So I have tried many ways of flashing until now, be it by NVIDIA SDK manager GUI, by the script nvsdkm_flash.sh or by the script l4t_initrd_flash.sh. all taken on the same setup, but when flashing by script alone I notice that gradually the rate in which my target failed to reboot into initrd mode (to start flashing) increases.
When I first saw the issue it was just 1 out of 3-4 trials, but currently the fail rate has been as high as 70-80% but sometimes I still have 2-3 consecutive successful flashes.
I know that VM cannot compare to Native Ubuntu regarding stability. However I’m currently not given a choice to use native Ubuntu, hence trying to make it work with VM.
And from what I’ve experienced that my setup was pretty stable 1-2 months ago, where I can achieve 95-100% success rate (even when running in a Docker container situated inside the host VM), but it’s just keep decreasing ever since without any clear reason. That’s why in this topic what I want to achieve is not a way to make it 100% again, but to at least know where in the log may show some hint about what’s gone wrong.
Can you have a look into the logs and have some verdicts? I would be very appreciated.
Yes I also had many tests on VMWare Workstation (on a different PC) as well, and the same issue still persist, originally VMWare Workstation achieves 100% successful rate, but it also keeps declining.
Actually I’m aware about how VMWare is more preferred than VirtualBox thanks to this post: Let's make flashing from virtual machines reliable - #4 by cyato , but VMWare only handles the USB disconnection-reconnection process smoother, whereas in this case the issue is that the device was not even be able to reboot into initrd (hence there’s no new USB device to be detected by the VM)
Do you think somewhere in the script may I need to add/extend some delayed period when the instruction to rcmboot starts?
I’ll try looking into the links in your shared topic to find more hints
