Hi All,
I am currently having issues setting up my TC358743 driver (GeeekPi HDMI to CSI converter) on my Orin NX (CTI Hadron DM carrier running J5.1.2 r35.4.1).
I have downloaded, built, and installed the TC358743.c driver (shipped in NVIDIA kernel_src.tbz2) as an out-of-tree kernel module TC358743.ko and added it to the device’s kernel.
I have also created a device tree overlay that I apply to the base kernel_tegra234-orin-nx-cti-NGX024.dtbto configure the driver.
mipi_driver.txt (5.4 KB)
The issue I am having is a timeout when trying to stream from the device. I believe this is likely a configuration issue as my timings and configuration format are returned as zeros and the defaults.
sudo v4l2-ctl -d /dev/video0 \
> --set-fmt-video=width=1920,height=1080,pixelformat=UYVY \
> --stream-mmap --stream-count=10
New timings found
[ 622.563084] bwmgr API not supported
[ 625.311809] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 625.324589] tegra-camrtc-capture-vi tegra-capture-vi: Uncorr_ERR_Occured 1 Times
[ 625.332244] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 625.342165] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 625.350122] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 625.360822] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 625.368540] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 625.379365] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 628.128287] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 628.137435] tegra-camrtc-capture-vi tegra-capture-vi: Uncorr_ERR_Occured 2 Times
[ 628.145065] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 628.155159] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 628.162890] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 628.173609] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 628.181340] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 628.192101] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 630.944032] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 630.953180] tegra-camrtc-capture-vi tegra-capture-vi: Uncorr_ERR_Occured 3 Times
[ 630.960814] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 630.971120] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 630.978837] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 630.989505] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 630.997216] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 631.007952] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 633.760173] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 633.769336] tegra-camrtc-capture-vi tegra-capture-vi: Uncorr_ERR_Occured 4 Times
[ 633.776978] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 633.787147] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 633.794861] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 633.805518] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 633.813233] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 633.824018] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 636.351999] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 636.361190] tegra-camrtc-capture-vi tegra-capture-vi: Uncorr_ERR_Occured 5 Times
[ 636.368820] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 636.379129] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 636.386840] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 636.397493] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 636.405202] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 636.415974] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
sudo v4l2-ctl -d /dev/v4l-subdev1 --verbose --query-dv-timings
VIDIOC_QUERY_DV_TIMINGS: ok
Active width: 0
Active height: 0
Total width: 0
Total height: 0
Frame format: progressive
Polarities: -vsync -hsync
Pixelclock: 0 Hz
Horizontal frontporch: 0
Horizontal sync: 0
Horizontal backporch: 0
Vertical frontporch: 0
Vertical sync: 0
Vertical backporch: 0
Standards:
Flags:
It is also worth noting I have to manually add the EDID on startup for the HDMI signal to be detected.
v4l2-ctl -d /dev/v4l-subdev1 --set-edid=type=hdmi --fix-edid-checksums
sudo v4l2-ctl -d /dev/v4l-subdev1 --log-status
Status Log:
[ 286.392493] tc358743 9-000f: ================= START STATUS =================
[ 286.393562] tc358743 9-000f: -----Chip status-----
[ 286.393915] tc358743 9-000f: Chip ID: 0x00
[ 286.394267] tc358743 9-000f: Chip revision: 0x00
[ 286.394269] tc358743 9-000f: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
[ 286.394271] tc358743 9-000f: Sleep mode: off
[ 286.394272] tc358743 9-000f: Cable detected (+5V power): yes
[ 286.394596] tc358743 9-000f: DDC lines enabled: yes
[ 286.394922] tc358743 9-000f: Hotplug enabled: yes
[ 286.395272] tc358743 9-000f: CEC enabled: no
[ 286.395273] tc358743 9-000f: -----Signal status-----
[ 286.395274] tc358743 9-000f: TMDS signal detected: yes
[ 286.395275] tc358743 9-000f: Stable sync signal: yes
[ 286.395276] tc358743 9-000f: PHY PLL locked: yes
[ 286.395277] tc358743 9-000f: PHY DE detected: yes
[ 286.399823] tc358743 9-000f: Detected format: 1920x1080p60.00 (2200x1125)
[ 286.399826] tc358743 9-000f: horizontal: fp = 0, -sync = 280, bp = 0
[ 286.399827] tc358743 9-000f: vertical: fp = 0, -sync = 45, bp = 0
[ 286.399828] tc358743 9-000f: pixelclock: 148500000
[ 286.399830] tc358743 9-000f: flags (0x0):
[ 286.399831] tc358743 9-000f: standards (0x0):
[ 286.399833] tc358743 9-000f: Configured format: 640x480p59.94 (800x525)
[ 286.399834] tc358743 9-000f: horizontal: fp = 16, -sync = 96, bp = 48
[ 286.399835] tc358743 9-000f: vertical: fp = 10, -sync = 2, bp = 33
[ 286.399836] tc358743 9-000f: pixelclock: 25175000
[ 286.399837] tc358743 9-000f: flags (0x80): HAS_CEA861_VIC
[ 286.399838] tc358743 9-000f: standards (0x3): CEA DMT
[ 286.399839] tc358743 9-000f: CEA-861 VIC: 1
[ 286.399840] tc358743 9-000f: -----CSI-TX status-----
[ 286.399842] tc358743 9-000f: Lanes needed: 1
[ 286.399843] tc358743 9-000f: Lanes in use: 1
[ 286.400195] tc358743 9-000f: Waiting for particular sync signal: no
[ 286.400545] tc358743 9-000f: Transmit mode: no
[ 286.400896] tc358743 9-000f: Receive mode: no
[ 286.401268] tc358743 9-000f: Stopped: no
[ 286.401271] tc358743 9-000f: Color space: RGB 888 24-bit
[ 286.401603] tc358743 9-000f: -----HDMI status-----
[ 286.401605] tc358743 9-000f: HDCP encrypted content: no
[ 286.401607] tc358743 9-000f: Input color space: RGB full range
[ 286.401935] tc358743 9-000f: AV Mute: off
[ 286.402264] tc358743 9-000f: Deep color mode: 8-bits per channel
[ 286.403324] tc358743 9-000f: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[ 286.403327] tc358743 9-000f: colorspace: RGB
[ 286.403328] tc358743 9-000f: scan mode: No Data
[ 286.403330] tc358743 9-000f: colorimetry: No Data
[ 286.403331] tc358743 9-000f: picture aspect: 16:9
[ 286.403332] tc358743 9-000f: active aspect: Same as Picture
[ 286.403333] tc358743 9-000f: itc: IT Content
[ 286.403335] tc358743 9-000f: extended colorimetry: xvYCC 601
[ 286.403336] tc358743 9-000f: quantization range: Full
[ 286.403338] tc358743 9-000f: nups: Unknown Non-uniform Scaling
[ 286.403339] tc358743 9-000f: video code: 16
[ 286.403340] tc358743 9-000f: ycc quantization range: Limited
[ 286.403341] tc358743 9-000f: hdmi content type: Graphics
[ 286.403342] tc358743 9-000f: pixel repeat: 0
[ 286.403344] tc358743 9-000f: bar top 0, bottom 0, left 0, right 0
[ 286.403345] tc358743 9-000f: ================== END STATUS ==================
The device does display as /dev/video0 and /dev/media0 with /dev/v4l-subdev0 and /dev/v4l-subdev1 and is detected on boot.
[ 79.697623] tc358743 2-000f: tc358743 found @ 0x1e (3180000.i2c)
