$inference_spec points to a directory that is blank
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
I mean you need to set $inference_spec to the explicit path.
Because you have set this env in the notebook, but currently you are running inside the docker. Then env is not set yet. You can set the env or set an explicit path.
