Tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
i captured the boot logs from sudo cat /var/log/syslog. and i found this above statement tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
can you please explain what does this mean ? and can it happen automatically / if yes what are the reasons.
I wonder why my jetson nano gets reboot often when deployed in vehicles.
hello aymen.baig,
please attach the log file for reference,
furthermore, may I know what’s the fuse type you’ve enabled for your target?
attaching logs and temperature logs of my jetson nano
boot_logs.txt (95.6 KB)
Temperature.log (3.4 MB)
hello aymen.baig,
those logs looks normal, may I also know what’s the background service running?
BTW,
this is system information instead of errors.
this is reported when kernel layer parse device tree property, thermal-zone.
