Hi NVIDIA team,
We are seeing a SuperSpeed USB device on our Jetson Orin NX reconnect
continuously without any userspace action or physical-layer event. Over
~35 minutes the kernel allocated 347 new device numbers on the same
physical port, accompanied by 24 tegra-xusb warnings. We’ve
narrowed the trigger down to within the host-side kernel stack: the
peripheral device itself and the Type-C physical layer show no events
during the reconnects. We’d like guidance on whether this signature is
known and what the recommended mitigation is.
Environment
| Platform : NVIDIA Jetson Orin NX Engineering Reference Developer Kit |
| L4T Release : R36.5.0 (JetPack 6.2) |
| BSP Build : nvidia-l4t-core 36.5.0-20260115194252 / GCID 43688277 |
| Kernel : 5.15.185-tegra |
| USB host controller : tegra-xusb 3610000.usb |
| Peripheral : Custom USB 3.0 bulk gadget, VID:PID 1d6b:0104, connected on bus 2, port 2 via Type-C |
$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
|__ Port 2: Dev 49, If 0, Class=Vendor Specific Class, Driver=, 5000M
Symptom
On usb 2-2, the device is disconnected and re-enumerated repeatedly,
sometimes multiple times per second. Each iteration consumes a new
device number:
[Wed Apr 22 19:33:33 2026] usb 2-2: USB disconnect, device number 28
[Wed Apr 22 19:33:33 2026] tegra-xusb 3610000.usb: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[Wed Apr 22 19:33:34 2026] usb 2-2: new SuperSpeed USB device number 29 using tegra-xusb
[Wed Apr 22 19:33:41 2026] usb 2-2: USB disconnect, device number 29
[Wed Apr 22 19:33:41 2026] usb 2-2: new SuperSpeed USB device number 30 using tegra-xusb
[Wed Apr 22 19:33:42 2026] usb 2-2: USB disconnect, device number 30
[Wed Apr 22 19:33:43 2026] usb 2-2: new SuperSpeed USB device number 31 using tegra-xusb
[Wed Apr 22 19:33:44 2026] usb 2-2: USB disconnect, device number 31
[Wed Apr 22 19:33:44 2026] tegra-xusb 3610000.usb: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[Wed Apr 22 19:33:44 2026] usb 2-2: new SuperSpeed USB device number 32 using tegra-xusb
Two warning signatures observed:
tegra-xusb 3610000.usb: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.(22 occurrences) -
tegra-xusb 3610000.usb: WARN Event TRB for slot 3 ep 1 with no TDs queued?(2 occurrences)
Over a 35-minute window:
usb 2-2disconnect/reconnect events: 347 -
tegra-xusb WARNlines: 24 -
Device numbers allocated: 2 → 49+ (no cleanup)
Why the trigger appears to be on the host side, not the peripheral or cabling
We did a two-sided investigation. The observations below rule out the
peripheral and the Type-C physical layer, which leaves the host-side
kernel stack as the most likely origin.
1. Type-C CC controller (fusb301) is silent
On both the Jetson side and the peripheral side, the fusb301 Type-C
controller only logs the initial attach sequence at boot — no detach
or re-attach events during the reconnect storm.
Jetson side fusb301 events — only at boot, then silent:
[Wed Apr 22 19:08:59 2026] fusb301 1-0025: fusb301_detach: type[0x00] chipstate[0x01]
[Wed Apr 22 19:08:59 2026] fusb301 1-0025: fusb_update_state: 1
[Wed Apr 22 19:09:00 2026] fusb301 1-0025: fusb_update_state: a
[Wed Apr 22 19:09:00 2026] fusb301 1-0025: fusb_update_state: b
[Wed Apr 22 19:09:00 2026] fusb301 1-0025: fusb_update_state: 7 <-- last event; stable from here
⇒ The physical Type-C CC layer is stable. The reconnects are not
caused by cable/connector issues.
2. Peripheral gadget was never torn down
On the peripheral side (a separate Linux SoC running FunctionFS):
/sys/kernel/config/usb_gadget/*/UDCmtime has not changed since
boot — userspace never unbound the gadget.
