Tegra-host1x 13e00000.host1x: syncpt_load failed
AGX Orin, Jetpack 6.2.1
2 x stereo + 4 x mono cameras
The “syncpt_load failed” messages are logged in bursts - typically 12 at a time, but sometimes 20.
The bursts may come every several minutes or a few per hour
What is the cause of these messages?
We have some camera failures, and I wonder if they can be related.
Jun 30 12:03:25 m020-9999 kernel: tegra-host1x 13e00000.host1x: syncpt_load failed: id=210, min=17319396, max=17319392
Jun 30 12:10:28 m020-9999 kernel: tegra-host1x 13e00000.host1x: syncpt_load failed: id=212, min=8735658, max=8735656
Jun 30 12:10:28 m020-9999 kernel: tegra-host1x 13e00000.host1x: syncpt_load failed: id=212, min=8735660, max=8735656
Jun 30 12:32:57 m020-9999 kernel: tegra-host1x 13e00000.host1x: syncpt_load failed: id=210, min=17968600, max=17968598
This is a host1x syncpoint bookkeeping mismatch. In your log, syncpoint id=210 has min > max (17319396 > 17319392), so hardware/current state is ahead of the software-expected maximum by 4 increments.
What it usually means in practice:
  • It is not just a harmless print if it repeats; several bugs tie it to hangs, job submission failures, or pipeline issues.
  • If this is on a camera path, it can affect image acquisition because VI/ISP are connected with host1x.
  • High system/CPU load has shown up as a trigger in similar cases, likely by delaying host1x interrupt handling or the related client process.
Best next checks:
  1. Capture host1x ownership/state right when it happens:
    • cat /sys/kernel/debug/tegra-host1x/status
    • or cat /sys/kernel/debug/tegra-host1x/status_all
  2. If reproduction correlates with boot or stress, also collect sysstat / CPU load around the event.
  3. If the owner comes up null or unclear, enable host1x tracing before repro:
    • echo 1 > /sys/kernel/debug/tegra-host1x/trace_cmdbuf
    • echo 1 > /sys/kernel/debug/tegra-host1x/trace_space
    • echo 1 > /sys/kernel/debug/tracing/events/host1x/enable
    • echo 1 > /sys/kernel/debug/tracing/tracing_on
  4. If this happens under heavy load, try pinning host1x_syncpt IRQs to an isolated CPU core; that was specifically suggested in a recent similar case
Re:
cat /sys/kernel/debug/tegra-host1x/status - it’s hard to catch the exact moments, since the events are unpredictable, but the ids likely belong to our argus apps. Sometimes they show up and sometimes not:
root@m020-9999:~# cat /sys/kernel/debug/tegra-host1x/status | grep argus
id 68 (68-argus) min 2000 max 2000 (0 waiters)
id 69 (69-argus) min 2000 max 2000 (0 waiters)
id 108 (108-argus) min 2000 max 2000 (0 waiters)
id 109 (109-argus) min 2000 max 2000 (0 waiters)
id 115 (115-argus) min 2000 max 2000 (0 waiters)
id 116 (116-argus) min 2000 max 2000 (0 waiters)
id 179 (179-argus) min 0 max 0 (0 waiters)
id 180 (180-argus) min 0 max 0 (0 waiters)
id 181 (181-argus) min 0 max 0 (0 waiters)
id 182 (182-argus) min 0 max 0 (0 waiters)
id 183 (183-argus) min 0 max 0 (0 waiters)
id 184 (184-argus) min 0 max 0 (0 waiters)
id 210 (210-argus) min 33023168 max 33023168 (0 waiters)
id 211 (211-argus) min 28558788 max 28558792 (2 waiters)
id 212 (212-argus) min 16840422 max 16840424 (2 waiters)
id 213 (213-argus) min 12957424 max 12957424 (0 waiters)
id 211 (211-argus) min 28573944 max 28573944 (0 waiters)
id 212 (212-argus) min 16849672 max 16849676 (2 waiters)
id 214 (214-argus) min 7097514 max 7097516 (2 waiters)
id 215 (215-argus) min 2827716 max 2827716 (0 waiters)
We have 6 argus apps - each servicing one camera (2 sterero + 4 mono).
Each app runs the loop:
  while (...) {
    frame = cam.AcquireFrame(timepoint)
      → iframe_consumer->acquireFrame(timeout)
      // Blocks until libargus delivers next frame. All VI/ISP/VIC work is inside closed-source libargus.
    // process raw
    copyToNvBuffer(...) // closed-source libargus
    // process lossy
    // process lossless
    // hand it to the worker thread
The cameras are synchronized by an external hardware strobe, so AcquireFrame() is executed approximately at the same time for all camera apps.
