Now I am getting video0 device but still tc358840 module is not engaged.
Module Size Used by
tc358840 56736 0
bnep 16562 2
xt_conntrack 3609 1
This tc358840 I have connected to HDMI out of my laptop. After installation of driver laptop detect Toshiba device as second screen.
Also if I try to check video0 properties using v4l2 command it always shows 1920 x 1080 resolution.
Even if nothing is connected still it shows same resolution.
please share complete kernel logs, $ sudo dmesg --follow
you should also note that, v4l2 IOCTL it only checks the driver capability, which reported by sensor driver.
Sorry in full log parse_dt function log also appear.
There is one thing in dtsi
csi_port = <1>;
Currently I am using CSI 4 lane only. I am using CSI 0 and CSI 1 port for that.
So above parameter declaration is correct ? or csi_port = <0> is correct.?
according to the logs.
it seems you’ve tc358840 register to linux system, and the failure now related to streaming.
for instance, [ 99.518662] tc358840 0-000f: enable_stream: Timeout: HDMI input sync failed.
this meant CSI-B, whereas CSI-B doesn’t support with 4-lane configuration.
please revise the node as CSI-A, (i.e. csi_port = <0>;) to enable your 4-lane streaming.
Sorry for my lack of understanding.
I run above commands after installing driver but I am getting following output.
user@user-desktop:~$ sudo su
[sudo] password for user:
root@user-desktop:/home/user# echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
bash: /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked: No such file or directory
root@user-desktop:/home/user# echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
bash: /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked: No such file or directory
root@user-desktop:/home/user# echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
bash: /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked: No such file or directory
root@user-desktop:/home/user# cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat: /sys/kernel/debug/bpmp/debug/clk/vi/max_rate: No such file or directory
tee: /sys/kernel/debug/bpmp/debug/clk/vi/rate: No such file or directory
root@user-desktop:/home/user# cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
tee: /sys/kernel/debug/bpmp/debug/clk/isp/ratecat: /sys/kernel/debug/bpmp/debug/clk/isp/max_rate: No such file or directory
root@user-desktop:/home/user# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat: /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate: No such file or directory
tee: /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate: No such file or directory
I thing I need to install something.
Please guide me on this.
I was going through all above links and tried to make changes in dtsi and driver.
But nothing helps.
I put function name display messages that gives idea about how program flows?
I took debug log please check attached log file.
In my case module is inserted.
I am getting video 0 device and tc358840 is detected on laptop but if I check lsmod command its not engaged.
Please guide me on this. defaultdebug_2208.txt (4.2 KB)
it looks driver has functional according to the debug logs,
however, what’s the reason of below two? is it related to no signaling detected by the TC358840? [ 373.077038] no_signal [ 373.077248] no_sync
Sorry for delayed reply.
Actually I was trying to find out where the things goes wrong?
For that I enable more debug and put messages to trace out the flow.
Finally I found the fault.
In driver probe function the last function is
v4l2_async_register_subdev(sd);
unfortunately we are failing there. Please check attached dmesg log.
I am trying to solve the problem.
If you have any suggestion then please let me know.
Thanks a lot for support.
