I am using CUDAfy to use CUDA along with C#. In order to keep the GUI responsive I am trying to use the TPL.
Whenever a CUDA Command occurs in the code I get this Error: “CUDA.NET exception: ErrorInvalidContext”.
I have absolutely no clue what to do, since I just began working with the TPL :(
Hopefully somebody can help.
Thank you
var uiScheduler = TaskScheduler.FromCurrentSynchronizationContext();
CancellationTokenSource tokenSource = new CancellationTokenSource();
CancellationToken cancellationToken = tokenSource.Token;
SynchronizationContext synContext = SynchronizationContext.Current;
Task customerTask = Task.Factory.StartNew(() =>
double[] dev_yp = gpu.Allocate<double>(new double[4]);
