My Issue is I am simply training a person dataset from Roboflow, however the training set is currently mean average precision is shooting up to 4.0952 which to my understanding is 400%.
Or am I missing something, is it just 4% now? because from the tensorboard when i saw the inference there are lots of false detections and loss of detections as well.
• Hardware (RTX3060)
• Network Type (Detectnet_v2)
• TLT Version (tao-toolkit:5.0.0-tf1.15.5)
• Training spec file(If have, please share here)
model_config {
arch: “resnet”
all_projections: True
num_layers: 18
use_pooling: True
use_batch_norm: True
dropout_rate: 0.0
objective_set: {
cov {}
bbox {
scale: 35.0
offset: 0.5
bbox_rasterizer_config {
target_class_config {
key: “person”
value: {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
bbox_min_radius: 1.0
deadzone_radius: 0.67
training_config {
batch_size_per_gpu: 16
num_epochs: 100
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-6
max_learning_rate: 5e-4
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
epsilon: 1e-08
beta1: 0.9
beta2: 0.999
cost_scaling {
enabled: true
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
visualizer {
enabled: true
num_images: 3
scalar_logging_frequency: 10
infrequent_logging_frequency: 1
key: “person”
value: {
coverage_threshold: 0.005
postprocessing_config {
key: “person”
value: {
clustering_config {
dbscan_eps: 0.15
dbscan_min_samples: 1
minimum_bounding_box_height: 20
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
enable_autoweighting: True
max_objective_weight: 0.9999
min_objective_weight: 0.0001
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 544
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
color_shift_stddev: 0.0
hue_rotation_max: 25.0
saturation_shift_max: 0.2
contrast_scale_max: 0.1
contrast_center: 0.5
evaluation_config {
average_precision_mode: INTEGRATE
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: “person”
value: 0.5
evaluation_box_config {
key: “person”
value {
minimum_height: 4
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
dataset_config {
data_sources: {
tfrecords_path: “/workspace/tao-experiments/head_coco_dataset-fold-*”
image_directory_path: “/workspace/tao-experiments/head_coco”
image_extension: “jpg”
target_class_mapping {
key: “person”
value: “person”
validation_data_source: {
Status.json
{“date”: “9/30/2025”, “time”: “3:19:58”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.404430627822876, “learning_rate”: “4.9999994e-06”}, “kpi”: {“validation cost”: 0.24861654, “mean average precision”: 0.0}}
{“epoch”: 1, “max_epoch”: 100, “time_per_epoch”: “0:04:15.080275”, “eta”: “7:00:52.947254”, “date”: “9/30/2025”, “time”: “3:20:1”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.20976409316062927, “learning_rate”: “7.924464e-06”}, “kpi”: {“validation cost”: 0.24861654, “mean average precision”: 0.0}}
{“epoch”: 2, “max_epoch”: 100, “time_per_epoch”: “0:02:14.991050”, “eta”: “3:40:29.122854”, “date”: “9/30/2025”, “time”: “3:22:14”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.19671112298965454, “learning_rate”: “1.2559428e-05”}, “kpi”: {“validation cost”: 0.24861654, “mean average precision”: 0.0}}
{“date”: “9/30/2025”, “time”: “3:23:47”, “status”: “STARTED”, “verbosity”: “INFO”, “message”: “Starting DetectNet_v2 Training job”}
{“date”: “9/30/2025”, “time”: “3:23:47”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Training gridbox model.”}
{“date”: “9/30/2025”, “time”: “3:23:49”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Building DetectNet V2 model”}
{“date”: “9/30/2025”, “time”: “3:23:50”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “DetectNet V2 model built.”}
{“date”: “9/30/2025”, “time”: “3:23:50”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Building rasterizer.”}
{“date”: “9/30/2025”, “time”: “3:23:50”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Rasterizers built.”}
{“date”: “9/30/2025”, “time”: “3:23:50”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Building training graph.”}
{“date”: “9/30/2025”, “time”: “3:23:53”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Rasterizing tensors.”}
{“date”: “9/30/2025”, “time”: “3:23:53”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Tensors rasterized.”}
