Hello all.
I am trying to “make zImage” with the kernel sources directory that can be found on the Jetson TK1 software page. I have tried 19.3 and 21.2 and both fail when compiling drivers/clocksource/tegra-nvtimers.c
Here are the compiler errors:
drivers/clocksource/tegra-nvtimers.c: In function ‘tegra_cputimer_interrupt’:
drivers/clocksource/tegra-nvtimers.c:99:25: error: dereferencing pointer to incomplete type
cpu = cpumask_first(evt->cpumask);
drivers/clocksource/tegra-nvtimers.c:102:5: error: dereferencing pointer to incomplete type
evt->event_handler(evt);
drivers/clocksource/tegra-nvtimers.c: In function ‘tegra_cputimer_set_next_event’:
drivers/clocksource/tegra-nvtimers.c:113:25: error: dereferencing pointer to incomplete type
drivers/clocksource/tegra-nvtimers.c: At top level:
drivers/clocksource/tegra-nvtimers.c:122:16: warning: ‘enum clock_event_mode’ declared inside parameter list [enabled by default]
struct clock_event_device *evt)
drivers/clocksource/tegra-nvtimers.c:122:16: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default]
drivers/clocksource/tegra-nvtimers.c:121:59: error: parameter 1 (‘mode’) has incomplete type
static void tegra_cputimer_set_mode(enum clock_event_mode mode,
drivers/clocksource/tegra-nvtimers.c:121:13: warning: function declaration isn’t a prototype [-Wstrict-prototypes]
drivers/clocksource/tegra-nvtimers.c: In function ‘tegra_cputimer_set_mode’:
drivers/clocksource/tegra-nvtimers.c:128:25: error: dereferencing pointer to incomplete type
drivers/clocksource/tegra-nvtimers.c:133:7: error: ‘CLOCK_EVT_MODE_PERIODIC’ undeclared (first use in this function)
case CLOCK_EVT_MODE_PERIODIC:
drivers/clocksource/tegra-nvtimers.c:133:7: note: each undeclared identifier is reported only once for each function it appears in
drivers/clocksource/tegra-nvtimers.c:137:7: error: ‘CLOCK_EVT_MODE_ONESHOT’ undeclared (first use in this function)
case CLOCK_EVT_MODE_ONESHOT:
drivers/clocksource/tegra-nvtimers.c:139:7: error: ‘CLOCK_EVT_MODE_UNUSED’ undeclared (first use in this function)
case CLOCK_EVT_MODE_UNUSED:
drivers/clocksource/tegra-nvtimers.c:140:7: error: ‘CLOCK_EVT_MODE_SHUTDOWN’ undeclared (first use in this function)
case CLOCK_EVT_MODE_SHUTDOWN:
drivers/clocksource/tegra-nvtimers.c:141:7: error: ‘CLOCK_EVT_MODE_RESUME’ undeclared (first use in this function)
case CLOCK_EVT_MODE_RESUME:
drivers/clocksource/tegra-nvtimers.c:146:15: error: variable ‘tegra_cputimer_clockevent’ has initializer but incomplete type
static struct clock_event_device tegra_cputimer_clockevent = {
drivers/clocksource/tegra-nvtimers.c:147:2: error: unknown field ‘rating’ specified in initializer
.rating = 450,
drivers/clocksource/tegra-nvtimers.c:147:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:147:2: warning: (near initialization for ‘tegra_cputimer_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c:148:2: error: unknown field ‘features’ specified in initializer
.features = CLOCK_EVT_FEAT_ONESHOT | CLOCK_EVT_FEAT_PERIODIC,
drivers/clocksource/tegra-nvtimers.c:148:14: error: ‘CLOCK_EVT_FEAT_ONESHOT’ undeclared here (not in a function)
drivers/clocksource/tegra-nvtimers.c:148:39: error: ‘CLOCK_EVT_FEAT_PERIODIC’ undeclared here (not in a function)
drivers/clocksource/tegra-nvtimers.c:148:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:148:2: warning: (near initialization for ‘tegra_cputimer_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c:149:2: error: unknown field ‘set_next_event’ specified in initializer
.set_next_event = tegra_cputimer_set_next_event,
drivers/clocksource/tegra-nvtimers.c:149:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:149:2: warning: (near initialization for ‘tegra_cputimer_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c:150:2: error: unknown field ‘set_mode’ specified in initializer
.set_mode = tegra_cputimer_set_mode,
drivers/clocksource/tegra-nvtimers.c:150:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:150:2: warning: (near initialization for ‘tegra_cputimer_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c:160:26: error: ‘INT_TMR3’ undeclared here (not in a function)
CPU_TIMER_IRQ_ACTION(0, INT_TMR3),
drivers/clocksource/tegra-nvtimers.c:157:10: note: in definition of macro ‘CPU_TIMER_IRQ_ACTION’
.irq = irqnum }
drivers/clocksource/tegra-nvtimers.c:182:16: warning: ‘enum clock_event_mode’ declared inside parameter list [enabled by default]
drivers/clocksource/tegra-nvtimers.c:181:56: error: parameter 1 (‘mode’) has incomplete type
static void tegra_timer_set_mode(enum clock_event_mode mode,
drivers/clocksource/tegra-nvtimers.c:181:13: warning: function declaration isn’t a prototype [-Wstrict-prototypes]
drivers/clocksource/tegra-nvtimers.c: In function ‘tegra_timer_set_mode’:
drivers/clocksource/tegra-nvtimers.c:189:7: error: ‘CLOCK_EVT_MODE_PERIODIC’ undeclared (first use in this function)
