Hello Guys
i am having some trouble running teamviewer on the nano
i did install it using a couple of guides, i set it up via terminal, i can see the computer running up, so i can connect, but as soon as i connect, the blue icon shows on the taskbar and then closes.
same happens if i manually open the app from the menu.
it says Aborted (core dumped) when run from terminal…
any ideas?
the first time i got my nano, i had success on this and was able to connect with no problem, but then i had to reflash the SD card and now i am having this issue
thanks in advance!!