{“date”: “9/30/2025”, “time”: “3:23:55”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Training graph built.”}
{“date”: “9/30/2025”, “time”: “3:23:55”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Building validation graph.”}
{“date”: “9/30/2025”, “time”: “3:23:55”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Rasterizing tensors.”}
{“date”: “9/30/2025”, “time”: “3:23:55”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Tensors rasterized.”}
{“date”: “9/30/2025”, “time”: “3:23:55”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Validation graph built.”}
{“date”: “9/30/2025”, “time”: “3:23:56”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Running training loop.”}
{“epoch”: 0, “max_epoch”: 100, “time_per_epoch”: “0:00:00”, “eta”: “0:00:00”, “date”: “9/30/2025”, “time”: “3:24:39”, “status”: “RUNNING”, “verbosity”: “INFO”, “graphical”: {“loss”: 0.4044340252876282, “learning_rate”: “4.9999994e-06”}}
{“date”: “9/30/2025”, “time”: “3:28:22”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.4044340252876282, “learning_rate”: “4.9999994e-06”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 1, “max_epoch”: 100, “time_per_epoch”: “0:04:10.378934”, “eta”: “6:53:07.514433”, “date”: “9/30/2025”, “time”: “3:28:24”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.2099231630563736, “learning_rate”: “7.924464e-06”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 2, “max_epoch”: 100, “time_per_epoch”: “0:02:12.502018”, “eta”: “3:36:25.197808”, “date”: “9/30/2025”, “time”: “3:30:35”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.1956145167350769, “learning_rate”: “1.2559428e-05”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 3, “max_epoch”: 100, “time_per_epoch”: “0:02:12.429793”, “eta”: “3:34:05.689886”, “date”: “9/30/2025”, “time”: “3:32:47”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.17567414045333862, “learning_rate”: “1.990535e-05”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 4, “max_epoch”: 100, “time_per_epoch”: “0:02:11.806518”, “eta”: “3:30:53.425690”, “date”: “9/30/2025”, “time”: “3:34:59”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.18284818530082703, “learning_rate”: “3.154785e-05”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 5, “max_epoch”: 100, “time_per_epoch”: “0:02:11.481423”, “eta”: “3:28:10.735153”, “date”: “9/30/2025”, “time”: “3:37:11”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.1571374386548996, “learning_rate”: “4.999997e-05”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 6, “max_epoch”: 100, “time_per_epoch”: “0:02:12.037913”, “eta”: “3:26:51.563785”, “date”: “9/30/2025”, “time”: “3:39:23”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.1412360668182373, “learning_rate”: “7.924468e-05”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 7, “max_epoch”: 100, “time_per_epoch”: “0:02:11.484504”, “eta”: “3:23:48.058915”, “date”: “9/30/2025”, “time”: “3:41:34”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.12434294819831848, “learning_rate”: “0.00012559434”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 8, “max_epoch”: 100, “time_per_epoch”: “0:02:11.370558”, “eta”: “3:21:26.091294”, “date”: “9/30/2025”, “time”: “3:43:46”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.1364600658416748, “learning_rate”: “0.0001990536”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 9, “max_epoch”: 100, “time_per_epoch”: “0:02:11.525963”, “eta”: “3:19:28.862639”, “date”: “9/30/2025”, “time”: “3:45:57”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.1269717812538147, “learning_rate”: “0.00031547868”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“epoch”: 10, “max_epoch”: 100, “time_per_epoch”: “0:02:12.885961”, “eta”: “3:19:19.736452”, “date”: “9/30/2025”, “time”: “3:48:10”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0}}, “graphical”: {“loss”: 0.1143883764743805, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.24905401, “mean average precision”: 0.0}}
