207700
2052000/5207700
2053000/5207700
2054000/5207700
2055000/5207700
2056000/5207700
2057000/5207700
2058000/5207700
2059000/5207700
2060000/5207700
2061000/5207700
2062000/5207700
2063000/5207700
2064000/5207700
2065000/5207700
2066000/5207700
2067000/5207700
2068000/5207700
2069000/5207700
2070000/5207700
2071000/5207700
2072000/5207700
2073000/5207700
2074000/5207700
2075000/5207700
2076000/5207700
2077000/5207700
2078000/5207700
2079000/5207700
2080000/5207700
2081000/5207700
2082000/5207700
2083000/5207700
2084000/5207700
2085000/5207700
2086000/5207700
2087000/5207700
2088000/5207700
2089000/5207700
2090000/5207700
2091000/5207700
2092000/5207700
2093000/5207700
2094000/5207700
2095000/5207700
2096000/5207700
2097000/5207700
2098000/5207700
2099000/5207700
2100000/5207700
2101000/5207700
2102000/5207700
2103000/5207700
2104000/5207700
2105000/5207700
2106000/5207700
2107000/5207700
2108000/5207700
2109000/5207700
2110000/5207700
2111000/5207700
2112000/5207700
2113000/5207700
2114000/5207700
2115000/5207700
2116000/5207700
2117000/5207700
2118000/5207700
2119000/5207700
2120000/5207700
2121000/5207700
2122000/5207700
2123000/5207700
2124000/5207700
2125000/5207700
2126000/5207700
2127000/5207700
2128000/5207700
2129000/5207700
2130000/5207700
2131000/5207700
2132000/5207700
2133000/5207700
2134000/5207700
2135000/5207700
2136000/5207700
2137000/5207700
2138000/5207700
2139000/5207700
2140000/5207700
2141000/5207700
2142000/5207700
2143000/5207700
2144000/5207700
2145000/5207700
2146000/5207700
2147000/5207700
2148000/5207700
2149000/5207700
2150000/5207700
2151000/5207700
2152000/5207700
2153000/5207700
2154000/5207700
2155000/5207700
2156000/5207700
2157000/5207700
2158000/5207700
2159000/5207700
2160000/5207700
2161000/5207700
2162000/5207700
2163000/5207700
2164000/5207700
2165000/5207700
2166000/5207700
2167000/5207700
2168000/5207700
2169000/5207700
2170000/5207700
2171000/5207700
2172000/5207700
2173000/5207700
2174000/5207700
2175000/5207700
2176000/5207700
2177000/5207700
2178000/5207700
2179000/5207700
2180000/5207700
2181000/5207700
2182000/5207700
2183000/5207700
2184000/5207700
2185000/5207700
2186000/5207700
2187000/5207700
2188000/5207700
2189000/5207700
2190000/5207700
2191000/5207700
2192000/5207700
2193000/5207700
2194000/5207700
2195000/5207700
2196000/5207700
2197000/5207700
2198000/5207700
2199000/5207700
2200000/5207700
2201000/5207700
2202000/5207700
2203000/5207700
2204000/5207700
2205000/5207700
2206000/5207700
2207000/5207700
2208000/5207700
2209000/5207700
2210000/5207700
2211000/5207700
2212000/5207700
2213000/5207700
2214000/5207700
2215000/5207700
2216000/5207700
2217000/5207700
2218000/5207700
2219000/5207700
2220000/5207700
2221000/5207700
2222000/5207700
2223000/5207700
2224000/5207700
2225000/5207700
2226000/5207700
2227000/5207700
2228000/5207700
2229000/5207700
2230000/5207700
2231000/5207700
2232000/5207700
2233000/5207700
2234000/5207700
2235000/5207700
2236000/5207700
2237000/5207700
2238000/5207700
2239000/5207700
2240000/5207700
2241000/5207700
2242000/5207700
2243000/5207700
2244000/5207700
2245000/5207700
2246000/5207700
2247000/5207700
2248000/5207700
2249000/5207700
2250000/5207700
2251000/5207700
2252000/5207700
2253000/5207700
2254000/5207700
2255000/5207700
2256000/5207700
2257000/5207700
2258000/5207700
2259000/5207700
2260000/5207700
2261000/5207700
2262000/5207700
2263000/5207700
2264000/5207700
2265000/5207700
2266000/5207700
2267000/5207700
2268000/5207700
2269000/5207700
2270000/5207700
2271000/5207700
2272000/5207700
2273000/5207700
2274000/5207700
2275000/5207700
2276000/5207700
2277000/5207700
2278000/5207700
2279000/5207700
2280000/5207700
2281000/5207700
2282000/5207700
2283000/5207700
2284000/5207700
2285000/5207700
2286000/5207700
2287000/5207700
2288000/5207700
2289000/5207700
2290000/5207700
2291000/5207700
2292000/5207700
2293000/5207700
2294000/5207700
2295000/5207700
2296000/5207700
2297000/5207700
2298000/5207700
2299000/5207700
2300000/5207700
2301000/5207700
2302000/5207700
2303000/5207700
2304000/5207700
2305000/5207700
2306000/5207700
2307000/5207700
2308000/5207700
2309000/5207700
2310000/5207700
2311000/5207700
2312000/5207700
2313000/5207700
2314000/5207700
2315000/5207700
2316000/5207700
2317000/5207700
2318000/5207700
2319000/5207700
2320000/5207700
2321000/5207700
2322000/5207700
2323000/5207700
2324000/5207700
2325000/5207700
2326000/5207700
2327000/5207700
2328000/5207700
2329000/5207700
2330000/5207700
2331000/5207700
2332000/5207700
2333000/5207700
2334000/5207700
2335000/5207700
2336000/5207700
2337000/5207700
2338000/5207700
2339000/5207700
2340000/5207700
2341000/5207700
2342000/5207700
2343000/5207700
2344000/5207700
2345000/5207700
2346000/5207700
2347000/5207700
2348000/5207700
2349000/5207700
2350000/5207700
2351000/5207700
2352000/5207700
2353000/5207700
2354000/5207700
2355000/5207700
2356000/5207700
2357000/5207700
2358000/5207700
2359000/5207700
2360000/5207700
2361000/5207700
2362000/5207700
2363000/5207700
2364000/5207700
2365000/5207700
2366000/5207700
2367000/5207700
2368000/5207700
2369000/5207700
2370000/5207700
2371000/5207700
2372000/5207700
2373000/5207700
2374000/5207700
2375000/5207700
2376000/5207700
2377000/5207700
2378000/5207700
2379000/5207700
2380000/5207700
2381000/5207700
2382000/5207700
2383000/5207700
2384000/5207700
2385000/5207700
2386000/5207700
2387000/5207700
2388000/5207700
2389000/5207700
2390000/5207700
2391000/5207700
2392000/5207700
2393000/5207700
2394000/5207700
2395000/5207700
2396000/5207700
2397000/5207700
2398000/5207700
2399000/5207700
2400000/5207700
2401000/5207700
2402000/5207700
2403000/5207700
2404000/5207700
2405000/5207700
2406000/5207700
2407000/5207700
2408000/5207700
2409000/5207700
2410000/5207700
2411000/5207700
2412000/5207700
2413000/5207700
2414000/5207700
2415000/5207700
2416000/5207700
2417000/5207700
2418000/5207700
2419000/5207700
2420000/5207700
2421000/5207700
2422000/5207700
2423000/5207700
2424000/5207700
2425000/5207700
2426000/5207700
2427000/5207700
2428000/5207700
2429000/5207700
2430000/5207700
2431000/5207700
2432000/5207700
2433000/5207700
2434000/5207700
2435000/5207700
2436000/5207700
2437000/5207700
2438000/5207700
2439000/5207700
2440000/5207700
2441000/5207700
2442000/5207700
2443000/5207700
2444000/5207700
2445000/5207700
2446000/5207700
2447000/5207700
2448000/5207700
2449000/5207700
2450000/5207700
2451000/5207700
2452000/5207700
2453000/5207700
2454000/5207700
2455000/5207700
2456000/5207700
2457000/5207700
2458000/5207700
2459000/5207700
2460000/5207700
2461000/5207700
2462000/5207700
2463000/5207700
2464000/5207700
2465000/5207700
2466000/5207700
2467000/5207700
2468000/5207700
2469000/5207700
2470000/5207700
2471000/5207700
2472000/5207700
2473000/5207700
2474000/5207700
2475000/5207700
2476000/5207700
2477000/5207700
2478000/5207700
2479000/5207700
2480000/5207700
2481000/5207700
2482000/5207700
2483000/5207700
2484000/5207700
2485000/5207700
2486000/5207700
2487000/5207700
2488000/5207700
2489000/5207700
2490000/5207700
2491000/5207700
2492000/5207700
2493000/5207700
2494000/5207700
2495000/5207700
2496000/5207700
2497000/5207700
2498000/5207700
2499000/5207700
2500000/5207700
2501000/5207700
2502000/5207700
2503000/5207700
2504000/5207700
2505000/5207700
2506000/5207700
2507000/5207700
2508000/5207700
2509000/5207700
2510000/5207700
2511000/5207700
2512000/5207700
2513000/5207700
2514000/5207700
2515000/5207700
2516000/5207700
2517000/5207700
2518000/5207700
2519000/5207700
2520000/5207700
2521000/5207700
2522000/5207700
2523000/5207700
2524000/5207700
2525000/5207700
2526000/5207700
2527000/5207700
2528000/5207700
2529000/5207700
2530000/5207700
2531000/5207700
2532000/5207700
2533000/5207700
2534000/5207700
2535000/5207700
2536000/5207700
2537000/5207700
2538000/5207700
