TC358840 HDMI TO CSI CONVERTER INTERFACE WITH NANO
With reference to my previous case I continued to work on TC358840 driver.
After changing some driver code now kernel module is engaged , video 0 is generated.
But now when I tried to start streaming first image comes but then it stuck.
I its gives no_sync error.
Can somebody guide me what I missed the setting driver?
hello rusurya,
this looks like an issue of bridge driver,
could you please give it a try to configure the clock mode as discontinuous mode for testing.
you may double check whether it’s keep sending frames to CSI channel.
furthermore,
please see-also Topic 305036 for reference.
Hello JerryChang,
Thanks a lot for reply.
Sorry for delayed reply.
Actually I going through given topic and trying some more variations.
But it wont help.
Please check attached dtsi file , I choose clock-noncontinuous property.
tegra210-tc358840.txt (6.3 KB)
Please guide me on the issue.
hello rusurya,
please refer to Property-Value Pairs section, you may give it a try by adding discontinuous_clk= "yes"; into device tree as well.
BTW,
is it possible to probe the MIPI signaling to ensure there’re packet sending to CSI channel?
