~/tegra_multimedia_api/argus/apps/camera/renderer/Composer.h::Composer class
Hi Folks,
I intend to use Composer class in my pipeline. In one of nvidia example application - argus_camera (i.e. ~~/tegra_multimedia_api/argus/apps/camera/ui/camera/Main.cpp) this class is used for camera preview. I would like to use this class to put up my ‘processed images/video’ on screen.
Would appreciate any guidance for this .
The code is at
tegra_multimedia_api\argus\apps\camera\renderer\Composer.cpp
tegra_multimedia_api\argus\apps\camera\renderer\StreamConsumer.cpp
In initializing, it initializes vertex and fragment shader and binds to eglstream/texture.
Everytime it gets an frame, it executes
glBindTexture();
glDrawArrays();
And do swap buffers.
It is same as preview consumer at
tegra_multimedia_api\argus\samples\utils\PreviewConsumer.cpp
Hi DaneLLL
Thanks for your help.
In the examples you have provided - cameras are directly feeding frames for preview/composer. In my situation I am looking to put up ‘post processed’ video frames on composer/screen. I am looking for way to do that. To me the situation in two aforesaid examples is not same as my requirement.
THanks
We have several samples for processing frames. FYR.
gl APIs
tegra_multimedia_api\argus\samples\openglBox
CUeglFrame
tegra_multimedia_api\argus\samples\cudaHistogram
NvBuffer
tegra_multimedia_api\samples
tegra_multimedia_api\samples\09_camera_jpeg_capture