2539000/5207700
2540000/5207700
2541000/5207700
2542000/5207700
2543000/5207700
2544000/5207700
2545000/5207700
2546000/5207700
2547000/5207700
2548000/5207700
2549000/5207700
2550000/5207700
2551000/5207700
2552000/5207700
2553000/5207700
2554000/5207700
2555000/5207700
2556000/5207700
2557000/5207700
2558000/5207700
2559000/5207700
2560000/5207700
2561000/5207700
2562000/5207700
2563000/5207700
2564000/5207700
2565000/5207700
2566000/5207700
2567000/5207700
2568000/5207700
2569000/5207700
2570000/5207700
2571000/5207700
2572000/5207700
2573000/5207700
2574000/5207700
2575000/5207700
2576000/5207700
2577000/5207700
2578000/5207700
2579000/5207700
2580000/5207700
2581000/5207700
2582000/5207700
2583000/5207700
2584000/5207700
2585000/5207700
2586000/5207700
2587000/5207700
2588000/5207700
2589000/5207700
2590000/5207700
2591000/5207700
2592000/5207700
2593000/5207700
2594000/5207700
2595000/5207700
2596000/5207700
2597000/5207700
2598000/5207700
2599000/5207700
2600000/5207700
2601000/5207700
2602000/5207700
2603000/5207700
2604000/5207700
2605000/5207700
2606000/5207700
2607000/5207700
2608000/5207700
2609000/5207700
2610000/5207700
2611000/5207700
2612000/5207700
2613000/5207700
2614000/5207700
2615000/5207700
2616000/5207700
2617000/5207700
2618000/5207700
2619000/5207700
2620000/5207700
2621000/5207700
2622000/5207700
2623000/5207700
2624000/5207700
2625000/5207700
2626000/5207700
2627000/5207700
2628000/5207700
2629000/5207700
2630000/5207700
2631000/5207700
2632000/5207700
2633000/5207700
2634000/5207700
2635000/5207700
2636000/5207700
2637000/5207700
2638000/5207700
2639000/5207700
2640000/5207700
2641000/5207700
2642000/5207700
2643000/5207700
2644000/5207700
2645000/5207700
2646000/5207700
2647000/5207700
2648000/5207700
2649000/5207700
2650000/5207700
2651000/5207700
2652000/5207700
2653000/5207700
2654000/5207700
2655000/5207700
2656000/5207700
2657000/5207700
2658000/5207700
2659000/5207700
2660000/5207700
2661000/5207700
2662000/5207700
2663000/5207700
2664000/5207700
2665000/5207700
2666000/5207700
2667000/5207700
2668000/5207700
2669000/5207700
2670000/5207700
2671000/5207700
2672000/5207700
2673000/5207700
2674000/5207700
2675000/5207700
2676000/5207700
2677000/5207700
2678000/5207700
2679000/5207700
2680000/5207700
2681000/5207700
2682000/5207700
2683000/5207700
2684000/5207700
2685000/5207700
2686000/5207700
2687000/5207700
2688000/5207700
2689000/5207700
2690000/5207700
2691000/5207700
2692000/5207700
2693000/5207700
2694000/5207700
2695000/5207700
2696000/5207700
2697000/5207700
2698000/5207700
2699000/5207700
2700000/5207700
2701000/5207700
2702000/5207700
2703000/5207700
2704000/5207700
2705000/5207700
2706000/5207700
2707000/5207700
2708000/5207700
2709000/5207700
2710000/5207700
2711000/5207700
2712000/5207700
2713000/5207700
2714000/5207700
2715000/5207700
2716000/5207700
2717000/5207700
2718000/5207700
2719000/5207700
2720000/5207700
2721000/5207700
2722000/5207700
2723000/5207700
2724000/5207700
2725000/5207700
2726000/5207700
2727000/5207700
2728000/5207700
2729000/5207700
2730000/5207700
2731000/5207700
2732000/5207700
2733000/5207700
2734000/5207700
2735000/5207700
2736000/5207700
2737000/5207700
2738000/5207700
2739000/5207700
2740000/5207700
2741000/5207700
2742000/5207700
2743000/5207700
2744000/5207700
2745000/5207700
2746000/5207700
2747000/5207700
2748000/5207700
2749000/5207700
2750000/5207700
2751000/5207700
2752000/5207700
2753000/5207700
2754000/5207700
2755000/5207700
2756000/5207700
2757000/5207700
2758000/5207700
2759000/5207700
2760000/5207700
2761000/5207700
2762000/5207700
2763000/5207700
2764000/5207700
2765000/5207700
2766000/5207700
2767000/5207700
2768000/5207700
2769000/5207700
2770000/5207700
2771000/5207700
2772000/5207700
2773000/5207700
2774000/5207700
2775000/5207700
2776000/5207700
2777000/5207700
2778000/5207700
2779000/5207700
2780000/5207700
2781000/5207700
2782000/5207700
2783000/5207700
2784000/5207700
2785000/5207700
2786000/5207700
2787000/5207700
2788000/5207700
2789000/5207700
2790000/5207700
2791000/5207700
2792000/5207700
2793000/5207700
2794000/5207700
2795000/5207700
2796000/5207700
2797000/5207700
2798000/5207700
2799000/5207700
2800000/5207700
2801000/5207700
2802000/5207700
2803000/5207700
2804000/5207700
2805000/5207700
2806000/5207700
2807000/5207700
2808000/5207700
2809000/5207700
2810000/5207700
2811000/5207700
2812000/5207700
2813000/5207700
2814000/5207700
2815000/5207700
2816000/5207700
2817000/5207700
2818000/5207700
2819000/5207700
2820000/5207700
2821000/5207700
2822000/5207700
2823000/5207700
2824000/5207700
2825000/5207700
2826000/5207700
2827000/5207700
2828000/5207700
2829000/5207700
2830000/5207700
2831000/5207700
2832000/5207700
2833000/5207700
2834000/5207700
2835000/5207700
2836000/5207700
2837000/5207700
2838000/5207700
2839000/5207700
2840000/5207700
2841000/5207700
2842000/5207700
2843000/5207700
2844000/5207700
2845000/5207700
2846000/5207700
2847000/5207700
2848000/5207700
2849000/5207700
2850000/5207700
2851000/5207700
2852000/5207700
2853000/5207700
2854000/5207700
2855000/5207700
2856000/5207700
2857000/5207700
2858000/5207700
2859000/5207700
2860000/5207700
2861000/5207700
2862000/5207700
2863000/5207700
2864000/5207700
2865000/5207700
2866000/5207700
2867000/5207700
2868000/5207700
2869000/5207700
2870000/5207700
2871000/5207700
2872000/5207700
2873000/5207700
2874000/5207700
2875000/5207700
2876000/5207700
2877000/5207700
2878000/5207700
2879000/5207700
2880000/5207700
2881000/5207700
2882000/5207700
2883000/5207700
2884000/5207700
2885000/5207700
2886000/5207700
2887000/5207700
2888000/5207700
2889000/5207700
2890000/5207700
2891000/5207700
2892000/5207700
2893000/5207700
2894000/5207700
2895000/5207700
2896000/5207700
2897000/5207700
2898000/5207700
2899000/5207700
2900000/5207700
2901000/5207700
2902000/5207700
2903000/5207700
2904000/5207700
2905000/5207700
2906000/5207700
2907000/5207700
2908000/5207700
2909000/5207700
2910000/5207700
2911000/5207700
2912000/5207700
2913000/5207700
2914000/5207700
2915000/5207700
2916000/5207700
2917000/5207700
2918000/5207700
2919000/5207700
2920000/5207700
2921000/5207700
2922000/5207700
2923000/5207700
2924000/5207700
2925000/5207700
2926000/5207700
2927000/5207700
2928000/5207700
2929000/5207700
2930000/5207700
2931000/5207700
2932000/5207700
2933000/5207700
2934000/5207700
2935000/5207700
2936000/5207700
2937000/5207700
2938000/5207700
2939000/5207700
2940000/5207700
2941000/5207700
2942000/5207700
2943000/5207700
2944000/5207700
2945000/5207700
2946000/5207700
2947000/5207700
2948000/5207700
2949000/5207700
2950000/5207700
2951000/5207700
2952000/5207700
2953000/5207700
2954000/5207700
2955000/5207700
2956000/5207700
2957000/5207700
2958000/5207700
2959000/5207700
2960000/5207700
2961000/5207700
2962000/5207700
2963000/5207700
2964000/5207700
2965000/5207700
2966000/5207700
2967000/5207700
2968000/5207700
2969000/5207700
2970000/5207700
2971000/5207700
2972000/5207700
2973000/5207700
2974000/5207700
2975000/5207700
2976000/5207700
2977000/5207700
2978000/5207700
2979000/5207700
2980000/5207700
2981000/5207700
2982000/5207700
2983000/5207700
2984000/5207700
2985000/5207700
2986000/5207700
2987000/5207700
2988000/5207700
2989000/5207700
2990000/5207700
2991000/5207700
2992000/5207700
2993000/5207700
2994000/5207700
2995000/5207700
2996000/5207700
2997000/5207700
2998000/5207700
2999000/5207700
3000000/5207700
3001000/5207700
3002000/5207700
3003000/5207700
3004000/5207700
3005000/5207700
3006000/5207700
3007000/5207700
3008000/5207700
3009000/5207700
3010000/5207700
3011000/5207700
3012000/5207700
3013000/5207700
3014000/5207700
3015000/5207700
3016000/5207700
3017000/5207700
3018000/5207700
3019000/5207700
3020000/5207700
3021000/5207700
3022000/5207700
3023000/5207700
3024000/5207700
3025000/5207700
3026000/5207700
