• Hardware (GTX 1050ti)
• Network Type (ActionRecognitionNet)
• TLT Version (4.0.0-pyt)
• Training spec file(
train_rgb_3d_64_i3d.yaml (949 Bytes)
• How to reproduce the issue? (tao action_recognition train -e /workspace/tao-experiments/specs/train_rgb_3d_64_i3d.yaml -r /workspace/tao-experiments/result -k OW41MDI1N21ra3ZvdHRjMjY3ZzY5aTA0ZWs6YjFkYTM3NDEtMGFmYi00NGFkLTgyYTUtYzA2Yzc1ZWMyZTJi model_config.rgb_pretrained_model_path=/workspace/tao-experiments/models/resnet18_3d_of_hmdb5_32_a100.tlt)
After running the above command, I’m getting mentioned below error message:
_pickle.UnpicklingError: invalid load key, ‘\xbe’.
Please find below the complete error message log:
Error executing job with overrides: ['output_dir=/workspace/tao-experiments/result', 'encryption_key=$KEY', 'model_config.rgb_pretrained_model_path=/workspace/tao-experiments/models/resnet18_3d_of_hmdb5_32_a100.tlt']
An error occurred during Hydra's exception formatting:
AssertionError()
File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 252, in run_and_report
assert mdl is not None
AssertionError
During handling of the above exception, another exception occurred:
File "</opt/conda/lib/python3.8/site-packages/nvidia_tao_pytorch/cv/action_recognition/scripts/train.py>", line 3, in <module>
File "<frozen cv.action_recognition.scripts.train>", line 81, in <module>
File "<frozen cv.super_resolution.scripts.configs.hydra_runner>", line 99, in wrapper
File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 377, in _run_hydra
run_and_report(
File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 294, in run_and_report
raise ex
File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 211, in run_and_report
return func()
File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 378, in <lambda>
lambda: hydra.run(
File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/hydra.py", line 111, in run
_ = ret.return_value
File "/opt/conda/lib/python3.8/site-packages/hydra/core/utils.py", line 233, in return_value
raise self._return_value
File "/opt/conda/lib/python3.8/site-packages/hydra/core/utils.py", line 160, in run_job
ret.return_value = task_function(task_cfg)
File "<frozen cv.action_recognition.scripts.train>", line 75, in main
File "<frozen cv.action_recognition.scripts.train>", line 30, in run_experiment
File "<frozen cv.action_recognition.model.pl_ar_model>", line 33, in __init__
File "<frozen cv.action_recognition.model.pl_ar_model>", line 39, in _build_model
File "<frozen cv.action_recognition.model.build_nn_model>", line 76, in build_ar_model
File "<frozen cv.action_recognition.model.ar_model>", line 97, in get_basemodel3d
File "<frozen cv.action_recognition.model.ar_model>", line 31, in load_pretrained_weights
File "<frozen cv.action_recognition.utils.common_utils>", line 29, in patch_decrypt_checkpoint
File "<frozen core.checkpoint_encryption>", line 30, in decrypt_checkpoint
_pickle.UnpicklingError: invalid load key, '\xbe'.
Execution status: FAIL
2023-08-31 12:28:25,383 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