{“date”: “9/30/2025”, “time”: “3:51:27”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.1143883764743805, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 11, “max_epoch”: 100, “time_per_epoch”: “0:03:17.874772”, “eta”: “4:53:30.854714”, “date”: “9/30/2025”, “time”: “3:51:28”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.12403935939073563, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 12, “max_epoch”: 100, “time_per_epoch”: “0:02:14.014062”, “eta”: “3:16:33.237492”, “date”: “9/30/2025”, “time”: “3:53:42”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.1133691668510437, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 13, “max_epoch”: 100, “time_per_epoch”: “0:02:12.168556”, “eta”: “3:11:38.664411”, “date”: “9/30/2025”, “time”: “3:55:54”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.10995160788297653, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 14, “max_epoch”: 100, “time_per_epoch”: “0:02:13.514683”, “eta”: “3:11:22.262780”, “date”: “9/30/2025”, “time”: “3:58:7”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.10176346451044083, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 15, “max_epoch”: 100, “time_per_epoch”: “0:02:13.899862”, “eta”: “3:09:41.488254”, “date”: “9/30/2025”, “time”: “4:0:21”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.10129997134208679, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 16, “max_epoch”: 100, “time_per_epoch”: “0:02:13.472258”, “eta”: “3:06:51.669700”, “date”: “9/30/2025”, “time”: “4:2:35”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.09512515366077423, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 17, “max_epoch”: 100, “time_per_epoch”: “0:02:11.886167”, “eta”: “3:02:26.551865”, “date”: “9/30/2025”, “time”: “4:4:47”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.10050839185714722, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 18, “max_epoch”: 100, “time_per_epoch”: “0:02:09.674380”, “eta”: “2:57:13.299185”, “date”: “9/30/2025”, “time”: “4:6:56”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.09863967448472977, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 19, “max_epoch”: 100, “time_per_epoch”: “0:02:09.570286”, “eta”: “2:54:55.193130”, “date”: “9/30/2025”, “time”: “4:9:6”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.11210843920707703, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“epoch”: 20, “max_epoch”: 100, “time_per_epoch”: “0:02:10.634506”, “eta”: “2:54:10.760441”, “date”: “9/30/2025”, “time”: “4:11:17”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.035}}, “graphical”: {“loss”: 0.09492345154285431, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.13437318, “mean average precision”: 0.035}}
{“date”: “9/30/2025”, “time”: “4:14:29”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.09492345154285431, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 21, “max_epoch”: 100, “time_per_epoch”: “0:03:13.016746”, “eta”: “4:14:08.322937”, “date”: “9/30/2025”, “time”: “4:14:30”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.09396826475858688, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 22, “max_epoch”: 100, “time_per_epoch”: “0:02:09.551654”, “eta”: “2:48:25.029038”, “date”: “9/30/2025”, “time”: “4:16:39”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.0998244360089302, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 23, “max_epoch”: 100, “time_per_epoch”: “0:02:09.602973”, “eta”: “2:46:19.428883”, “date”: “9/30/2025”, “time”: “4:18:49”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.0872088372707367, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 24, “max_epoch”: 100, “time_per_epoch”: “0:02:09.669931”, “eta”: “2:44:14.914769”, “date”: “9/30/2025”, “time”: “4:20:58”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.08118899911642075, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 25, “max_epoch”: 100, “time_per_epoch”: “0:02:09.569647”, “eta”: “2:41:57.723513”, “date”: “9/30/2025”, “time”: “4:23:8”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.0845017209649086, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 26, “max_epoch”: 100, “time_per_epoch”: “0:02:09.585279”, “eta”: “2:39:49.310645”, “date”: “9/30/2025”, “time”: “4:25:18”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.08165459334850311, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 27, “max_epoch”: 100, “time_per_epoch”: “0:02:09.911366”, “eta”: “2:38:03.529682”, “date”: “9/30/2025”, “time”: “4:27:28”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.08103282004594803, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 