Hi
we find Linux_for_Tegra package include flash_win.bat file.
when we try to use it in windows, we find there is no tegraparser_v2.exe file.
Does Jetson orin support download img in windows system???
the log below
D:\work\orin\bootloader\bootloader>python .\tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g --overlay_dtb L4TConfiguration.dtbo,tegra234-p3737-overlay-pcie.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-a03-overlay.dtbo,tegra234-p3737-a04-overlay.dtbo,L4TRootfsInfo.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo --bldtb tegra234-p3701-0000-p3737-0000.dtb --applet mb1_t234_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0000.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --scr_config tegra234-mb2-bct-scr-p3701-0000.dts --wb0sdram_config tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --dev_params tegra234-br-bct-p3701-0000.dts,tegra234-br-bct_b-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0000.dts --bins “psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3701-0000-3737-0000.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks.img” --sdram_config tegra234-p3701-0000-p3737-0000-TE990M-sdram.dts --secondary_gpt_backup --bct_backup --boot_chain A
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 1.5238 ] tegrasign_v3.py --key None --getmode mode.txt
[ 1.5238 ] Assuming zero filled SBK key
[ 1.5238 ] Parsing partition layout
[ 1.5268 ] tegraparser_v2.exe --pt flash.xml.tmp
[ 1.5358 ] ‘tegraparser_v2.exe’ �������������������������ǿ����еij���
[ 1.5358 ] »òÅú´¦ÀíÎļþ¡£
[ 1.5358 ]
Error: Return value 1
Command tegraparser_v2.exe --pt flash.xml.tmp
