I develope a camera that its resolution can be 1280x1080,2560x1080,3840x1080 and 5120x1080(pixel format is yuv422 8 bit,isp bypass mode).It can successfully capture when resolution less than 5120x1080.
When I try 5120x1080,the tegra-vi error occurred.Follow is the log
[ 222.342336] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 32, err_data 160
[ 222.422409] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 222.582449] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 222.902535] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 223.382806] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 223.542829] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 223.782942] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 223.862933] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 223.942993] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
[ 224.023079] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 224.263175] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 166, err_data 160
[ 224.343208] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 224.503265] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 160
It seems tegra-vi cannot support so big resolution.
Is there a solution to solve this problem? Thank you a lot!