28, “max_epoch”: 100, “time_per_epoch”: “0:02:09.569090”, “eta”: “2:35:28.974506”, “date”: “9/30/2025”, “time”: “4:29:37”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.09038716554641724, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 29, “max_epoch”: 100, “time_per_epoch”: “0:02:09.480799”, “eta”: “2:33:13.136709”, “date”: “9/30/2025”, “time”: “4:31:47”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.08249232172966003, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“epoch”: 30, “max_epoch”: 100, “time_per_epoch”: “0:02:10.444663”, “eta”: “2:32:11.126397”, “date”: “9/30/2025”, “time”: “4:33:57”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.0771}}, “graphical”: {“loss”: 0.07102286070585251, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.11266375, “mean average precision”: 0.0771}}
{“date”: “9/30/2025”, “time”: “4:37:10”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.07102286070585251, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 31, “max_epoch”: 100, “time_per_epoch”: “0:03:13.743084”, “eta”: “3:42:48.272826”, “date”: “9/30/2025”, “time”: “4:37:11”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.08345421403646469, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 32, “max_epoch”: 100, “time_per_epoch”: “0:02:09.545792”, “eta”: “2:26:49.113831”, “date”: “9/30/2025”, “time”: “4:39:20”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.0773557648062706, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 33, “max_epoch”: 100, “time_per_epoch”: “0:02:09.618582”, “eta”: “2:24:44.445027”, “date”: “9/30/2025”, “time”: “4:41:30”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.07543889433145523, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 34, “max_epoch”: 100, “time_per_epoch”: “0:02:09.681843”, “eta”: “2:22:39.001657”, “date”: “9/30/2025”, “time”: “4:43:40”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.08766428381204605, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 35, “max_epoch”: 100, “time_per_epoch”: “0:02:09.811540”, “eta”: “2:20:37.750077”, “date”: “9/30/2025”, “time”: “4:45:49”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.0708388239145279, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 36, “max_epoch”: 100, “time_per_epoch”: “0:02:09.751746”, “eta”: “2:18:24.111771”, “date”: “9/30/2025”, “time”: “4:47:59”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.08282347768545151, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 37, “max_epoch”: 100, “time_per_epoch”: “0:02:09.714375”, “eta”: “2:16:12.005641”, “date”: “9/30/2025”, “time”: “4:50:9”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.06885235756635666, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 38, “max_epoch”: 100, “time_per_epoch”: “0:02:09.714933”, “eta”: “2:14:02.325856”, “date”: “9/30/2025”, “time”: “4:52:19”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.06692330539226532, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 39, “max_epoch”: 100, “time_per_epoch”: “0:02:09.826357”, “eta”: “2:11:59.407770”, “date”: “9/30/2025”, “time”: “4:54:28”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.06867922097444534, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“epoch”: 40, “max_epoch”: 100, “time_per_epoch”: “0:02:10.488129”, “eta”: “2:10:29.287763”, “date”: “9/30/2025”, “time”: “4:56:39”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.4242}}, “graphical”: {“loss”: 0.06795738637447357, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.08068494, “mean average precision”: 0.4242}}
{“date”: “9/30/2025”, “time”: “4:59:53”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.06795738637447357, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 41, “max_epoch”: 100, “time_per_epoch”: “0:03:14.843125”, “eta”: “3:11:35.744367”, “date”: “9/30/2025”, “time”: “4:59:54”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.07392945140600204, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 42, “max_epoch”: 100, “time_per_epoch”: “0:02:10.662194”, “eta”: “2:06:18.407239”, “date”: “9/30/2025”, “time”: “5:2:4”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.061782531440258026, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 