Tegra2 GMI SNOR trouble
I want to use the GMI interface multiplexed 16-bits asynchronous mode.
I have difficulty with sequences of read / write on the bus.
The problem is that sometimes the GMI_OE_N signal appears before GMI_ADV_N signal, which is not normal.
Can you help me?
thank you
there is a erratas document for tegra2 cpu?
