We found that some error messages like “tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN” reported on Orin booting.
What is the cause of this error, and will it have any impact on usage?
In source code “kernel/kernel-jammy-src/include/linux/mailbox_controller.h”, it says:
* The length of circular buffer for queuing messages from a client.
* 'msg_count' tracks the number of buffered messages while 'msg_free'
* is the index where the next message would be buffered.
* We shouldn't need it too big because every transfer is interrupt
* triggered and if we have lots of data to transfer, the interrupt
* latencies are going to be the bottleneck, not the buffer length.
* Besides, mbox_send_message could be called from atomic context and
* the client could also queue another message from the notifier 'tx_done'
* of the last transfer done.
* REVISIT: If too many platforms see the "Try increasing MBOX_TX_QUEUE_LEN"
* print, it needs to be taken from config option or somesuch.
#define MBOX_TX_QUEUE_LEN 20
Do you think it’s necessary to change MBOX_TX_QUEUE_LEN value?
Are you using devkit or with custom carrier board?
Which JetPack SW?
Does this cause anything go wrong there?
We are using our own carrier board, and the JetPack version is 6.0GA.
Nothing seems wrong so far, but we are concerned about potential risks.