3027000/5207700
3028000/5207700
3029000/5207700
3030000/5207700
3031000/5207700
3032000/5207700
3033000/5207700
3034000/5207700
3035000/5207700
3036000/5207700
3037000/5207700
3038000/5207700
3039000/5207700
3040000/5207700
3041000/5207700
3042000/5207700
3043000/5207700
3044000/5207700
3045000/5207700
3046000/5207700
3047000/5207700
3048000/5207700
3049000/5207700
3050000/5207700
3051000/5207700
3052000/5207700
3053000/5207700
3054000/5207700
3055000/5207700
3056000/5207700
3057000/5207700
3058000/5207700
3059000/5207700
3060000/5207700
3061000/5207700
3062000/5207700
3063000/5207700
3064000/5207700
3065000/5207700
3066000/5207700
3067000/5207700
3068000/5207700
3069000/5207700
3070000/5207700
3071000/5207700
3072000/5207700
3073000/5207700
3074000/5207700
3075000/5207700
3076000/5207700
3077000/5207700
3078000/5207700
3079000/5207700
3080000/5207700
3081000/5207700
3082000/5207700
3083000/5207700
3084000/5207700
3085000/5207700
3086000/5207700
3087000/5207700
3088000/5207700
3089000/5207700
3090000/5207700
3091000/5207700
3092000/5207700
3093000/5207700
3094000/5207700
3095000/5207700
3096000/5207700
3097000/5207700
3098000/5207700
3099000/5207700
3100000/5207700
3101000/5207700
3102000/5207700
3103000/5207700
3104000/5207700
3105000/5207700
3106000/5207700
3107000/5207700
3108000/5207700
3109000/5207700
3110000/5207700
3111000/5207700
3112000/5207700
3113000/5207700
3114000/5207700
3115000/5207700
3116000/5207700
3117000/5207700
3118000/5207700
3119000/5207700
3120000/5207700
3121000/5207700
3122000/5207700
3123000/5207700
3124000/5207700
3125000/5207700
3126000/5207700
3127000/5207700
3128000/5207700
3129000/5207700
3130000/5207700
3131000/5207700
3132000/5207700
3133000/5207700
3134000/5207700
3135000/5207700
3136000/5207700
3137000/5207700
3138000/5207700
3139000/5207700
3140000/5207700
3141000/5207700
3142000/5207700
3143000/5207700
3144000/5207700
3145000/5207700
3146000/5207700
3147000/5207700
3148000/5207700
3149000/5207700
3150000/5207700
3151000/5207700
3152000/5207700
3153000/5207700
3154000/5207700
3155000/5207700
3156000/5207700
3157000/5207700
3158000/5207700
3159000/5207700
3160000/5207700
3161000/5207700
3162000/5207700
3163000/5207700
3164000/5207700
3165000/5207700
3166000/5207700
3167000/5207700
3168000/5207700
3169000/5207700
3170000/5207700
3171000/5207700
3172000/5207700
3173000/5207700
3174000/5207700
3175000/5207700
3176000/5207700
3177000/5207700
3178000/5207700
3179000/5207700
3180000/5207700
3181000/5207700
3182000/5207700
3183000/5207700
3184000/5207700
3185000/5207700
3186000/5207700
3187000/5207700
3188000/5207700
3189000/5207700
3190000/5207700
3191000/5207700
3192000/5207700
3193000/5207700
3194000/5207700
3195000/5207700
3196000/5207700
3197000/5207700
3198000/5207700
3199000/5207700
3200000/5207700
3201000/5207700
3202000/5207700
3203000/5207700
3204000/5207700
3205000/5207700
3206000/5207700
3207000/5207700
3208000/5207700
3209000/5207700
3210000/5207700
3211000/5207700
3212000/5207700
3213000/5207700
3214000/5207700
3215000/5207700
3216000/5207700
3217000/5207700
3218000/5207700
3219000/5207700
3220000/5207700
3221000/5207700
3222000/5207700
3223000/5207700
3224000/5207700
3225000/5207700
3226000/5207700
3227000/5207700
3228000/5207700
3229000/5207700
3230000/5207700
3231000/5207700
3232000/5207700
3233000/5207700
3234000/5207700
3235000/5207700
3236000/5207700
3237000/5207700
3238000/5207700
3239000/5207700
3240000/5207700
3241000/5207700
3242000/5207700
3243000/5207700
3244000/5207700
3245000/5207700
3246000/5207700
3247000/5207700
3248000/5207700
3249000/5207700
3250000/5207700
3251000/5207700
3252000/5207700
3253000/5207700
3254000/5207700
3255000/5207700
3256000/5207700
3257000/5207700
3258000/5207700
3259000/5207700
3260000/5207700
3261000/5207700
3262000/5207700
3263000/5207700
3264000/5207700
3265000/5207700
3266000/5207700
3267000/5207700
3268000/5207700
3269000/5207700
3270000/5207700
3271000/5207700
3272000/5207700
3273000/5207700
3274000/5207700
3275000/5207700
3276000/5207700
3277000/5207700
3278000/5207700
3279000/5207700
3280000/5207700
3281000/5207700
3282000/5207700
3283000/5207700
3284000/5207700
3285000/5207700
3286000/5207700
3287000/5207700
3288000/5207700
3289000/5207700
3290000/5207700
3291000/5207700
3292000/5207700
3293000/5207700
3294000/5207700
3295000/5207700
3296000/5207700
3297000/5207700
3298000/5207700
3299000/5207700
3300000/5207700
3301000/5207700
3302000/5207700
3303000/5207700
3304000/5207700
3305000/5207700
3306000/5207700
3307000/5207700
3308000/5207700
3309000/5207700
3310000/5207700
3311000/5207700
3312000/5207700
3313000/5207700
3314000/5207700
3315000/5207700
3316000/5207700
3317000/5207700
3318000/5207700
3319000/5207700
3320000/5207700
3321000/5207700
3322000/5207700
3323000/5207700
3324000/5207700
3325000/5207700
3326000/5207700
3327000/5207700
3328000/5207700
3329000/5207700
3330000/5207700
3331000/5207700
3332000/5207700
3333000/5207700
3334000/5207700
3335000/5207700
3336000/5207700
3337000/5207700
3338000/5207700
3339000/5207700
3340000/5207700
3341000/5207700
3342000/5207700
3343000/5207700
3344000/5207700
3345000/5207700
3346000/5207700
3347000/5207700
3348000/5207700
3349000/5207700
3350000/5207700
3351000/5207700
3352000/5207700
3353000/5207700
3354000/5207700
3355000/5207700
3356000/5207700
3357000/5207700
3358000/5207700
3359000/5207700
3360000/5207700
3361000/5207700
3362000/5207700
3363000/5207700
3364000/5207700
3365000/5207700
3366000/5207700
3367000/5207700
3368000/5207700
3369000/5207700
3370000/5207700
3371000/5207700
3372000/5207700
3373000/5207700
3374000/5207700
3375000/5207700
3376000/5207700
3377000/5207700
3378000/5207700
3379000/5207700
3380000/5207700
3381000/5207700
3382000/5207700
3383000/5207700
3384000/5207700
3385000/5207700
3386000/5207700
3387000/5207700
3388000/5207700
3389000/5207700
3390000/5207700
3391000/5207700
3392000/5207700
3393000/5207700
3394000/5207700
3395000/5207700
3396000/5207700
3397000/5207700
3398000/5207700
3399000/5207700
3400000/5207700
3401000/5207700
3402000/5207700
3403000/5207700
3404000/5207700
3405000/5207700
3406000/5207700
3407000/5207700
3408000/5207700
3409000/5207700
3410000/5207700
3411000/5207700
3412000/5207700
3413000/5207700
3414000/5207700
3415000/5207700
3416000/5207700
3417000/5207700
3418000/5207700
3419000/5207700
3420000/5207700
3421000/5207700
3422000/5207700
3423000/5207700
3424000/5207700
3425000/5207700
3426000/5207700
3427000/5207700
3428000/5207700
3429000/5207700
3430000/5207700
3431000/5207700
3432000/5207700
3433000/5207700
3434000/5207700
3435000/5207700
3436000/5207700
3437000/5207700
3438000/5207700
3439000/5207700
3440000/5207700
3441000/5207700
3442000/5207700
3443000/5207700
3444000/5207700
3445000/5207700
3446000/5207700
3447000/5207700
3448000/5207700
3449000/5207700
3450000/5207700
3451000/5207700
3452000/5207700
3453000/5207700
3454000/5207700
3455000/5207700
3456000/5207700
3457000/5207700
3458000/5207700
3459000/5207700
3460000/5207700
3461000/5207700
3462000/5207700
3463000/5207700
3464000/5207700
3465000/5207700
3466000/5207700
3467000/5207700
3468000/5207700
3469000/5207700
3470000/5207700
3471000/5207700
3472000/5207700
3473000/5207700
3474000/5207700
3475000/5207700
3476000/5207700
3477000/5207700
3478000/5207700
3479000/5207700
3480000/5207700
3481000/5207700
3482000/5207700
3483000/5207700
3484000/5207700
3485000/5207700
3486000/5207700
3487000/5207700
3488000/5207700
3489000/5207700
3490000/5207700
3491000/5207700
3492000/5207700
3493000/5207700
3494000/5207700
3495000/5207700
3496000/5207700
3497000/5207700
3498000/5207700
3499000/5207700
3500000/5207700
3501000/5207700
3502000/5207700
3503000/5207700
3504000/5207700
3505000/5207700
3506000/5207700
3507000/5207700
3508000/5207700
3509000/5207700
3510000/5207700
3511000/5207700
3512000/5207700
3513000/5207700
3514000/5207700