43, “max_epoch”: 100, “time_per_epoch”: “0:02:11.300570”, “eta”: “2:04:44.132491”, “date”: “9/30/2025”, “time”: “5:4:16”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.06186389550566673, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 44, “max_epoch”: 100, “time_per_epoch”: “0:02:09.878021”, “eta”: “2:01:13.169163”, “date”: “9/30/2025”, “time”: “5:6:26”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.07462797313928604, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 45, “max_epoch”: 100, “time_per_epoch”: “0:02:09.671085”, “eta”: “1:58:51.909668”, “date”: “9/30/2025”, “time”: “5:8:35”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.05940079316496849, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 46, “max_epoch”: 100, “time_per_epoch”: “0:02:09.789669”, “eta”: “1:56:48.642141”, “date”: “9/30/2025”, “time”: “5:10:45”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.07930578291416168, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 47, “max_epoch”: 100, “time_per_epoch”: “0:02:09.921391”, “eta”: “1:54:45.833698”, “date”: “9/30/2025”, “time”: “5:12:55”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.06578066945075989, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 48, “max_epoch”: 100, “time_per_epoch”: “0:02:09.592834”, “eta”: “1:52:18.827368”, “date”: “9/30/2025”, “time”: “5:15:5”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.06182970106601715, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 49, “max_epoch”: 100, “time_per_epoch”: “0:02:09.790911”, “eta”: “1:50:19.336471”, “date”: “9/30/2025”, “time”: “5:17:14”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.06735049188137054, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“epoch”: 50, “max_epoch”: 100, “time_per_epoch”: “0:02:10.866373”, “eta”: “1:49:03.318629”, “date”: “9/30/2025”, “time”: “5:19:25”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8251}}, “graphical”: {“loss”: 0.056647732853889465, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.06829815, “mean average precision”: 0.8251}}
{“date”: “9/30/2025”, “time”: “5:22:39”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.056647732853889465, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 51, “max_epoch”: 100, “time_per_epoch”: “0:03:13.827450”, “eta”: “2:38:17.545028”, “date”: “9/30/2025”, “time”: “5:22:39”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.0622844323515892, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 52, “max_epoch”: 100, “time_per_epoch”: “0:02:09.983496”, “eta”: “1:43:59.207829”, “date”: “9/30/2025”, “time”: “5:24:49”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.06122328341007233, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 53, “max_epoch”: 100, “time_per_epoch”: “0:02:08.735008”, “eta”: “1:40:50.545376”, “date”: “9/30/2025”, “time”: “5:26:58”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.05108253285288811, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 54, “max_epoch”: 100, “time_per_epoch”: “0:02:09.974349”, “eta”: “1:39:38.820066”, “date”: “9/30/2025”, “time”: “5:29:8”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.06568079441785812, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 55, “max_epoch”: 100, “time_per_epoch”: “0:02:09.820657”, “eta”: “1:37:21.929544”, “date”: “9/30/2025”, “time”: “5:31:18”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.05669553950428963, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 56, “max_epoch”: 100, “time_per_epoch”: “0:02:10.073460”, “eta”: “1:35:23.232224”, “date”: “9/30/2025”, “time”: “5:33:28”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.05038151517510414, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 57, “max_epoch”: 100, “time_per_epoch”: “0:02:09.863137”, “eta”: “1:33:04.114881”, “date”: “9/30/2025”, “time”: “5:35:38”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.05699966102838516, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 58, “max_epoch”: 100, “time_per_epoch”: “0:02:10.016340”, “eta”: “1:31:00.686271”, “date”: “9/30/2025”, “time”: “5:37:48”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.05744409188628197, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 59, “max_epoch”: 100, “time_per_epoch”: “0:02:09.960656”, “eta”: “1:28:48.386903”, “date”: “9/30/2025”, “time”: “5:39:57”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.05008644238114357, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“epoch”: 60, “max_epoch”: 100, “time_per_epoch”: “0:02:11.079690”, “eta”: “1:27:23.187599”, “date”: “9/30/2025”, “time”: “5:42:9”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 0.8148}}, “graphical”: {“loss”: 0.05636274814605713, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.07057582, “mean average precision”: 0.8148}}
