For nano evb, with l4t 3644,
I’m following https://forums.developer.nvidia.com/t/failing-with-custom-keys-for-encrypting-nvme-on-jetson-orin-nano/270934/13 for some issue about secure boot .
one of the steps there is " l4t_initrd_flash…", there are tow probleam:
1)during the process, the board (nano) got reset and exit from recovery mode, what lead to failures. i can handle this by reset manuall the board (unplug power) while the “force recovery” shorted to ground.
2) at the end of l4t_init_flash, it call tegrarcm_v2, for download images. but there also, after the first image it download, the board got reset, exit from recovery, and the operation failed ,according to the logs, it tried it manually :
"sudo ./tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
it got reset after bct_br download, and cant continue to the next images.
secureboot PKC and UEFI (by the error from the serial log, it have issue with the signed image)
3)I pretty sure it is not cable issue, when the nano in recovery mode its recognized fine, the problem is that during the tegrarcm_v2 itself, the board perform reboot and get out from the recovery, it can be seen in the log file of the serial output. if I reset the board (unpluged and pluged) with RECOVERY_PIN shorted to GRND, it goes back to recovery and recognized well
I attached the full log for the whole process NVIDIA_FULL_LOGS_FOR_FLASH_SECURED_FAILE_AT_TEGRARCM.txt (550.3 KB)
(as described at the topic above), The only workaround i foubd to prevent l4t_initrd_flash failure due to “rcm not found” is to reset the nano each time it performed a cold reboot and went out from recovery mode. this workaround can’t work for tegrarcm_v2 command, which reboot the board during the proceesss, so it can load only BCR and fail for the next image
Seems that my problem, Is to find a way to make the nano not to reboot after every time the tools talk to him
Could you try to flash w/o enabling Secureboot and UEFI secureboot clarify if the issue relates to them?
Not really, sometimes it can be recognized in force recovery state correctly before flash and would still hit USB timeout issue due to the unstable connection/signal.
Are you using standalone Ubuntu as host PC to flash the board?
Or you are using something like VM/docker/WSL2?
Several reboots during flash are expected so that I suggested for the stable USB connection.