drivers/clocksource/tegra-nvtimers.c:193:7: error: ‘CLOCK_EVT_MODE_ONESHOT’ undeclared (first use in this function)
drivers/clocksource/tegra-nvtimers.c:195:7: error: ‘CLOCK_EVT_MODE_UNUSED’ undeclared (first use in this function)
drivers/clocksource/tegra-nvtimers.c:196:7: error: ‘CLOCK_EVT_MODE_SHUTDOWN’ undeclared (first use in this function)
drivers/clocksource/tegra-nvtimers.c:197:7: error: ‘CLOCK_EVT_MODE_RESUME’ undeclared (first use in this function)
drivers/clocksource/tegra-nvtimers.c:202:15: error: variable ‘tegra_clockevent’ has initializer but incomplete type
static struct clock_event_device tegra_clockevent = {
drivers/clocksource/tegra-nvtimers.c:203:2: error: unknown field ‘name’ specified in initializer
.name = “timer0”,
drivers/clocksource/tegra-nvtimers.c:203:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:203:2: warning: (near initialization for ‘tegra_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c:204:2: error: unknown field ‘rating’ specified in initializer
.rating = 300,
drivers/clocksource/tegra-nvtimers.c:204:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:204:2: warning: (near initialization for ‘tegra_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c:205:2: error: unknown field ‘features’ specified in initializer
drivers/clocksource/tegra-nvtimers.c:205:37: error: invalid operands to binary | (have ‘struct irqaction *’ and ‘struct irqaction *’)
drivers/clocksource/tegra-nvtimers.c:205:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:205:2: warning: (near initialization for ‘tegra_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c:206:2: error: unknown field ‘set_next_event’ specified in initializer
.set_next_event = tegra_timer_set_next_event,
drivers/clocksource/tegra-nvtimers.c:206:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:206:2: warning: (near initialization for ‘tegra_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c:207:2: error: unknown field ‘set_mode’ specified in initializer
.set_mode = tegra_timer_set_mode,
drivers/clocksource/tegra-nvtimers.c:207:2: warning: excess elements in struct initializer [enabled by default]
drivers/clocksource/tegra-nvtimers.c:207:2: warning: (near initialization for ‘tegra_clockevent’) [enabled by default]
drivers/clocksource/tegra-nvtimers.c: In function ‘tegra_timer_interrupt’:
drivers/clocksource/tegra-nvtimers.c:366:5: error: dereferencing pointer to incomplete type
drivers/clocksource/tegra-nvtimers.c:366:5: error: request for member ‘event_handler’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:366:20: error: called object is not a function or function pointer
drivers/clocksource/tegra-nvtimers.c:366:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c: In function ‘tegra_local_timer_setup’:
drivers/clocksource/tegra-nvtimers.c:408:5: error: dereferencing pointer to incomplete type
evt->name = clkevt->name;
drivers/clocksource/tegra-nvtimers.c:408:5: error: request for member ‘name’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:408:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:409:5: error: dereferencing pointer to incomplete type
evt->cpumask = cpumask_of(cpu);
drivers/clocksource/tegra-nvtimers.c:409:5: error: request for member ‘cpumask’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:409:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:410:5: error: dereferencing pointer to incomplete type
evt->features = tegra_cputimer_clockevent.features;
drivers/clocksource/tegra-nvtimers.c:410:5: error: request for member ‘features’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:410:2: error: invalid use of undefined type ‘struct clock_event_device’
drivers/clocksource/tegra-nvtimers.c:410:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:411:5: error: dereferencing pointer to incomplete type
evt->rating = tegra_cputimer_clockevent.rating;
drivers/clocksource/tegra-nvtimers.c:411:5: error: request for member ‘rating’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:411:2: error: invalid use of undefined type ‘struct clock_event_device’
drivers/clocksource/tegra-nvtimers.c:411:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:412:5: error: dereferencing pointer to incomplete type
evt->set_mode = tegra_cputimer_set_mode;
drivers/clocksource/tegra-nvtimers.c:412:5: error: request for member ‘set_mode’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:412:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:413:5: error: dereferencing pointer to incomplete type
evt->set_next_event = tegra_cputimer_set_next_event;
drivers/clocksource/tegra-nvtimers.c:413:5: error: request for member ‘set_next_event’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:413:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:414:2: error: implicit declaration of function ‘clockevents_calc_mult_shift’ [-Werror=implicit-function-declaration]
clockevents_calc_mult_shift(evt, 1000000, 5);