3515000/5207700
3516000/5207700
3517000/5207700
3518000/5207700
3519000/5207700
3520000/5207700
3521000/5207700
3522000/5207700
3523000/5207700
3524000/5207700
3525000/5207700
3526000/5207700
3527000/5207700
3528000/5207700
3529000/5207700
3530000/5207700
3531000/5207700
3532000/5207700
3533000/5207700
3534000/5207700
3535000/5207700
3536000/5207700
3537000/5207700
3538000/5207700
3539000/5207700
3540000/5207700
3541000/5207700
3542000/5207700
3543000/5207700
3544000/5207700
3545000/5207700
3546000/5207700
3547000/5207700
3548000/5207700
3549000/5207700
3550000/5207700
3551000/5207700
3552000/5207700
3553000/5207700
3554000/5207700
3555000/5207700
3556000/5207700
3557000/5207700
3558000/5207700
3559000/5207700
3560000/5207700
3561000/5207700
3562000/5207700
3563000/5207700
3564000/5207700
3565000/5207700
3566000/5207700
3567000/5207700
3568000/5207700
3569000/5207700
3570000/5207700
3571000/5207700
3572000/5207700
3573000/5207700
3574000/5207700
3575000/5207700
3576000/5207700
3577000/5207700
3578000/5207700
3579000/5207700
3580000/5207700
3581000/5207700
3582000/5207700
3583000/5207700
3584000/5207700
3585000/5207700
3586000/5207700
3587000/5207700
3588000/5207700
3589000/5207700
3590000/5207700
3591000/5207700
3592000/5207700
3593000/5207700
3594000/5207700
3595000/5207700
3596000/5207700
3597000/5207700
3598000/5207700
3599000/5207700
3600000/5207700
3601000/5207700
3602000/5207700
3603000/5207700
3604000/5207700
3605000/5207700
3606000/5207700
3607000/5207700
3608000/5207700
3609000/5207700
3610000/5207700
3611000/5207700
3612000/5207700
3613000/5207700
3614000/5207700
3615000/5207700
3616000/5207700
3617000/5207700
3618000/5207700
3619000/5207700
3620000/5207700
3621000/5207700
3622000/5207700
3623000/5207700
3624000/5207700
3625000/5207700
3626000/5207700
3627000/5207700
3628000/5207700
3629000/5207700
3630000/5207700
3631000/5207700
3632000/5207700
3633000/5207700
3634000/5207700
3635000/5207700
3636000/5207700
3637000/5207700
3638000/5207700
3639000/5207700
3640000/5207700
3641000/5207700
3642000/5207700
3643000/5207700
3644000/5207700
3645000/5207700
3646000/5207700
3647000/5207700
3648000/5207700
3649000/5207700
3650000/5207700
3651000/5207700
3652000/5207700
3653000/5207700
3654000/5207700
3655000/5207700
3656000/5207700
3657000/5207700
3658000/5207700
3659000/5207700
3660000/5207700
3661000/5207700
3662000/5207700
3663000/5207700
3664000/5207700
3665000/5207700
3666000/5207700
3667000/5207700
3668000/5207700
3669000/5207700
3670000/5207700
3671000/5207700
3672000/5207700
3673000/5207700
3674000/5207700
3675000/5207700
3676000/5207700
3677000/5207700
3678000/5207700
3679000/5207700
3680000/5207700
3681000/5207700
3682000/5207700
3683000/5207700
3684000/5207700
3685000/5207700
3686000/5207700
3687000/5207700
3688000/5207700
3689000/5207700
3690000/5207700
3691000/5207700
3692000/5207700
3693000/5207700
3694000/5207700
3695000/5207700
3696000/5207700
3697000/5207700
3698000/5207700
3699000/5207700
3700000/5207700
3701000/5207700
3702000/5207700
3703000/5207700
3704000/5207700
3705000/5207700
3706000/5207700
3707000/5207700
3708000/5207700
3709000/5207700
3710000/5207700
3711000/5207700
3712000/5207700
3713000/5207700
3714000/5207700
3715000/5207700
3716000/5207700
3717000/5207700
3718000/5207700
3719000/5207700
3720000/5207700
3721000/5207700
3722000/5207700
3723000/5207700
3724000/5207700
3725000/5207700
3726000/5207700
3727000/5207700
3728000/5207700
3729000/5207700
3730000/5207700
3731000/5207700
3732000/5207700
3733000/5207700
3734000/5207700
3735000/5207700
3736000/5207700
3737000/5207700
3738000/5207700
3739000/5207700
3740000/5207700
3741000/5207700
3742000/5207700
3743000/5207700
3744000/5207700
3745000/5207700
3746000/5207700
3747000/5207700
3748000/5207700
3749000/5207700
3750000/5207700
3751000/5207700
3752000/5207700
3753000/5207700
3754000/5207700
3755000/5207700
3756000/5207700
3757000/5207700
3758000/5207700
3759000/5207700
3760000/5207700
3761000/5207700
3762000/5207700
3763000/5207700
3764000/5207700
3765000/5207700
3766000/5207700
3767000/5207700
3768000/5207700
3769000/5207700
3770000/5207700
3771000/5207700
3772000/5207700
3773000/5207700
3774000/5207700
3775000/5207700
3776000/5207700
3777000/5207700
3778000/5207700
3779000/5207700
3780000/5207700
3781000/5207700
3782000/5207700
3783000/5207700
3784000/5207700
3785000/5207700
3786000/5207700
3787000/5207700
3788000/5207700
3789000/5207700
3790000/5207700
3791000/5207700
3792000/5207700
3793000/5207700
3794000/5207700
3795000/5207700
3796000/5207700
3797000/5207700
3798000/5207700
3799000/5207700
3800000/5207700
3801000/5207700
3802000/5207700
3803000/5207700
3804000/5207700
3805000/5207700
3806000/5207700
3807000/5207700
3808000/5207700
3809000/5207700
3810000/5207700
3811000/5207700
3812000/5207700
3813000/5207700
3814000/5207700
3815000/5207700
3816000/5207700
3817000/5207700
3818000/5207700
3819000/5207700
3820000/5207700
3821000/5207700
3822000/5207700
3823000/5207700
3824000/5207700
3825000/5207700
3826000/5207700
3827000/5207700
3828000/5207700
3829000/5207700
3830000/5207700
3831000/5207700
3832000/5207700
3833000/5207700
3834000/5207700
3835000/5207700
3836000/5207700
3837000/5207700
3838000/5207700
3839000/5207700
3840000/5207700
3841000/5207700
3842000/5207700
3843000/5207700
3844000/5207700
3845000/5207700
3846000/5207700
3847000/5207700
3848000/5207700
3849000/5207700
3850000/5207700
3851000/5207700
3852000/5207700
3853000/5207700
3854000/5207700
3855000/5207700
3856000/5207700
3857000/5207700
3858000/5207700
3859000/5207700
3860000/5207700
3861000/5207700
3862000/5207700
3863000/5207700
3864000/5207700
3865000/5207700
3866000/5207700
3867000/5207700
3868000/5207700
3869000/5207700
3870000/5207700
3871000/5207700
3872000/5207700
3873000/5207700
3874000/5207700
3875000/5207700
3876000/5207700
3877000/5207700
3878000/5207700
3879000/5207700
3880000/5207700
3881000/5207700
3882000/5207700
3883000/5207700
3884000/5207700
3885000/5207700
3886000/5207700
3887000/5207700
3888000/5207700
3889000/5207700
3890000/5207700
3891000/5207700
3892000/5207700
3893000/5207700
3894000/5207700
3895000/5207700
3896000/5207700
3897000/5207700
3898000/5207700
3899000/5207700
3900000/5207700
3901000/5207700
3902000/5207700
3903000/5207700
3904000/5207700
3905000/5207700
3906000/5207700
3907000/5207700
3908000/5207700
3909000/5207700
3910000/5207700
3911000/5207700
3912000/5207700
3913000/5207700
3914000/5207700
3915000/5207700
3916000/5207700
3917000/5207700
3918000/5207700
3919000/5207700
3920000/5207700
3921000/5207700
3922000/5207700
3923000/5207700
3924000/5207700
3925000/5207700
3926000/5207700
3927000/5207700
3928000/5207700
3929000/5207700
3930000/5207700
3931000/5207700
3932000/5207700
3933000/5207700
3934000/5207700
3935000/5207700
3936000/5207700
3937000/5207700
3938000/5207700
3939000/5207700
3940000/5207700
3941000/5207700
3942000/5207700
3943000/5207700
3944000/5207700
3945000/5207700
3946000/5207700
3947000/5207700
3948000/5207700
3949000/5207700
3950000/5207700
3951000/5207700
3952000/5207700
3953000/5207700
3954000/5207700
3955000/5207700
3956000/5207700
3957000/5207700
3958000/5207700
3959000/5207700
3960000/5207700
3961000/5207700
3962000/5207700
3963000/5207700
3964000/5207700
3965000/5207700
3966000/5207700
3967000/5207700
3968000/5207700
3969000/5207700
3970000/5207700
3971000/5207700
3972000/5207700
3973000/5207700
3974000/5207700
3975000/5207700
3976000/5207700
3977000/5207700
3978000/5207700
3979000/5207700
3980000/5207700
3981000/5207700
3982000/5207700
3983000/5207700
3984000/5207700
3985000/5207700
3986000/5207700
3987000/5207700
3988000/5207700
3989000/5207700
3990000/5207700
3991000/5207700
3992000/5207700
3993000/5207700
3994000/5207700
3995000/5207700
3996000/5207700
3997000/5207700
3998000/5207700
3999000/5207700
4000000/5207700
4001000/5207700
4002000/5207700
