I can’t run “Profile a Frame” with the Tegra Graphics Debugger, because the Driver Instrumentation is not enabled. The “Driver Instrumentation Status” on the upper right of the “Launch and Connect Application on Android (EGL)” window is deactivated and disabled(grey), so I can’t activate the check box. How can I activate the driver instrumentation?
Thank you very much in advance
