Hi nvidia
we encountereda critical error on customer site on Jetson Xavier NX, L4T 35.3.0, and we found some same cases
Camera RTCPU gone bad after 49.7 days - fix available?
49-7-day-bug-camera-rtcpu-gone-bad
My question is it possible to solved the issue by resetting the CAMER RTCPU separately or there may be patches that can fix it ?
logs.txt (6.2 KB)
hello cosmic_edge,
it’s known issue, please refer to Topic 382191 for the test rce-fw update, it should address this specific 24/7 camera-stream failure after ~49.7 days for JP-5.1.7/r35.6.5 on Xavier.
Thank you for your prompt response, Is the test rce fw update suitable for R35.3? Is there a release version available?
hello cosmic_edge,
unfortunately, you cannot apply this rce-fw to r35.3 directly since there’re several changes checked-in.
please consider moving forward to JP-5.1.7 for verification.