Re: host1x_syncpt - there seems to be 8 of them:
root@m020-9999:~# cat /proc/interrupts | grep host1x_syncpt
191:        174          0          0          0          0          0          0          0          0          0          0          0     GICv3 480 Level     host1x_syncpt
192:    3127440          0          0          0          0          0          0          0          0          0          0          0     GICv3 481 Level     host1x_syncpt
193:    4665095          0          0          0          0          0          0          0          0          0          0          0     GICv3 482 Level     host1x_syncpt
194:   10952015          0          0          0          0          0          0          0          0          0          0          0     GICv3 483 Level     host1x_syncpt
195:     936662          0          0          0          0          0          0          0          0          0          0          0     GICv3 484 Level     host1x_syncpt
196:   12680493          0          0          0          0          0          0          0          0          0          0          0     GICv3 485 Level     host1x_syncpt
197:   48030361          0          0          0          0          0          0          0          0          0          0          0     GICv3 486 Level     host1x_syncpt
198:          0          0          0          0          0          0          0          0          0          0          0          0     GICv3 487 Level     host1x_syncpt
root@m020-9999:~#
The system load is moderate and steady:
root@m020-9999:~# mpstat -P ALL
Linux 5.15.148-tegra (m020-9999)        07/01/26        aarch64       (12 CPU)
01:09:25     CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest  %gnice   %idle
01:09:25     all   13.83    0.02   13.38    0.02    0.85    0.89    0.00    0.00    0.00   71.01
01:09:25       0    5.78    0.00    6.65    0.01    3.46    1.15    0.00    0.00    0.00   82.95
01:09:25       1    5.44    0.00    4.82    0.01    0.61    0.75    0.00    0.00    0.00   88.37
01:09:25       2    5.40    0.00    5.10    0.01    0.60    0.66    0.00    0.00    0.00   88.22
01:09:25       3   24.76    0.08   35.88    0.01    0.38    0.54    0.00    0.00    0.00   38.35
01:09:25       4    7.59    0.00    9.96    0.04    0.42    0.34    0.00    0.00    0.00   81.64
01:09:25       5    7.34    0.00   10.74    0.04    0.42    0.31    0.00    0.00    0.00   81.13
01:09:25       6   17.11    0.00    6.49    0.02    0.59    0.64    0.00    0.00    0.00   75.16
01:09:25       7   17.26    0.00    5.99    0.01    0.58    0.63    0.00    0.00    0.00   75.52
01:09:25       8   18.81    0.04   18.80    0.02    0.76    1.43    0.00    0.00    0.00   60.14
01:09:25       9   18.93    0.04   18.75    0.02    0.76    1.44    0.00    0.00    0.00   60.06
01:09:25      10   18.86    0.04   18.77    0.02    0.76    1.42    0.00    0.00    0.00   60.12
01:09:25      11   18.84    0.04   18.77    0.02    0.76    1.42    0.00    0.00    0.00   60.15
root@m020-9999:~#
Can you provide a link to the recent similar case - nothing showed up in my search
Boost the clocks to try.
sudo nvpmodel -m [maxN]
sudo jetson_clocks
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
echo on > /sys/devices/platform/*rtcpu/power/control
If still capture the failure at the moment it happens with tracing enabled:
Then when the error appears, immediately collect:
dmesg -T | tail -200
cat /sys/kernel/debug/tracing/trace > /tmp/host1x_trace.log
Those tracepoints are the right ones for submit/syncpoint/interrupt correlation in host1x debugging.
Also, if this tends to happen during boot or heavy load, internal cases have correlated it with high CPU load delaying host1x interrupt handling, and one suggested experiment was binding host1x_syncpt IRQs to an isolated core.
Bottom line: owner = Argus, but your snapshot was taken after recovery, so the next useful evidence is a trace + status_all captured immediately at the failing print
Max power model and jetson_clocks have already been on. I added the other clock commands and enabled the trace. The second trace command did not work:
root@m020-9999:~# echo 1 > /sys/kernel/debug/tegra-host1x/trace_space
-bash: /sys/kernel/debug/tegra-host1x/trace_space: Permission denied
root@m020-9999:~# ll /sys/kernel/debug/tegra-host1x/
total 0
drwxr-xr-x 3 root root 0 Aug 26 2025 ./
drwx------ 80 root root 0 Jun 29 22:07 ../
drwxr-xr-x 8 root root 0 Aug 26 2025 actmon/
-r--r--r-- 1 root root 0 Aug 26 2025 devices
-rw-r--r-- 1 root root 0 Aug 26 2025 force_timeout_channel
-rw-r--r-- 1 root root 0 Aug 26 2025 force_timeout_pid
-rw-r--r-- 1 root root 0 Aug 26 2025 force_timeout_val
-r--r--r-- 1 root root 0 Aug 26 2025 status
-r--r--r-- 1 root root 0 Aug 26 2025 status_all
-rw-r--r-- 1 root root 0 Jul 1 11:05 trace_cmdbuf
root@m020-9999:~#
Attached are two sets of captured logs.