drivers/clocksource/tegra-nvtimers.c:415:5: error: dereferencing pointer to incomplete type
evt->max_delta_ns =
drivers/clocksource/tegra-nvtimers.c:415:5: error: request for member ‘max_delta_ns’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:416:3: error: implicit declaration of function ‘clockevent_delta2ns’ [-Werror=implicit-function-declaration]
clockevent_delta2ns(0x1fffffff, evt);
drivers/clocksource/tegra-nvtimers.c:415:2: warning: statement with no effect [-Wunused-value]
evt->max_delta_ns =
drivers/clocksource/tegra-nvtimers.c:417:5: error: dereferencing pointer to incomplete type
evt->min_delta_ns =
drivers/clocksource/tegra-nvtimers.c:417:5: error: request for member ‘min_delta_ns’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:417:2: warning: statement with no effect [-Wunused-value]
evt->min_delta_ns =
drivers/clocksource/tegra-nvtimers.c:421:2: error: implicit declaration of function ‘clockevents_register_device’ [-Werror=implicit-function-declaration]
clockevents_register_device(evt);
drivers/clocksource/tegra-nvtimers.c:431:5: error: dereferencing pointer to incomplete type
evt->irq = tegra_cputimer_irq[cpu].irq;
drivers/clocksource/tegra-nvtimers.c:431:5: error: request for member ‘irq’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:431:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:440:23: error: dereferencing pointer to incomplete type
enable_percpu_irq(evt->irq, IRQ_TYPE_LEVEL_HIGH);
drivers/clocksource/tegra-nvtimers.c:440:23: error: request for member ‘irq’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:440:2: warning: passing argument 1 of ‘enable_percpu_irq’ makes integer from pointer without a cast [enabled by default]
In file included from drivers/clocksource/tegra-nvtimers.c:25:0:
include/linux/interrupt.h:221:13: note: expected ‘unsigned int’ but argument is of type ‘struct irqaction *’
extern void enable_percpu_irq(unsigned int irq, unsigned int type);
drivers/clocksource/tegra-nvtimers.c: In function ‘tegra_local_timer_stop’:
drivers/clocksource/tegra-nvtimers.c:449:5: error: dereferencing pointer to incomplete type
evt->set_mode(CLOCK_EVT_MODE_UNUSED, evt);
drivers/clocksource/tegra-nvtimers.c:449:5: error: request for member ‘set_mode’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:449:16: error: ‘CLOCK_EVT_MODE_UNUSED’ undeclared (first use in this function)
drivers/clocksource/tegra-nvtimers.c:449:15: error: called object is not a function or function pointer
drivers/clocksource/tegra-nvtimers.c:449:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:450:16: error: dereferencing pointer to incomplete type
remove_irq(evt->irq, &tegra_cputimer_irq[cpu]);
drivers/clocksource/tegra-nvtimers.c:450:16: error: request for member ‘irq’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:450:2: warning: passing argument 1 of ‘remove_irq’ makes integer from pointer without a cast [enabled by default]
In file included from drivers/clocksource/tegra-nvtimers.c:26:0:
include/linux/irq.h:372:13: note: expected ‘unsigned int’ but argument is of type ‘struct irqaction *’
extern void remove_irq(unsigned int irq, struct irqaction *act);
drivers/clocksource/tegra-nvtimers.c:451:24: error: dereferencing pointer to incomplete type
disable_percpu_irq(evt->irq);
drivers/clocksource/tegra-nvtimers.c:451:24: error: request for member ‘irq’ in something not a structure or union
drivers/clocksource/tegra-nvtimers.c:451:2: warning: passing argument 1 of ‘disable_percpu_irq’ makes integer from pointer without a cast [enabled by default]
include/linux/interrupt.h:219:13: note: expected ‘unsigned int’ but argument is of type ‘struct irqaction *’
extern void disable_percpu_irq(unsigned int irq);
drivers/clocksource/tegra-nvtimers.c: In function ‘tegra_init_timer’:
drivers/clocksource/tegra-nvtimers.c:607:2: error: invalid use of undefined type ‘struct clock_event_device’
tegra_clockevent.max_delta_ns =
drivers/clocksource/tegra-nvtimers.c:607:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:609:2: error: invalid use of undefined type ‘struct clock_event_device’
tegra_clockevent.min_delta_ns =
drivers/clocksource/tegra-nvtimers.c:609:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:611:2: error: invalid use of undefined type ‘struct clock_event_device’
tegra_clockevent.cpumask = cpu_all_mask;
drivers/clocksource/tegra-nvtimers.c:611:2: warning: statement with no effect [-Wunused-value]
drivers/clocksource/tegra-nvtimers.c:612:2: error: invalid use of undefined type ‘struct clock_event_device’
tegra_clockevent.irq = tegra_timer_irq.irq;
drivers/clocksource/tegra-nvtimers.c:612:2: warning: statement with no effect [-Wunused-value]
cc1: some warnings being treated as errors
make[2]: *** [drivers/clocksource/tegra-nvtimers.o] Error 1
make[1]: *** [drivers/clocksource] Error 2
make: *** [drivers] Error 2
Has anyone else had this issue or know how to fix it?
