I’m using the Yocto layer to build my image for Jetson Nano and if the tegra_wdt_t210x module is loaded I’m getting a board reset. This appears to be due to the watchdog not being notified.
I’ve set the wd timeout in systemd to 120 seconds, I see Tegra module acks this, however I still get the board reset in about 20 seconds. This doesn’t happen with the Ubuntu sd-card image, so I’m guessing it could be due to a difference of how systemd pings /dev/watchdog? Or maybe there is a separate app that pings the watchdog in the ubuntu image?
Could you please tell me more about what could be the root cause? Thank you
[ 11.397267] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 11.418422] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 0)
36.330274] Watchdog detected hard LOCKUP on cpu 0[ 36.334940] ------------[ cut here ]------------
[ 36.339595] WARNING: CPU: 3 PID: 0 at /usr/src/kernel/kernel/watchdog_hld.c:143 watchdog_check_hardlockup_other_cpu+0x108/0x128
[ 36.351118] Modules linked in: ip6_tables ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink br_netfilter xt_owner nvgpu nvs tegra_wdt_t21x
[ 36.365387]
[ 36.366885] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.9.140-l4t-r32.1+g0e2f66e #1
[ 36.374573] Hardware name: jetson-nano (DT)
[ 36.378773] task: ffffffc0fa7bc600 task.stack: ffffffc0fa7d0000
[ 36.384718] PC is at watchdog_check_hardlockup_other_cpu+0x108/0x128
[ 36.391098] LR is at watchdog_check_hardlockup_other_cpu+0x108/0x128
[ 36.397476] pc : [<ffffff800817c878>] lr : [<ffffff800817c878>] pstate: 604001c5
[ 36.404900] sp : ffffffc0ff019d00
[ 36.408225] x29: ffffffc0ff019d00 x28: ffffffc0fa7bc600
[ 36.413581] x27: 0000000000000000 x26: 0000000000000000
[ 36.418936] x25: ffffff800a218000 x24: ffffff800a218fa8
[ 36.424289] x23: ffffff800a51f268 x22: ffffffc0ff01d6f8
[ 36.429640] x21: 0000000000000000 x20: ffffff800a219c30
[ 36.434993] x19: ffffff8009bed760 x18: ffffffffffffffff
[ 36.440347] x17: 000000000000569f x16: 0000000000000000
[ 36.445700] x15: ffffff800a217e10 x14: ffffffc17f0196c7
[ 36.451053] x13: ffffffc0ff0196ca x12: ffffffc0f95e4b60
[ 36.456406] x11: ffffff8008fe15d8 x10: 00000000ffffffff
[ 36.461760] x9 : 00000000000002f6 x8 : 206e6f2050554b43
[ 36.467113] x7 : 4f4c206472616820 x6 : ffffffc0ff019700
[ 36.472466] x5 : 0000000000000012 x4 : 0000000000000000
[ 36.477818] x3 : 0000000000000000 x2 : 000000000004098c
[ 36.483172] x1 : 0000000000000000 x0 : 0000000000000026
[ 36.488525]
[ 36.490021] ---[ end trace 5c17e2a8d4f30cf2 ]---
[ 36.494658] Call trace:
[ 36.497116] [<ffffff800817c878>] watchdog_check_hardlockup_other_cpu+0x108/0x128
[ 36.504542] [<ffffff800817b9ec>] watchdog_timer_fn+0x9c/0x280
[ 36.510314] [<ffffff800813e764>] __hrtimer_run_queues+0xe4/0x378