timestamp 10:52:54.064 - jetson_clocks, max power
dmesg-20260701-105254.064.log (1.3 KB)
host1x_status_all-20260701-105254.064.log (18.4 KB)
host1x_trace-20260701-105254.064.log (7.5 MB)
timestamp 11:07:28.612 - jetson_clocks, max power + extra clocks boost
dmesg-20260701-110728.612.log (1.3 KB)
host1x_status_all-20260701-110728.612.log (18.4 KB)
host1x_trace-20260701-110728.612.log (17.1 MB)
Most likely, hardware/completion reached the terminal value of an Argus VIC job, but a syncpt_load path observed a stale software max for one instant. In other words, this is most consistent with a timing/order race in host1x syncpoint bookkeeping around the Argus VIC path, rather than a long-lived timeout/hang.
Practical conclusion
Focus on:
  • Argus + VIC (15340000.vic)
  • syncpt 210
  • a software/hardware ordering race around submit/completion accounting
Best next actions
  1. Treat load/CPU pressure as a possible trigger, because this looks timing-sensitive rather than structurally stuck.
  2. If you need a short-term mitigation experiment, try reducing concurrent Argus/VIC load or pinning the relevant host1x syncpt IRQ handling to a less busy CPU
BTW, could you verify by argus_camera sample APP.
Are you saying that this is too much work for VIC to handle?
We have 8 sensors, 6 argus apps running in parallel. There are 8 host1x syncpt IRQs.
The syncpt_load does not always fail for the same id, it’s king of random. So which IRQ should I be pinning?
No — I’m not saying VIC is simply “overloaded” in the throughput sense. What your setup does suggest is a timing/interrupt-servicing problem under high concurrency: 8 sensors and 6 parallel Argus apps increase submission/completion pressure, which makes a host1x syncpoint accounting race or delayed interrupt handling more likely.
The fact that syncpt_load failed shows up on different syncpt IDs is actually consistent with that interpretation. It points away from “one bad syncpoint” and more toward a shared service path issue — i.e. host1x syncpt interrupt processing latency, scheduler delay, or client timing under load.
Which IRQ to pin
Pin the host1x_syncpt IRQ lines, not an IRQ derived from the failing syncpt ID. A syncpt ID like 210 or 212 is not the IRQ number to pin. In the similar internal case, the recommendation was to move the host1x_syncpt IRQs shown in /proc/interrupts onto an isolated CPU core, and the example listed multiple host1x_syncpt IRQ lines (101-108), with only some carrying traffic.
For your case, because the failing syncpt ID is random:
  • Best first experiment: pin all 8 host1x_syncpt IRQs to the same isolated core.
  • If you want a narrower experiment, pin only the host1x_syncpt IRQ entries in /proc/interrupts that show non-zero/increasing counts while Argus is running.
  • Don’t try to map “syncpt 210 failed” to “IRQ X”; that is usually the wrong level of mapping.
What to check on your board
Run:
grep host1x_syncpt /proc/interrupts
Then pin those IRQ numbers’ affinity to one isolated CPU. If you have 8 entries for host1x_syncpt, the simplest clean test is to move all 8 together.
So the short answer is: not “too much work for VIC” by itself; more likely too much concurrency for the current interrupt/scheduling margin. Pin all active host1x_syncpt IRQs, and if you want the least ambiguous test, pin all 8.
We would suggest use Jetpac 6.2.2 r36.5 since it includes PSIRT fix:
The commits are included to r36.5:
Making sure you're not a bot!
Jetson AGX Orin FAQ
If you cannot upgrade, please manually apply the patches and check if it helps the use-case.
@ShaneCCC I isolated cpu4 and pinned the host1x_syncpt IRQs to it.
I also maxed all the clocks and turned off all non-camera apps, so there is not much else running on the system.
