Thank you for the input, that demo works flawless in my configuration too.
I have Ubuntu 14.04 as NVIDIA guidelines, I am using JetPack 3.1, release 28.1 of Linux, and VisionWorks 1.6. I have the Jetson TX1 development kit, and I am using Tegra System Profiler 3.8. All was flashed with standard configuration, no kernel modifications were made.
Guided by this tip, I reduced the code to the minimal possible configuration to find the issue. It’s not so long, I’ll post it here with the compiler line to compile it.
If you run this in the profiler, most of the time (even if not always) it will produce an error, in my case the error is the one that I’ll post here.
Basically, it just create a pyramid with 2 levels, and it will run a FAST detector on the 2nd level. The problem seems to be linked with image size (in this case, 1226x370). With a more common size (640x480, for example) the problems is reduced, albeit sometimes the profiler crash even with this common size.
So, can you try with some run of the profiler if I am not the only one with this problem? If I missed some important information let me know.
Thank you in advance
Error of the profiler
Events fetch failed: Source id=
Type=ErrorInformation (18)
Error information:
ProcessEventsError (4005)
Properties:
ErrorText (100)=/home/devtools/teamCityBuildAgent/work/20a3cfcd1c25021d/QuadD/Host/Analysis/Modules/EventCollection.cpp(1021): Throw in function void QuadDAnalysis::EventCollection::CheckOrder(QuadDAnalysis::EventCollectionHelper::EventContainer&, const QuadDAnalysis::ConstEvent&) const
Dynamic exception type: N5boost16exception_detail10clone_implIN11QuadDCommon24InvalidArgumentExceptionEEE
std::exception::what: InvalidArgumentException
[PN11QuadDCommon14tag_error_textE] = Wrong event order has been detected when adding events to the collection:
new event ={ StartNs=1528182448 StopNs=1528183750 GlobalId=281624193269760 Event={ CudaEvent=[{ CorrelationId=236 DeviceId=0 ContextId=1 StreamId=15 EventClass=2 EventCategory=0 Event={ Memset={ SizeBytes=4 Value=0 } } },] } Type=80 }
last event ={ StartNs=1528280520 StopNs=1528340416 GlobalId=281624193269760 Event={ CudaEvent=[{ CorrelationId=224 DeviceId=0 ContextId=1 StreamId=15 EventClass=2 EventCategory=0 Event={ Memset={ SizeBytes=1297448 Value=0 } } },] } Type=80 }
To compile the following file, use this line (in a standard Jetson TX1 configuration)
g++ -std=c++11 main.cpp -I /usr/share/visionworks/sources/nvxio/include/ -lvisionworks `pkg-config --cflags --libs opencv` -o main.x
File main.cpp
* Minimal example of VisionWorks problem with Tegra System Profiler.
#include <cstdio>
#include <cstdlib>
#include <iostream>
#include <exception>
#include <NVX/nvx.h>
#include <NVX/Utility.hpp>
#include <OVX/UtilityOVX.hpp>
using namespace std;
int main(int argc, char **argv)
int width; int height;
if(argc < 3)
width = 1226;
height = 370;
else
try
width = std::stoi(argv[1]);
height = std::stoi(argv[2]);
catch(std::exception& e)
std::cout << "Launch: " << argv[0] << " width height" << std::endl;
exit(1);
// context
vx_context context;
// graph
vx_graph global_graph;
// images
vx_image image_start;
vx_image image_level_one;
// scalars
vx_scalar s_strength_threshold;
vx_scalar corners;
// array
vx_array keypoints;
// pyramid
vx_pyramid gaussian_pyramid;
context = vxCreateContext();
NVXIO_CHECK_REFERENCE( context );
vxDirective((vx_reference)context, NVX_DIRECTIVE_ENABLE_PERFORMANCE);
vx_pixel_value_t p;
p.U8 = 0;
image_start = vxCreateUniformImage(context, width, height, VX_DF_IMAGE_U8, &p);
NVXIO_CHECK_REFERENCE(image_start);
global_graph = vxCreateGraph(context);
NVXIO_CHECK_REFERENCE( global_graph );
float fast_t = 10;
s_strength_threshold = vxCreateScalar(context, VX_TYPE_FLOAT32, &fast_t);
NVXIO_CHECK_REFERENCE( s_strength_threshold );
// allocate some space to store the keypoints
keypoints = vxCreateVirtualArray(global_graph, VX_TYPE_KEYPOINT, 400);
NVXIO_CHECK_REFERENCE( keypoints );
vx_size sz_corners = 0;
corners = vxCreateScalar(context, VX_TYPE_SIZE, &sz_corners);
NVXIO_CHECK_REFERENCE( corners );
// build the pyramid
gaussian_pyramid = vxCreateVirtualPyramid(global_graph, 2, VX_SCALE_PYRAMID_ORB, width, height, VX_DF_IMAGE_U8);
NVXIO_CHECK_REFERENCE( gaussian_pyramid );
vxGaussianPyramidNode(global_graph, image_start, gaussian_pyramid);
// get reference to the second level
image_level_one = vxGetPyramidLevel(gaussian_pyramid, 1);
NVXIO_CHECK_REFERENCE( image_level_one );
// do the FAST corners detection
vxFastCornersNode(global_graph, image_level_one, s_strength_threshold, vx_true_e, keypoints, corners);
NVXIO_SAFE_CALL( vxVerifyGraph(global_graph) );
// process 2 times the graph to arise the issue!
for(int i = 0; i < 2; i++)
vxProcessGraph(global_graph);
vxReleaseImage(&image_level_one);
vxReleaseImage(&image_start);
vxReleaseScalar(&corners);
vxReleaseScalar(&s_strength_threshold);
vxReleasePyramid(&gaussian_pyramid);
vxReleaseArray(&keypoints);
vxReleaseGraph(&global_graph);
vxReleaseContext(&context);
return 0;