The peripheral’s EP0 never observed a
DISABLEevent. -
FunctionFS URBs remained
in_flight=8throughout the storm — no
ESHUTDOWN was propagated to the gadget.
- The peripheral’s current_speed reported
super-speedconsistently.
⇒ From the peripheral’s point of view, VBUS was continuous and the
pullup was continuous. The disconnects are not caused by the peripheral
dropping off.
3. No userspace action on the host
Our Rust USB daemon on the Jetson only calls claim_interface() after
opening the device, then uses bulk endpoints. It does not issue
set_configuration, set_interface, reset_device, or clear_halt
in the normal path. The disconnect is initiated entirely by
tegra-xusb in kernel space, not by any userspace syscall.
4. Throughput behavior and self-healing (observations)
Expected throughput on this setup would be on the order of ~90 MB/s
for bulk transfer. In practice we have never reached that figure —
typical observed throughput is a few hundred KB/s, occasionally
bursting to ~20 MB/s, and the reconnect storm keeps happening at any
load level, not only during idle periods. So we cannot attribute the
storm to link idleness.
We have also observed long (30+ minute) self-healing intervals where
the storm spontaneously stops without any intervention, then resumes
later. We have not yet found a reliable external trigger that
correlates with entering or leaving these stable periods.
Attempted mitigations
We tried the usual userspace knobs with no effect:
/sys/bus/usb/devices/2-2/power/controlset toon— no change. -
/sys/bus/usb/devices/2-2/power/autosuspend_delay_ms=2000
(default) — not a factor.
Questions
- Known issue? Is `WARN Set TR Deq Ptr cmd failed due to incorrect
slot or ep stateontegra-xusb 3610000.usb` a known issue on
JetPack 6.2 / L4T R36.5 for Orin NX? Any existing bug ID or fix in
a newer BSP?
- Root cause direction. Given that the peripheral and CC layer
are quiescent while the host kernel keeps reporting
incorrect slot or ep state on ep 1 of slot 3, what is the most
likely internal state-machine path to investigate first? E.g. Set
TR Dequeue Pointer command timing vs. endpoint state transitions,
LPM U1/U2 handling, or something else specific to Orin NX?
- Tuning knobs to try now. Are there Orin NX /
tegra-xusb
specific knobs we can change without a kernel rebuild —
kernel cmdline parameters in
/boot/extlinux/extlinux.conf, -
device-tree property overrides,
or
xhci_hcd/tegra-xusbmodule parameters —
that you would recommend we test first to narrow this down?
Related (but distinct) prior observation
On the same platform and kernel, in April 2026 we previously saw a
different failure signature with a different ERROR-level message:
xhci-tegra 3610000.xhci: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 6 comp_code 4
xhci-tegra 3610000.xhci: Looking for event-dma ... trb-start ... trb-end ...
(trb-end monotonically increasing, never catching up to event-dma)
That mode bricked the UDC state machine on the peripheral side
(functionfs returning EAGAIN, only a full reboot recovered). The
current issue is clearly different — a WARN Set TR Deq Ptr message
rather than a TRB-DMA-mismatch ERROR, and the peripheral stays fully
operational (URBs stay in-flight, functionfs never returns EAGAIN,
a daemon restart — not a reboot — is enough to clear it).
We mention it because both failure modes appeared while the peripheral
was actively streaming bulk data up to the Jetson (device → host),
which is the primary traffic pattern of our recording workload. So the
two may share a common origin in the Orin NX xhci endpoint/slot
state-machine handling of that direction.
Reproducibility and follow-up
We can reproduce this on demand with the same kernel/BSP/peripheral.
Happy to provide any of the following if helpful:
Longer dmesg (boot → 1+ hour runtime)
ftracecapture ofxhci_hcd:*events during a reconnect burst -
Test with a different SuperSpeed peripheral (e.g., an off-the-shelf
USB3 flash drive) to see whether the warning signature is
peripheral-specific
- Test on USB2 speed only (gadget advertising only FS/HS descriptors)
Attachment: jetson_dmesg_runtime_only.txt — trimmed dmesg containing
platform info, xhci boot probe, and the full runtime event stream
(347 usb 2-2 events + 24 tegra-xusb WARN lines over 35 minutes).
Thanks in advance for any pointers.