Still seeing the misses
root@m020-9999:~# mpstat -P ALL 2
Linux 5.15.148-tegra (m020-9999)        07/02/26        _aarch64_       (12 CPU)
16:23:34     CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest  %gnice   %idle
16:23:36     all    5.43    0.04    8.99    0.00    0.50    0.25    0.00    0.00    0.00   84.78
16:23:36       0    0.50    0.00    1.50    0.00    1.00    0.50    0.00    0.00    0.00   96.50
16:23:36       1    0.50    0.00    1.00    0.00    0.00    0.50    0.00    0.00    0.00   98.01
16:23:36       2    0.00    0.00    0.50    0.00    0.50    0.00    0.00    0.00    0.00   98.99
16:23:36       3   24.23    0.00   30.93    0.00    0.00    0.52    0.00    0.00    0.00   44.33
16:23:36       4    0.00    0.00    1.51    0.00    2.01    0.00    0.00    0.00    0.00   96.48
16:23:36       5    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00  100.00
16:23:36       6    0.00    0.00   15.53    0.00    0.00    0.00    0.00    0.00    0.00   84.47
16:23:36       7    0.99    0.00    7.88    0.00    0.49    0.00    0.00    0.00    0.00   90.64
16:23:36       8    9.18    0.51   10.71    0.00    0.51    0.51    0.00    0.00    0.00   78.57
16:23:36       9   10.00    0.00   13.50    0.00    0.50    0.50    0.00    0.00    0.00   75.50
16:23:36      10   10.50    0.00   14.00    0.00    0.50    0.00    0.00    0.00    0.00   75.00
16:23:36      11   10.20    0.00   11.22    0.00    0.51    0.51    0.00    0.00    0.00   77.55
16:23:36     CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest  %gnice   %idle
16:23:38     all    5.36    0.00    8.88    0.00    0.46    0.17    0.00    0.00    0.00   85.13
16:23:38       0    0.00    0.00    0.50    0.00    1.01    1.01    0.00    0.00    0.00   97.49
16:23:38       1    0.00    0.00    1.01    0.00    0.00    0.00    0.00    0.00    0.00   98.99
16:23:38       2    0.00    0.00    0.50    0.00    0.00    0.00    0.00    0.00    0.00   99.50
16:23:38       3   24.37    0.00   30.46    0.00    0.51    0.00    0.00    0.00    0.00   44.67
16:23:38       4    0.00    0.00    1.51    0.00    2.01    0.00    0.00    0.00    0.00   96.48
16:23:38       5    0.50    0.00    1.00    0.00    0.50    0.00    0.00    0.00    0.00   98.01
16:23:38       6    0.51    0.00   16.75    0.00    0.00    0.00    0.00    0.00    0.00   82.74
16:23:38       7    0.00    0.00    2.01    0.00    0.00    0.00    0.00    0.00    0.00   97.99
16:23:38       8   10.50    0.00   11.50    0.00    0.50    0.50    0.00    0.00    0.00   77.00
16:23:38       9    9.23    0.00   12.82    0.00    0.00    0.00    0.00    0.00    0.00   77.95
16:23:38      10    9.45    0.00   14.43    0.00    0.50    0.50    0.00    0.00    0.00   75.12
16:23:38      11    9.85    0.00   14.29    0.00    0.49    0.00    0.00    0.00    0.00   75.37
16:23:38     CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest  %gnice   %idle
16:23:40     all    5.25    0.00    8.60    0.04    0.38    0.21    0.00    0.00    0.00   85.52
16:23:40       0    0.00    0.00    0.50    0.00    1.01    0.50    0.00    0.00    0.00   97.99
16:23:40       1    0.00    0.00    1.00    0.50    0.00    0.00    0.00    0.00    0.00   98.51
16:23:40       2    0.00    0.00    0.50    0.00    0.00    0.00    0.00    0.00    0.00   99.50
16:23:40       3   21.18    0.00   34.48    0.00    0.49    0.49    0.00    0.00    0.00   43.35
16:23:40       4    0.00    0.00    2.00    0.00    1.50    0.00    0.00    0.00    0.00   96.50
16:23:40       5    1.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00   99.00
16:23:40       6    0.00    0.00    9.60    0.00    0.51    0.00    0.00    0.00    0.00   89.90
16:23:40       7    0.00    0.00    7.69    0.00    0.00    0.00    0.00    0.00    0.00   92.31
16:23:40       8   11.17    0.00   10.66    0.00    0.51    0.00    0.00    0.00    0.00   77.66
16:23:40       9    9.64    0.00   12.18    0.00    0.51    0.51    0.00    0.00    0.00   77.16
16:23:40      10    9.60    0.00   12.63    0.00    0.00    0.51    0.00    0.00    0.00   77.27
16:23:40      11   10.20    0.00   11.73    0.00    0.00    0.51    0.00    0.00    0.00   77.55
root@m020-9999:~# ps -eo pid,psr,comm | awk '$2 == 4'
33   4 cpuhp/4
34   4 migration/4
35   4 ksoftirqd/4
37   4 kworker/4:0H-kblockd
81   4 kworker/4:1-events
558   4 sugov:4
1195   4 kworker/4:1H-kblockd
17195   4 kworker/4:2-events
19046   4 kworker/4:0-events
root@m020-9999:~#
root@m020-9999:~# cat /proc/interrupts | awk 'NR==1 || /19[1-8]:/'
