I’m a bit confused by the options in the tegra-camera-platform device tree.
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes makes sense, if I have two cameras that each use one lane then it would be 2. Or if both of those cameras used 2 lanes, it would be 4.
max_lane_speed is how fast the TX should talk to the camera over mipi. What was this value in r24.2?
min_bits_per_pixel I assume is your bayer pixel format bits per pixel. So MEDIA_BUS_FMT_SRGGB12_1X12 would be 12, or MEDIA_BUS_FMT_SRGGB12_1X10 would be 10.
As for the rest, what are “VI ISO case” and “ISP ISO case?” And how do we calculate the ISP bandwidth margin?
* Let's go with simple registering max dedicated BW
* approach for now.
* The formula is:
* Camera's max total ISO BW =
* ((max_num_streams *
* num_csi_lanes * max_lane_speed) /
* min_bits_per_pixel) * max_peak_BPP
* Above considered cap is CSI link cap, but we need to
* consider real sensor-on-board cap also, DT based approach
* should handle it.
* Only VI out is considered, because in case of
* max # of cameras running, only VI is in ISO mode.
* TODO: Try renegotiate approach later.
So Camera’s max total ISO bandwidth in r24.2 would be (((2 * 1500000000 * 6) / 10) * 2) / 1000 = 3600000 Kbit/s
Which version? I’m looking at r28.2 and I don’t even see a mention that those are required for tegra-camera-platform. I had to find out about them from the dtsi.
please check [L4T R28.2 DP Documentation]-> [Release 28.2 Development Guide]-> [Camera Development]-> [Sensor Driver Programming Guide]
searching for the “Module Properties” for the descriptions.
thanks
