Any time I run Tao (ie. tao spectro_gen pitch_stats) i get the warning below:
[NeMo W 2022-12-13 16:36:41 init :22] pynini
is not installed !
Please run the nemo_text_processing/setup.sh
script prior to usage of this toolkit.
I am certain that NeMo is installed properly on my local machine (2.1.5). Is this an issue with the TAO docker, or something specific to my setup?
• Hardware (3080ti, AMD Ryzen 7 5800X, 32Gb RAM)
• Network Type (FastPitch and HiFiGAN)
• TAO Version (v3.21.11-tf1.15.5-py3)
After completely reinstalling all tao and nvidia docker related packages, this error has disappeared, but now it gets stuck at “Sending telemetry data” and never fully completes. The docker container version has changed to 4.0.0-tf2.9.1
Morganh
December 14, 2022, 1:49am
3
Could you share the full command and full log for the latest stuck at “Sending telemetry data” ?
Morganh
December 15, 2022, 4:42am
4
To narrow down, could you try to login the docker via below way and then run previous command without “tao”?
Morganh
December 16, 2022, 12:42am
5
Above comment is just for narrowing down.
After checking internally, could you please try to follow your previous test method to try again?
Hi @Morganh , it ran that command just fine when logging into the docker directly
Morganh
December 16, 2022, 1:20am
7
OK, please follow your original test method to try again.
The issues seems to have gone away :)
Morganh
December 16, 2022, 1:48am
9
Thanks for the confirmation.
system
Closed
January 3, 2023, 3:25am
10
