TAO Toolkit API crashes because of permissions
Hello all,
We are running the TAO Toolkit API on an EKS cluster running T4’s. The EKS cluster was created and deployed using the instructions here: Setup
Periodically the “tao-toolkit-api-app-pod” will go into crashloop and emits a ton of logs about permissions like these:
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/2_20190607_22-16-50-20190607_22-22-23_2640.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/0_20190522_18-11-10-20190522_18-15-18_14175.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/videos_192.168.60.4_4_21_0.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/ptzimage-10.169.222.11-2018-12-05t16-47-42.753237z_1.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/data_192.168.70.5_1_260_0.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/20190522_17-11-10-20190522_17-15-15_14525_1.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/ptzimage-10.169.240.161-2018-11-19t15-20-40.699514z_1.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/videos_192.168.60.4_3_1911_0.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/vids_192.168.70.5_2_130_0.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/2251-2019-12-20T08:05:07.872774102Z_0.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/0_20190522_17-31-10-20190522_17-35-12_11300.jpg': Operation not permitted
chmod: changing permissions of '/shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9/datasets/d42d0632-c8bf-4d81-9fd4-12e7c199ce0b/images/ptzimage-10.169.222.191-2018-11-28t01-52-55.586978z_0.jpg': Operation not permitted
Please try:
sudo chown -R root:root /shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9
sudo chmod -R 777 /shared/users/34c37fbc-98e3-5cf6-8668-d5e2b1a5bca9
Please run above commands locally instead of inside container.
@Morganh Thanks for your response but that will not fix my issue. When the pod starts up initially after an issue it attempts to change permissions by itself.
Can you share more logs as following commands?
$ kubectl get pods
$ kubectl get pod -n nvidia-gpu-operator
$ kubectl logs -n nvidia-gpu-operator nvidia-driver-daemonset-*****
$ kubectl pod get -n gpu-operator-operator nvidia-cuda-validator-****
Note: **** depends on actual name.