{“date”: “9/30/2025”, “time”: “5:45:22”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.05636274814605713, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 61, “max_epoch”: 100, “time_per_epoch”: “0:03:13.940118”, “eta”: “2:06:03.664586”, “date”: “9/30/2025”, “time”: “5:45:23”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.055028483271598816, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 62, “max_epoch”: 100, “time_per_epoch”: “0:02:09.410680”, “eta”: “1:21:57.605824”, “date”: “9/30/2025”, “time”: “5:47:32”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.06432587653398514, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 63, “max_epoch”: 100, “time_per_epoch”: “0:02:09.974692”, “eta”: “1:20:09.063599”, “date”: “9/30/2025”, “time”: “5:49:42”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.055571895092725754, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 64, “max_epoch”: 100, “time_per_epoch”: “0:02:09.963825”, “eta”: “1:17:58.697708”, “date”: “9/30/2025”, “time”: “5:51:52”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.04877893999218941, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 65, “max_epoch”: 100, “time_per_epoch”: “0:02:09.663894”, “eta”: “1:15:38.236296”, “date”: “9/30/2025”, “time”: “5:54:2”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.05168722942471504, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 66, “max_epoch”: 100, “time_per_epoch”: “0:02:09.924422”, “eta”: “1:13:37.430333”, “date”: “9/30/2025”, “time”: “5:56:11”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.053638607263565063, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 67, “max_epoch”: 100, “time_per_epoch”: “0:02:09.893441”, “eta”: “1:11:26.483552”, “date”: “9/30/2025”, “time”: “5:58:21”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.05979212373495102, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 68, “max_epoch”: 100, “time_per_epoch”: “0:02:09.818014”, “eta”: “1:09:14.176445”, “date”: “9/30/2025”, “time”: “6:0:31”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.05115517973899841, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 69, “max_epoch”: 100, “time_per_epoch”: “0:02:09.830847”, “eta”: “1:07:04.756243”, “date”: “9/30/2025”, “time”: “6:2:41”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.06259104609489441, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“epoch”: 70, “max_epoch”: 100, “time_per_epoch”: “0:02:10.790578”, “eta”: “1:05:23.717351”, “date”: “9/30/2025”, “time”: “6:4:52”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.3909}}, “graphical”: {“loss”: 0.059487227350473404, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05145665, “mean average precision”: 1.3909}}
{“date”: “9/30/2025”, “time”: “6:8:5”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.059487227350473404, “learning_rate”: “0.00049999997”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 71, “max_epoch”: 100, “time_per_epoch”: “0:03:14.106615”, “eta”: “1:33:49.091830”, “date”: “9/30/2025”, “time”: “6:8:6”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.059290021657943726, “learning_rate”: “0.00042884806”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 72, “max_epoch”: 100, “time_per_epoch”: “0:02:09.636771”, “eta”: “1:00:29.829580”, “date”: “9/30/2025”, “time”: “6:10:16”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.046074651181697845, “learning_rate”: “0.0003678212”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 73, “max_epoch”: 100, “time_per_epoch”: “0:02:09.877580”, “eta”: “0:58:26.694664”, “date”: “9/30/2025”, “time”: “6:12:25”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.04747997969388962, “learning_rate”: “0.00031547897”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 