Tee-supplicant run failed on Xavier NX
[Issue Category] Security
[Hardware Setup] Jetson NX Xavier module + custom carrier board
[Repro Steps]
[Test Sample] tee-supplicant
[Error Log] ERR [13058] TSUP:main:922: failed to find an OP-TEE supplicant device
[dmesg] upload
[Device tree patch if any]
[Reproducible on dev-kit] Yes
[Dev-kit Model + BSP version] r35.3.1
[Additional Information]
I check the device node on /dev/ there’s no tee node can be found. I add tegra194-optee.dts in dts, but take no effect. Please help to take a look. thanks.
5003956_a90df1f8af_dmesg.txt (175.5 KB)
hello lingsong.zheng,
please check whether you’ve device nodes created correctly.
for instance,
$ ls /dev/tee*
/dev/tee0  /dev/teepriv0
you may dig into $ ls -la /dev/teepriv0 to confirm its permission (i.e. should be 664) as well.
Hi Jerry, thanks for reply:
There is no /dev/tee0 or /dev/teepriv0.I change dts like this.
firmware {
optee {
compatible = “linaro,optee-tz”;
method = “smc”;
status = “okay”;
Then I get the error in kernel:
[Sat Dec 14 15:23:36 2024] optee: probing for conduit method.
[Sat Dec 14 15:23:36 2024] optee: api uid mismatch
[Sat Dec 14 15:23:36 2024] optee: probe of firmware:optee failed with error -22
please check you’ve update TOS image correctly.
you may see-also Topic 246326 for reference.
It seems to be working fine now, thank you for your support.