4003000/5207700
4004000/5207700
4005000/5207700
4006000/5207700
4007000/5207700
4008000/5207700
4009000/5207700
4010000/5207700
4011000/5207700
4012000/5207700
4013000/5207700
4014000/5207700
4015000/5207700
4016000/5207700
4017000/5207700
4018000/5207700
4019000/5207700
4020000/5207700
4021000/5207700
4022000/5207700
4023000/5207700
4024000/5207700
4025000/5207700
4026000/5207700
4027000/5207700
4028000/5207700
4029000/5207700
4030000/5207700
4031000/5207700
4032000/5207700
4033000/5207700
4034000/5207700
4035000/5207700
4036000/5207700
4037000/5207700
4038000/5207700
4039000/5207700
4040000/5207700
4041000/5207700
4042000/5207700
4043000/5207700
4044000/5207700
4045000/5207700
4046000/5207700
4047000/5207700
4048000/5207700
4049000/5207700
4050000/5207700
4051000/5207700
4052000/5207700
4053000/5207700
4054000/5207700
4055000/5207700
4056000/5207700
4057000/5207700
4058000/5207700
4059000/5207700
4060000/5207700
4061000/5207700
4062000/5207700
4063000/5207700
4064000/5207700
4065000/5207700
4066000/5207700
4067000/5207700
4068000/5207700
4069000/5207700
4070000/5207700
4071000/5207700
4072000/5207700
4073000/5207700
4074000/5207700
4075000/5207700
4076000/5207700
4077000/5207700
4078000/5207700
4079000/5207700
4080000/5207700
4081000/5207700
4082000/5207700
4083000/5207700
4084000/5207700
4085000/5207700
4086000/5207700
4087000/5207700
4088000/5207700
4089000/5207700
4090000/5207700
4091000/5207700
4092000/5207700
4093000/5207700
4094000/5207700
4095000/5207700
4096000/5207700
4097000/5207700
4098000/5207700
4099000/5207700
4100000/5207700
4101000/5207700
4102000/5207700
4103000/5207700
4104000/5207700
4105000/5207700
4106000/5207700
4107000/5207700
4108000/5207700
4109000/5207700
4110000/5207700
4111000/5207700
4112000/5207700
4113000/5207700
4114000/5207700
4115000/5207700
4116000/5207700
4117000/5207700
4118000/5207700
4119000/5207700
4120000/5207700
4121000/5207700
4122000/5207700
4123000/5207700
4124000/5207700
4125000/5207700
4126000/5207700
4127000/5207700
4128000/5207700
4129000/5207700
4130000/5207700
4131000/5207700
4132000/5207700
4133000/5207700
4134000/5207700
4135000/5207700
4136000/5207700
4137000/5207700
4138000/5207700
4139000/5207700
4140000/5207700
4141000/5207700
4142000/5207700
4143000/5207700
4144000/5207700
4145000/5207700
4146000/5207700
4147000/5207700
4148000/5207700
4149000/5207700
4150000/5207700
4151000/5207700
4152000/5207700
4153000/5207700
4154000/5207700
4155000/5207700
4156000/5207700
4157000/5207700
4158000/5207700
4159000/5207700
4160000/5207700
4161000/5207700
4162000/5207700
4163000/5207700
4164000/5207700
4165000/5207700
4166000/5207700
4167000/5207700
4168000/5207700
4169000/5207700
4170000/5207700
4171000/5207700
4172000/5207700
4173000/5207700
4174000/5207700
4175000/5207700
4176000/5207700
4177000/5207700
4178000/5207700
4179000/5207700
4180000/5207700
4181000/5207700
4182000/5207700
4183000/5207700
4184000/5207700
4185000/5207700
4186000/5207700
4187000/5207700
4188000/5207700
4189000/5207700
4190000/5207700
4191000/5207700
4192000/5207700
4193000/5207700
4194000/5207700
4195000/5207700
4196000/5207700
4197000/5207700
4198000/5207700
4199000/5207700
4200000/5207700
4201000/5207700
4202000/5207700
4203000/5207700
4204000/5207700
4205000/5207700
4206000/5207700
4207000/5207700
4208000/5207700
4209000/5207700
4210000/5207700
4211000/5207700
4212000/5207700
4213000/5207700
4214000/5207700
4215000/5207700
4216000/5207700
4217000/5207700
4218000/5207700
4219000/5207700
4220000/5207700
4221000/5207700
4222000/5207700
4223000/5207700
4224000/5207700
4225000/5207700
4226000/5207700
4227000/5207700
4228000/5207700
4229000/5207700
4230000/5207700
4231000/5207700
4232000/5207700
4233000/5207700
4234000/5207700
4235000/5207700
4236000/5207700
4237000/5207700
4238000/5207700
4239000/5207700
4240000/5207700
4241000/5207700
4242000/5207700
4243000/5207700
4244000/5207700
4245000/5207700
4246000/5207700
4247000/5207700
4248000/5207700
4249000/5207700
4250000/5207700
4251000/5207700
4252000/5207700
4253000/5207700
4254000/5207700
4255000/5207700
4256000/5207700
4257000/5207700
4258000/5207700
4259000/5207700
4260000/5207700
4261000/5207700
4262000/5207700
4263000/5207700
4264000/5207700
4265000/5207700
4266000/5207700
4267000/5207700
4268000/5207700
4269000/5207700
4270000/5207700
4271000/5207700
4272000/5207700
4273000/5207700
4274000/5207700
4275000/5207700
4276000/5207700
4277000/5207700
4278000/5207700
4279000/5207700
4280000/5207700
4281000/5207700
4282000/5207700
4283000/5207700
4284000/5207700
4285000/5207700
4286000/5207700
4287000/5207700
4288000/5207700
4289000/5207700
4290000/5207700
4291000/5207700
4292000/5207700
4293000/5207700
4294000/5207700
4295000/5207700
4296000/5207700
4297000/5207700
4298000/5207700
4299000/5207700
4300000/5207700
4301000/5207700
4302000/5207700
4303000/5207700
4304000/5207700
4305000/5207700
4306000/5207700
4307000/5207700
4308000/5207700
4309000/5207700
4310000/5207700
4311000/5207700
4312000/5207700
4313000/5207700
4314000/5207700
4315000/5207700
4316000/5207700
4317000/5207700
4318000/5207700
4319000/5207700
4320000/5207700
4321000/5207700
4322000/5207700
4323000/5207700
4324000/5207700
4325000/5207700
4326000/5207700
4327000/5207700
4328000/5207700
4329000/5207700
4330000/5207700
4331000/5207700
4332000/5207700
4333000/5207700
4334000/5207700
4335000/5207700
4336000/5207700
4337000/5207700
4338000/5207700
4339000/5207700
4340000/5207700
4341000/5207700
4342000/5207700
4343000/5207700
4344000/5207700
4345000/5207700
4346000/5207700
4347000/5207700
4348000/5207700
4349000/5207700
4350000/5207700
4351000/5207700
4352000/5207700
4353000/5207700
4354000/5207700
4355000/5207700
4356000/5207700
4357000/5207700
4358000/5207700
4359000/5207700
4360000/5207700
4361000/5207700
4362000/5207700
4363000/5207700
4364000/5207700
4365000/5207700
4366000/5207700
4367000/5207700
4368000/5207700
4369000/5207700
4370000/5207700
4371000/5207700
4372000/5207700
4373000/5207700
4374000/5207700
4375000/5207700
4376000/5207700
4377000/5207700
4378000/5207700
4379000/5207700
4380000/5207700
4381000/5207700
4382000/5207700
4383000/5207700
4384000/5207700
4385000/5207700
4386000/5207700
4387000/5207700
4388000/5207700
4389000/5207700
4390000/5207700
4391000/5207700
4392000/5207700
4393000/5207700
4394000/5207700
4395000/5207700
4396000/5207700
4397000/5207700
4398000/5207700
4399000/5207700
4400000/5207700
4401000/5207700
4402000/5207700
4403000/5207700
4404000/5207700
4405000/5207700
4406000/5207700
4407000/5207700
4408000/5207700
4409000/5207700
4410000/5207700
4411000/5207700
4412000/5207700
4413000/5207700
4414000/5207700
4415000/5207700
4416000/5207700
4417000/5207700
4418000/5207700
4419000/5207700
4420000/5207700
4421000/5207700
4422000/5207700
4423000/5207700
4424000/5207700
4425000/5207700
4426000/5207700
4427000/5207700
4428000/5207700
4429000/5207700
4430000/5207700
4431000/5207700
4432000/5207700
4433000/5207700
4434000/5207700
4435000/5207700
4436000/5207700
4437000/5207700
4438000/5207700
4439000/5207700
4440000/5207700
4441000/5207700
4442000/5207700
4443000/5207700
4444000/5207700
4445000/5207700
4446000/5207700
4447000/5207700
4448000/5207700
4449000/5207700
4450000/5207700
4451000/5207700
4452000/5207700
4453000/5207700
4454000/5207700
4455000/5207700
4456000/5207700
4457000/5207700
4458000/5207700
4459000/5207700
4460000/5207700
4461000/5207700
4462000/5207700
4463000/5207700
4464000/5207700
4465000/5207700
4466000/5207700
4467000/5207700
4468000/5207700
4469000/5207700
4470000/5207700
4471000/5207700
4472000/5207700
4473000/5207700
4474000/5207700
4475000/5207700
4476000/5207700
4477000/5207700
4478000/5207700
4479000/5207700
4480000/5207700
4481000/5207700
4482000/5207700
4483000/5207700
4484000/5207700
4485000/5207700
4486000/5207700
4487000/5207700
4488000/5207700
4489000/5207700
4490000/5207700