74, “max_epoch”: 100, “time_per_epoch”: “0:02:09.899544”, “eta”: “0:56:17.388156”, “date”: “9/30/2025”, “time”: “6:14:35”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.045363109558820724, “learning_rate”: “0.0002705846”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 75, “max_epoch”: 100, “time_per_epoch”: “0:02:09.693707”, “eta”: “0:54:02.342675”, “date”: “9/30/2025”, “time”: “6:16:45”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.03633156046271324, “learning_rate”: “0.00023207937”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 76, “max_epoch”: 100, “time_per_epoch”: “0:02:10.028047”, “eta”: “0:52:00.673124”, “date”: “9/30/2025”, “time”: “6:18:55”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.04404548555612564, “learning_rate”: “0.0001990536”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 77, “max_epoch”: 100, “time_per_epoch”: “0:02:09.716488”, “eta”: “0:49:43.479216”, “date”: “9/30/2025”, “time”: “6:21:5”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.03986875340342522, “learning_rate”: “0.00017072751”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 78, “max_epoch”: 100, “time_per_epoch”: “0:02:10.016083”, “eta”: “0:47:40.353826”, “date”: “9/30/2025”, “time”: “6:23:15”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.03458838909864426, “learning_rate”: “0.00014643234”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 79, “max_epoch”: 100, “time_per_epoch”: “0:02:09.884801”, “eta”: “0:45:27.580824”, “date”: “9/30/2025”, “time”: “6:25:25”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.040294330567121506, “learning_rate”: “0.00012559434”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“epoch”: 80, “max_epoch”: 100, “time_per_epoch”: “0:02:10.686687”, “eta”: “0:43:33.733745”, “date”: “9/30/2025”, “time”: “6:27:35”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 1.1293}}, “graphical”: {“loss”: 0.03988732770085335, “learning_rate”: “0.00010772168”}, “kpi”: {“validation cost”: 0.05468823, “mean average precision”: 1.1293}}
{“date”: “9/30/2025”, “time”: “6:30:50”, “status”: “RUNNING”, “verbosity”: “INFO”, “message”: “Evaluation metrics generated.”, “categorical”: {“average_precision”: {“person”: 4.0952}}, “graphical”: {“loss”: 0.03988732770085335, “learning_rate”: “0.00010772168”}, “kpi”: {“validation cost”: 0.03309437, “mean average precision”: 4.0952}}
{“epoch”: 81, “max_epoch”: 100, “time_per_epoch”: “0:03:14.714617”, “eta”: “1:01:39.577719”, “date”: “9/30/2025”, “time”: “6:30:50”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 4.0952}}, “graphical”: {“loss”: 0.040571920573711395, “learning_rate”: “9.239248e-05”}, “kpi”: {“validation cost”: 0.03309437, “mean average precision”: 4.0952}}
{“epoch”: 82, “max_epoch”: 100, “time_per_epoch”: “0:02:09.591179”, “eta”: “0:38:52.641220”, “date”: “9/30/2025”, “time”: “6:33:0”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 4.0952}}, “graphical”: {“loss”: 0.036677874624729156, “learning_rate”: “7.924468e-05”}, “kpi”: {“validation cost”: 0.03309437, “mean average precision”: 4.0952}}
{“epoch”: 83, “max_epoch”: 100, “time_per_epoch”: “0:02:09.995054”, “eta”: “0:36:49.915914”, “date”: “9/30/2025”, “time”: “6:35:10”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 4.0952}}, “graphical”: {“loss”: 0.03213275223970413, “learning_rate”: “6.7967856e-05”}, “kpi”: {“validation cost”: 0.03309437, “mean average precision”: 4.0952}}
{“epoch”: 84, “max_epoch”: 100, “time_per_epoch”: “0:02:09.870754”, “eta”: “0:34:37.932056”, “date”: “9/30/2025”, “time”: “6:37:20”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 4.0952}}, “graphical”: {“loss”: 0.040249571204185486, “learning_rate”: “5.829572e-05”}, “kpi”: {“validation cost”: 0.03309437, “mean average precision”: 4.0952}}
{“epoch”: 85, “max_epoch”: 100, “time_per_epoch”: “0:02:09.903138”, “eta”: “0:32:28.547065”, “date”: “9/30/2025”, “time”: “6:39:29”, “status”: “RUNNING”, “verbosity”: “INFO”, “categorical”: {“average_precision”: {“person”: 4.0952}}, “graphical”: {“loss”: 0.041655246168375015, “learning_rate”: “5.000002e-05”}, “kpi”: {“validation cost”: 0.03309437, “mean average precision”: 4.0952}}
• Just trained from roboflow dataset pulled as coco and converted with tao itself.
