We are using the tegrastats command in our software to get all the needed information about the system (CPU usage, Temperatures, RAM, etc.). It was working when using only the /dev/i2c-8 bus. Now when I try to use the /dev/i2c-1 bus, the tegrastats command does not seem to work anymore, it runs but doesn’t give any output.
Do you know why ? My guess is that maybe this command uses i2c and there is a conflict there.
Thanks for help