4491000/5207700
4492000/5207700
4493000/5207700
4494000/5207700
4495000/5207700
4496000/5207700
4497000/5207700
4498000/5207700
4499000/5207700
4500000/5207700
4501000/5207700
4502000/5207700
4503000/5207700
4504000/5207700
4505000/5207700
4506000/5207700
4507000/5207700
4508000/5207700
4509000/5207700
4510000/5207700
4511000/5207700
4512000/5207700
4513000/5207700
4514000/5207700
4515000/5207700
4516000/5207700
4517000/5207700
4518000/5207700
4519000/5207700
4520000/5207700
4521000/5207700
4522000/5207700
4523000/5207700
4524000/5207700
4525000/5207700
4526000/5207700
4527000/5207700
4528000/5207700
4529000/5207700
4530000/5207700
4531000/5207700
4532000/5207700
4533000/5207700
4534000/5207700
4535000/5207700
4536000/5207700
4537000/5207700
4538000/5207700
4539000/5207700
4540000/5207700
4541000/5207700
4542000/5207700
4543000/5207700
4544000/5207700
4545000/5207700
4546000/5207700
4547000/5207700
4548000/5207700
4549000/5207700
4550000/5207700
4551000/5207700
4552000/5207700
4553000/5207700
4554000/5207700
4555000/5207700
4556000/5207700
4557000/5207700
4558000/5207700
4559000/5207700
4560000/5207700
4561000/5207700
4562000/5207700
4563000/5207700
4564000/5207700
4565000/5207700
4566000/5207700
4567000/5207700
4568000/5207700
4569000/5207700
4570000/5207700
4571000/5207700
4572000/5207700
4573000/5207700
4574000/5207700
4575000/5207700
4576000/5207700
4577000/5207700
4578000/5207700
4579000/5207700
4580000/5207700
4581000/5207700
4582000/5207700
4583000/5207700
4584000/5207700
4585000/5207700
4586000/5207700
4587000/5207700
4588000/5207700
4589000/5207700
4590000/5207700
4591000/5207700
4592000/5207700
4593000/5207700
4594000/5207700
4595000/5207700
4596000/5207700
4597000/5207700
4598000/5207700
4599000/5207700
4600000/5207700
4601000/5207700
4602000/5207700
4603000/5207700
4604000/5207700
4605000/5207700
4606000/5207700
4607000/5207700
4608000/5207700
4609000/5207700
4610000/5207700
4611000/5207700
4612000/5207700
4613000/5207700
4614000/5207700
4615000/5207700
4616000/5207700
4617000/5207700
4618000/5207700
4619000/5207700
4620000/5207700
4621000/5207700
4622000/5207700
4623000/5207700
4624000/5207700
4625000/5207700
4626000/5207700
4627000/5207700
4628000/5207700
4629000/5207700
4630000/5207700
4631000/5207700
4632000/5207700
4633000/5207700
4634000/5207700
4635000/5207700
4636000/5207700
4637000/5207700
4638000/5207700
4639000/5207700
4640000/5207700
4641000/5207700
4642000/5207700
4643000/5207700
4644000/5207700
4645000/5207700
4646000/5207700
4647000/5207700
4648000/5207700
4649000/5207700
4650000/5207700
4651000/5207700
4652000/5207700
4653000/5207700
4654000/5207700
4655000/5207700
4656000/5207700
4657000/5207700
4658000/5207700
4659000/5207700
4660000/5207700
4661000/5207700
4662000/5207700
4663000/5207700
4664000/5207700
4665000/5207700
4666000/5207700
4667000/5207700
4668000/5207700
4669000/5207700
4670000/5207700
4671000/5207700
4672000/5207700
4673000/5207700
4674000/5207700
4675000/5207700
4676000/5207700
4677000/5207700
4678000/5207700
4679000/5207700
4680000/5207700
4681000/5207700
4682000/5207700
4683000/5207700
4684000/5207700
4685000/5207700
4686000/5207700
4687000/5207700
4688000/5207700
4689000/5207700
4690000/5207700
4691000/5207700
4692000/5207700
4693000/5207700
4694000/5207700
4695000/5207700
4696000/5207700
4697000/5207700
4698000/5207700
4699000/5207700
4700000/5207700
4701000/5207700
4702000/5207700
4703000/5207700
4704000/5207700
4705000/5207700
4706000/5207700
4707000/5207700
4708000/5207700
4709000/5207700
4710000/5207700
4711000/5207700
4712000/5207700
4713000/5207700
4714000/5207700
4715000/5207700
4716000/5207700
4717000/5207700
4718000/5207700
4719000/5207700
4720000/5207700
4721000/5207700
4722000/5207700
4723000/5207700
4724000/5207700
4725000/5207700
4726000/5207700
4727000/5207700
4728000/5207700
4729000/5207700
4730000/5207700
4731000/5207700
4732000/5207700
4733000/5207700
4734000/5207700
4735000/5207700
4736000/5207700
4737000/5207700
4738000/5207700
4739000/5207700
4740000/5207700
4741000/5207700
4742000/5207700
4743000/5207700
4744000/5207700
4745000/5207700
4746000/5207700
4747000/5207700
4748000/5207700
4749000/5207700
4750000/5207700
4751000/5207700
4752000/5207700
4753000/5207700
4754000/5207700
4755000/5207700
4756000/5207700
4757000/5207700
4758000/5207700
4759000/5207700
4760000/5207700
4761000/5207700
4762000/5207700
4763000/5207700
4764000/5207700
4765000/5207700
4766000/5207700
4767000/5207700
4768000/5207700
4769000/5207700
4770000/5207700
4771000/5207700
4772000/5207700
4773000/5207700
4774000/5207700
4775000/5207700
4776000/5207700
4777000/5207700
4778000/5207700
4779000/5207700
4780000/5207700
4781000/5207700
4782000/5207700
4783000/5207700
4784000/5207700
4785000/5207700
4786000/5207700
4787000/5207700
4788000/5207700
4789000/5207700
4790000/5207700
4791000/5207700
4792000/5207700
4793000/5207700
4794000/5207700
4795000/5207700
4796000/5207700
4797000/5207700
4798000/5207700
4799000/5207700
4800000/5207700
4801000/5207700
4802000/5207700
4803000/5207700
4804000/5207700
4805000/5207700
4806000/5207700
4807000/5207700
4808000/5207700
4809000/5207700
4810000/5207700
4811000/5207700
4812000/5207700
4813000/5207700
4814000/5207700
4815000/5207700
4816000/5207700
4817000/5207700
4818000/5207700
4819000/5207700
4820000/5207700
4821000/5207700
4822000/5207700
4823000/5207700
4824000/5207700
4825000/5207700
4826000/5207700
4827000/5207700
4828000/5207700
4829000/5207700
4830000/5207700
4831000/5207700
4832000/5207700
4833000/5207700
4834000/5207700
4835000/5207700
4836000/5207700
4837000/5207700
4838000/5207700
4839000/5207700
4840000/5207700
4841000/5207700
4842000/5207700
4843000/5207700
4844000/5207700
4845000/5207700
4846000/5207700
4847000/5207700
4848000/5207700
4849000/5207700
4850000/5207700
4851000/5207700
4852000/5207700
4853000/5207700
4854000/5207700
4855000/5207700
4856000/5207700
4857000/5207700
4858000/5207700
4859000/5207700
4860000/5207700
4861000/5207700
4862000/5207700
4863000/5207700
4864000/5207700
4865000/5207700
4866000/5207700
4867000/5207700
4868000/5207700
4869000/5207700
4870000/5207700
4871000/5207700
4872000/5207700
4873000/5207700
4874000/5207700
4875000/5207700
4876000/5207700
4877000/5207700
4878000/5207700
4879000/5207700
4880000/5207700
4881000/5207700
4882000/5207700
4883000/5207700
4884000/5207700
4885000/5207700
4886000/5207700
4887000/5207700
4888000/5207700
4889000/5207700
4890000/5207700
4891000/5207700
4892000/5207700
4893000/5207700
4894000/5207700
4895000/5207700
4896000/5207700
4897000/5207700
4898000/5207700
4899000/5207700
4900000/5207700
4901000/5207700
4902000/5207700
4903000/5207700
4904000/5207700
4905000/5207700
4906000/5207700
4907000/5207700
4908000/5207700
4909000/5207700
4910000/5207700
4911000/5207700
4912000/5207700
4913000/5207700
4914000/5207700
4915000/5207700
4916000/5207700
4917000/5207700
4918000/5207700
4919000/5207700
4920000/5207700
4921000/5207700
4922000/5207700
4923000/5207700
4924000/5207700
4925000/5207700
4926000/5207700
4927000/5207700
4928000/5207700
4929000/5207700
4930000/5207700
4931000/5207700
4932000/5207700
4933000/5207700
4934000/5207700
4935000/5207700
4936000/5207700
4937000/5207700
4938000/5207700
4939000/5207700
4940000/5207700
4941000/5207700
4942000/5207700
4943000/5207700
4944000/5207700
4945000/5207700
4946000/5207700
4947000/5207700
4948000/5207700
4949000/5207700
4950000/5207700
4951000/5207700
4952000/5207700
4953000/5207700
4954000/5207700
4955000/5207700
4956000/5207700
4957000/5207700
4958000/5207700
4959000/5207700
4960000/5207700
4961000/5207700
4962000/5207700
4963000/5207700
4964000/5207700
4965000/5207700
4966000/5207700
4967000/5207700
4968000/5207700
4969000/5207700
4970000/5207700
4971000/5207700
4972000/5207700
4973000/5207700
4974000/5207700
4975000/5207700
4976000/5207700
4977000/5207700
4978000/5207700