           CPU0       CPU1       CPU2       CPU3       CPU4       CPU5       CPU6       CPU7       CPU8       CPU9       CPU10      CPU11
191:          0          0          0          0          0          0          0          0          0          0          0          0     GICv3 480 Level     host1x_syncpt
192:          0          0          0          0     629247          0          0          0          0          0          0          0     GICv3 481 Level     host1x_syncpt
193:          0          0          0          0     580400          0          0          0          0          0          0          0     GICv3 482 Level     host1x_syncpt
194:          0          0          0          0    1513661          0          0          0          0          0          0          0     GICv3 483 Level     host1x_syncpt
195:          0          0          0          0     883766          0          0          0          0          0          0          0     GICv3 484 Level     host1x_syncpt
196:          0          0          0          0    2654937          0          0          0          0          0          0          0     GICv3 485 Level     host1x_syncpt
197:          0          0          0          0    5141312          0          0          0          0          0          0          0     GICv3 486 Level     host1x_syncpt
root@m020-9999:~#
@DaneLLL
Which one is the PSIRT ?
We have already applied some of these kernel patches.
The PSIRT are the two:
https://nvidia.custhelp.com/app/answers/detail/a_id/5716
Please apply all the patches.
And there are other fixes in Jetpack 6.2.2 r36.5:
Would be great if you can upgrade.
It would be a lot of work to upgrade, and I don’t see any evidence that these or related issues were addressed. PSIRT is concerned primarily with system security.
However if there are fixes, I am willing to try patches, or ideas to eliminate this problem.
Currently unable to upgrade due to:
Would suggest try this:
VIC failure - tegra-mc: VPR violation - #6 by DaneLLL
I upgraded one system to Jetpack 6.2.2.
The syncpt_load failures did not go away. They appear in similar frequency as before. The frequency appears to be correlated to the number of camera apps running in parallel.
root@m020-9999:~# cat /etc/nv_tegra_release
# R36 (release), REVISION: 5.0, GCID: 43688277, BOARD: generic, EABI: aarch64, DATE: Fri Jan 16 03:50:45 UTC 2026
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
root@m020-9999:~# uname -a
Linux m020-9999 5.15.185-tegra #1 SMP PREEMPT Fri Jul 10 11:09:46 PDT 2026 aarch64 aarch64 aarch64 GNU/Linux
root@m020-9999:~# dmesg -T | tail
[Wed Jul 15 09:17:58 2026] tegra-host1x 13e00000.host1x: syncpt_load failed: id=180, min=3822620, max=3822618
root@m020-9999:~#
Please apply the prebuilt lib and patch to r36.5 and give it a try:
VIC performance drop when drm load
[DRIVER] rcu_preempt detected stalls on CPUs/tasks with r36.5
The two fixes are related to host1x. Please apply them and try.
Applied both fixes. It did not eliminate or reduce the syncpt_load failed.
Thanks for the detailed troubleshooting so far. The syncpt_load failed errors on your Jetson AGX Orin with 6 cameras suggest a synchronization point issue in the VI (Video Input) pipeline, likely related to the high camera load.
To help narrow down the root cause, we need a bit more diagnostic information:
  1. Camera failure confirmation: Are you observing actual camera failures (dropped frames, timeouts, disconnects) when the syncpt_load errors occur, or are the errors appearing in the kernel log without visible impact to your application?
  2. Full kernel log context: Can you share the full dmesg output or kernel log around the time the syncpt_load errors occur? This will help us see if there are related VI driver messages, memory errors, or other tegra-host1x events.
  3. Correlation with camera operations: Do the syncpt_load failures happen at specific times—for example, when you start camera capture, switch resolutions, or access a particular camera index? Or do they appear randomly regardless of camera activity?
  4. Jetpack 6.2.2 behavior: You mentioned upgrading one system to Jetpack 6.2.2 in post #20. Did the frequency or pattern of syncpt_load errors change at all after the upgrade, or did they remain identical?
Once we have these details, we can determine whether this is a driver issue, a resource contention problem, or a configuration that needs adjustment for your multi-camera setup.
Does reference APP like argus_camera able to reproduce it?
