Getting Error in TPG using deserializer DS90UB954
I have made changes in the ov5693 sensor driver changing the i2c address, clock and registers to generate pattern but the i2c write failed so for now I have removed the reg_write part in the driver and using i2cset to write i2c the deserializer is sending mipi data I have confirmed it using an oscilloscope.
I need help n figuring out why i can’t capture and show the pattern generation output.
I have added the Kernel log and the user_space code which i am using, for reference.
user_space_code: GitHub - fastr/yavta: fork of git://git.ideasonboard.org/yavta.git
kernel_log: kern.log (16.6 KB)
Can anyone help me to fix this issue?
Hi @ShaneCCC ,
I got the following Results:
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
998400000
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
1190400000
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
400000000