4979000/5207700
4980000/5207700
4981000/5207700
4982000/5207700
4983000/5207700
4984000/5207700
4985000/5207700
4986000/5207700
4987000/5207700
4988000/5207700
4989000/5207700
4990000/5207700
4991000/5207700
4992000/5207700
4993000/5207700
4994000/5207700
4995000/5207700
4996000/5207700
4997000/5207700
4998000/5207700
4999000/5207700
5000000/5207700
5001000/5207700
5002000/5207700
5003000/5207700
5004000/5207700
5005000/5207700
5006000/5207700
5007000/5207700
5008000/5207700
5009000/5207700
5010000/5207700
5011000/5207700
5012000/5207700
5013000/5207700
5014000/5207700
5015000/5207700
5016000/5207700
5017000/5207700
5018000/5207700
5019000/5207700
5020000/5207700
5021000/5207700
5022000/5207700
5023000/5207700
5024000/5207700
5025000/5207700
5026000/5207700
5027000/5207700
5028000/5207700
5029000/5207700
5030000/5207700
5031000/5207700
5032000/5207700
5033000/5207700
5034000/5207700
5035000/5207700
5036000/5207700
5037000/5207700
5038000/5207700
5039000/5207700
5040000/5207700
5041000/5207700
5042000/5207700
5043000/5207700
5044000/5207700
5045000/5207700
5046000/5207700
5047000/5207700
5048000/5207700
5049000/5207700
5050000/5207700
5051000/5207700
5052000/5207700
5053000/5207700
5054000/5207700
5055000/5207700
5056000/5207700
5057000/5207700
5058000/5207700
5059000/5207700
5060000/5207700
5061000/5207700
5062000/5207700
5063000/5207700
5064000/5207700
5065000/5207700
5066000/5207700
5067000/5207700
5068000/5207700
5069000/5207700
5070000/5207700
5071000/5207700
5072000/5207700
5073000/5207700
5074000/5207700
5075000/5207700
5076000/5207700
5077000/5207700
5078000/5207700
5079000/5207700
5080000/5207700
5081000/5207700
5082000/5207700
5083000/5207700
5084000/5207700
5085000/5207700
5086000/5207700
5087000/5207700
5088000/5207700
5089000/5207700
5090000/5207700
5091000/5207700
5092000/5207700
5093000/5207700
5094000/5207700
5095000/5207700
5096000/5207700
5097000/5207700
5098000/5207700
5099000/5207700
5100000/5207700
5101000/5207700
5102000/5207700
5103000/5207700
5104000/5207700
5105000/5207700
5106000/5207700
5107000/5207700
5108000/5207700
5109000/5207700
5110000/5207700
5111000/5207700
5112000/5207700
5113000/5207700
5114000/5207700
5115000/5207700
5116000/5207700
5117000/5207700
5118000/5207700
5119000/5207700
5120000/5207700
5121000/5207700
5122000/5207700
5123000/5207700
5124000/5207700
5125000/5207700
5126000/5207700
5127000/5207700
5128000/5207700
5129000/5207700
5130000/5207700
5131000/5207700
5132000/5207700
5133000/5207700
5134000/5207700
5135000/5207700
5136000/5207700
5137000/5207700
5138000/5207700
5139000/5207700
5140000/5207700
5141000/5207700
5142000/5207700
5143000/5207700
5144000/5207700
5145000/5207700
5146000/5207700
5147000/5207700
5148000/5207700
5149000/5207700
5150000/5207700
5151000/5207700
5152000/5207700
5153000/5207700
5154000/5207700
5155000/5207700
5156000/5207700
5157000/5207700
5158000/5207700
5159000/5207700
5160000/5207700
5161000/5207700
5162000/5207700
5163000/5207700
5164000/5207700
5165000/5207700
5166000/5207700
5167000/5207700
5168000/5207700
5169000/5207700
5170000/5207700
5171000/5207700
5172000/5207700
5173000/5207700
5174000/5207700
5175000/5207700
5176000/5207700
5177000/5207700
5178000/5207700
5179000/5207700
5180000/5207700
5181000/5207700
5182000/5207700
5183000/5207700
5184000/5207700
5185000/5207700
5186000/5207700
5187000/5207700
5188000/5207700
5189000/5207700
5190000/5207700
5191000/5207700
5192000/5207700
5193000/5207700
5194000/5207700
5195000/5207700
5196000/5207700
5197000/5207700
5198000/5207700
5199000/5207700
5200000/5207700
5201000/5207700
5202000/5207700
5203000/5207700
5204000/5207700
5205000/5207700
5206000/5207700
5207000/5207700
creating index...
index created!
Running per image evaluation...
Evaluate annotation type *bbox*
DONE (t=94.31s).
Accumulating evaluation results...
DONE (t=16.46s).
Average Recall     (AR) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.001AP: 0.000000598
AP50: 0.000003085
AP75: 0.000000089
APl: 0.000001397
APm: 0.000000705
APs: 0.000000000
ARl: 0.001165882
ARm: 0.001511795
ARmax1: 0.000011488
ARmax10: 0.000064007
ARmax100: 0.000942596
ARs: 0.000000000
Finished evaluation.
Trt_evaluate finished successfully.
2026-06-24 07:04:08,052 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - Telemetry data couldn't be sent, but the command ran successfully.
2026-06-24 07:04:08,052 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - 'str' object has no attribute 'decode'
2026-06-24 12:34:08,572 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 381: Stopping container.
Could you please set cal_batch_size: 8 to cal_batch_size: 1 as well?
More, please use all the calibration_data/image_2 to do calibration. Assume there are 1000 images under image_2folder, then use cal_batch_size: 1 and cal_batches: 1000.
Yes I had 2000 images for calibration.
Config:
# deploy_spec.yaml
gen_trt_engine:
  results_dir: /workspace/tao-experiments/results/trt_engine_logs
  onnx_file: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_FP32_V2.1.pth.onnx
  trt_engine: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_int8_b1_V2.1.pth.engine
  # input_channel: 3
  # input_width: 960
  # input_height: 544
  tensorrt:
    data_type: int8
    # data_type: fp16
    workspace_size: 2048
    min_batch_size: 1
    opt_batch_size: 1
    max_batch_size: 1
    calibration:
      cal_image_dir:
        - /workspace/tao-experiments/dataset/calibration_data/image_2
      cal_cache_file: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_FP32_b1_V2.1.pth.cache
      cal_batch_size: 1
      cal_batches: 2000
Engine Creation:
!tao deploy rtdetr gen_trt_engine -e /workspace/tao-experiments/specs/deploy.yaml
Output:
2026-06-24 12:47:12,807 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2026-06-24 12:47:12,891 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 360: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:6.26.3-deploy
2026-06-24 12:47:12,916 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 303:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/smarg/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
2026-06-24 12:47:12,916 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 316: Printing tty value True
2026-06-24 07:17:39,166 - nvidia_tao_core.microservices.utils.job_utils.workflow - INFO - Logging configured at level: INFO
2026-06-24 07:17:41,609 [TAO Toolkit] [INFO] nvidia_tao_core.microservices.utils.job_utils.workflow 61: Logging configured at level: INFOsys:1: UserWarning:
'deploy.yaml' is validated against ConfigStore schema with the same name.
This behavior is deprecated in Hydra 1.1 and will be removed in Hydra 1.2.
See https://hydra.cc/docs/1.2/upgrades/1.0_to_1.1/automatic_schema_matching for migration instructions.
/usr/local/lib/python3.12/dist-packages/nvidia_tao_deploy/cv/common/hydra/hydra_runner.py:99: UserWarning:
  _run_hydra(
/usr/local/lib/python3.12/dist-packages/hydra/_internal/hydra.py:119: UserWarning: Future Hydra versions will no longer change working directory at job runtime by default.
See https://hydra.cc/docs/1.2/upgrades/1.1_to_1.2/changes_to_job_working_dir/ for more information.
  ret = run_job(
Gen_trt_engine results will be saved at: /workspace/tao-experiments/results/trt_engine_logs
Log file already exists at /workspace/tao-experiments/results/trt_engine_logs/status.json
Starting rtdetr gen_trt_engine.
No QDQ quantization operators found in ONNX model.
[06/24/2026-07:17:43] [TRT] [I] [MemUsageChange] Init builder kernel library: CPU +988, GPU +4, now: CPU 1278, GPU 1006 (MiB)Setting up QAT mode: False
[06/24/2026-07:17:43] [TRT] [I] Successfully created plugin: MultiscaleDeformableAttnPlugin_TRTParsing ONNX modelin_namespace:istil_TeR50_StR18_Res352x576_FP32_V2.1.pth.onnx
List inputs:
Input 0 -> inputs.
(3, 352, 576).
-1.
Network Description
Input 'inputs' with shape (-1, 3, 352, 576) and dtype DataType.FLOAT
Output 'pred_logits' with shape (-1, 300, 4) and dtype DataType.FLOAT
Output 'pred_boxes' with shape (-1, 300, 4) and dtype DataType.FLOAT
Calibrating using ImageBatcher
TensorRT engine build configurations:
  OptimizationProfile:
    "inputs": (1, 3, 352, 576), (1, 3, 352, 576), (1, 3, 352, 576)
  BuilderFlag.FP16
  BuilderFlag.INT8
  BuilderFlag.TF32
  Note: max representabile value is 2,147,483,648 bytes or 2GB.
  MemoryPoolType.WORKSPACE = 2147483648 bytes
  MemoryPoolType.DLA_MANAGED_SRAM = 0 bytes
  MemoryPoolType.DLA_LOCAL_DRAM = 1073741824 bytes
  MemoryPoolType.DLA_GLOBAL_DRAM = 536870912 bytes
  MemoryPoolType.TACTIC_DRAM = 16606232576 bytes
  MemoryPoolType.TACTIC_SHARED_MEMORY = 1073741824 bytes
  Tactic Sources = 24
[06/24/2026-07:17:56] [TRT] [I] Starting Calibration.Calibrating image 1 / 2000 IExecutionContext creation: CPU +1, GPU +37, now: CPU 1, GPU 200 (MiB)
[06/24/2026-07:17:56] [TRT] [I]   Calibrated batch 0 in 0.113413 seconds.Calibrating image 2 / 2000
[06/24/2026-07:17:56] [TRT] [I]   Calibrated batch 1 in 0.0921267 seconds.Calibrating image 3 / 2000
[06/24/2026-07:17:56] [TRT] [I]   Calibrated batch 2 in 0.0925435 seconds.Calibrating image 4 / 2000
[06/24/2026-07:17:56] [TRT] [I]   Calibrated batch 3 in 0.0911896 seconds.Calibrating image 5 / 2000
[06/24/2026-07:21:12] [TRT] [I]   Calibrated batch 1949 in 0.0931209 seconds.Calibrating image 1951 / 2000
[06/24/2026-07:21:12] [TRT] [I]   Calibrated batch 1950 in 0.0922874 seconds.Calibrating image 1952 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1951 in 0.0938913 seconds.Calibrating image 1953 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1952 in 0.0941273 seconds.Calibrating image 1954 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1953 in 0.09567 seconds.Calibrating image 1955 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1954 in 0.0932714 seconds.Calibrating image 1956 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1955 in 0.0958846 seconds.Calibrating image 1957 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1956 in 0.100411 seconds.Calibrating image 1958 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1957 in 0.0919393 seconds.Calibrating image 1959 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1958 in 0.0949172 seconds.Calibrating image 1960 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1959 in 0.0978715 seconds.Calibrating image 1961 / 2000
[06/24/2026-07:21:13] [TRT] [I]   Calibrated batch 1960 in 0.0951132 seconds.Calibrating image 1962 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1961 in 0.0914142 seconds.Calibrating image 1963 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1962 in 0.0941141 seconds.Calibrating image 1964 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1963 in 0.0913625 seconds.Calibrating image 1965 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1964 in 0.0927355 seconds.Calibrating image 1966 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1965 in 0.0918398 seconds.Calibrating image 1967 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1966 in 0.093254 seconds.Calibrating image 1968 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1967 in 0.0933791 seconds.Calibrating image 1969 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1968 in 0.0929579 seconds.Calibrating image 1970 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1969 in 0.0943026 seconds.Calibrating image 1971 / 2000
[06/24/2026-07:21:14] [TRT] [I]   Calibrated batch 1970 in 0.0948589 seconds.Calibrating image 1972 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1971 in 0.0936986 seconds.Calibrating image 1973 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1972 in 0.0937983 seconds.Calibrating image 1974 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1973 in 0.0929412 seconds.Calibrating image 1975 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1974 in 0.092271 seconds.Calibrating image 1976 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1975 in 0.0912154 seconds.Calibrating image 1977 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1976 in 0.0903727 seconds.Calibrating image 1978 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1977 in 0.090926 seconds.Calibrating image 1979 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1978 in 0.0937416 seconds.Calibrating image 1980 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1979 in 0.093125 seconds.Calibrating image 1981 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1980 in 0.0925494 seconds.Calibrating image 1982 / 2000
[06/24/2026-07:21:15] [TRT] [I]   Calibrated batch 1981 in 0.0926928 seconds.Calibrating image 1983 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1982 in 0.0918817 seconds.Calibrating image 1984 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1983 in 0.0946339 seconds.Calibrating image 1985 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1984 in 0.093986 seconds.Calibrating image 1986 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1985 in 0.0914742 seconds.Calibrating image 1987 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1986 in 0.0948993 seconds.Calibrating image 1988 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1987 in 0.0942293 seconds.Calibrating image 1989 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1988 in 0.0925301 seconds.Calibrating image 1990 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1989 in 0.0915057 seconds.Calibrating image 1991 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1990 in 0.0921244 seconds.Calibrating image 1992 / 2000
[06/24/2026-07:21:16] [TRT] [I]   Calibrated batch 1991 in 0.0936717 seconds.Calibrating image 1993 / 2000
[06/24/2026-07:21:17] [TRT] [I]   Calibrated batch 1992 in 0.0931653 seconds.Calibrating image 1994 / 2000
[06/24/2026-07:21:17] [TRT] [I]   Calibrated batch 1993 in 0.0928472 seconds.Calibrating image 1995 / 2000
[06/24/2026-07:21:17] [TRT] [I]   Calibrated batch 1994 in 0.0953929 seconds.Calibrating image 1996 / 2000
[06/24/2026-07:21:17] [TRT] [I]   Calibrated batch 1995 in 0.0927962 seconds.Calibrating image 1997 / 2000
[06/24/2026-07:21:17] [TRT] [I]   Calibrated batch 1996 in 0.0928374 seconds.Calibrating image 1998 / 2000
[06/24/2026-07:21:17] [TRT] [I]   Calibrated batch 1997 in 0.0943617 seconds.Calibrating image 1999 / 2000
[06/24/2026-07:21:17] [TRT] [I]   Calibrated batch 1998 in 0.0911414 seconds.Calibrating image 2000 / 2000
[06/24/2026-07:21:17] [TRT] [I]   Calibrated batch 1999 in 0.0912571 seconds.Finished calibration batches
[06/24/2026-07:23:23] [TRT] [I] Writing Calibration Cache for calibrator: TRT-101303-EntropyCalibration2Writing calibration cache data to: /workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_FP32_b1_V2.1.pth.cache
[06/24/2026-07:26:31] [TRT] [I] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 16 MiB, GPU 200 MiBequiring 17818112 bytes.or any layer consuming or producing given tensoroducing given tensororn tensorEngine build finished successfully.
Gen_trt_engine finished successfully.
2026-06-24 07:26:32,677 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - Telemetry data couldn't be sent, but the command ran successfully.
2026-06-24 07:26:32,677 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - 'str' object has no attribute 'decode'
2026-06-24 12:56:33,073 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 381: Stopping container.
Engine Evaluation:
Command:
!tao deploy rtdetr evaluate \
    -e /workspace/tao-experiments/specs/eval_engine.yaml \
    results_dir=/workspace/tao-experiments/results/trt_evaluation \
    evaluate.trt_engine=/workspace/tao-experiments/results/student/distill/VehicleDetection_RtDetr_Distil_TeR50_StR18_Res352x576_int8_b1_V2.1.pth.engine
Output:
2026-06-24 12:57:46,781 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2026-06-24 12:57:46,862 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 360: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:6.26.3-deploy
2026-06-24 12:57:46,886 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 303:
terminal.
2026-06-24 12:57:46,886 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 316: Printing tty value True
2026-06-24 07:27:48,903 - nvidia_tao_core.microservices.utils.job_utils.workflow - INFO - Logging configured at level: INFO
2026-06-24 07:27:51,504 - nvidia_tao_core.microservices.utils.job_utils.workflow - INFO - Logging configured at level: INFO
sys:1: UserWarning:
'eval_engine.yaml' is validated against ConfigStore schema with the same name.
  _run_hydra(
  ret = run_job(
Trt_evaluate results will be saved at: /workspace/tao-experiments/results/trt_evaluation/trt_evaluate
Log file already exists at /workspace/tao-experiments/results/trt_evaluation/trt_evaluate/status.json
Starting rtdetr trt_evaluate.
loading annotations into memory...
Done (t=0.45s)
creating index...
index created!
Done (t=0.35s)
creating index...
index created!
Producing predictions: 100%|██████████| 17359/17359 [04:08<00:00, 69.80it/s]]Loading and preparing results...
0/5207700
5207000/5207700
creating index...
index created!
DONE (t=94.30s).
DONE (t=13.95s).
Average Recall     (AR) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.000AP: 0.000002765
AP50: 0.000006275
AP75: 0.000002326
APl: 0.000003810
APm: 0.000003026
APs: 0.000000000
ARl: 0.000341183
ARm: 0.000822613
ARmax1: 0.000085890
ARmax10: 0.000094096
ARmax100: 0.000436559
ARs: 0.000000000
2026-06-24 07:34:18,797 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - Telemetry data couldn't be sent, but the command ran successfully.
2026-06-24 07:34:18,797 - nvidia_tao_deploy.cv.common.entrypoint.entrypoint_hydra - WARNING - 'str' object has no attribute 'decode'
2026-06-24 13:04:19,337 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 381: Stopping container.
Still it is Zero.
OK, seems that this specific 576x352 distilled RT-DETR model is not quantizing robustly with PTQ INT8. You can train/distill/PTQ with more larger size(such as 768x448 and 864x480).
Okay.
