njal
May 11, 2018, 11:57am
1
Hi
I see that tegrastats changed a bit in the Jetpack 3.2 release.
Can anyone point me in the direction of some documentation that describes the different stats?
RAM 721/7854MB (lfb 1615x4MB) CPU [0%@960 ,off,off,0%@959 ,0%@960 ,0%@959 ] EMC_FREQ 1%@665 GR3D_FREQ 0%@140 APE 150 BCPU@33C MCPU@33C GPU@30C PLL@33C Tboard@28C Tdiode@29.5C PMIC@100C thermal@31.5C VDD_IN 2028/2028 VDD_CPU 153/153 VDD_GPU 153/153 VDD_SOC 382/382 VDD_WIFI 0/0 VDD_DDR 212/212
Hi njal, you can find the tegrastats documentation included under the L4T Documentation . After extracting the tarball and opening it in your web browser, expand the “Applications and Tools” entry in the navigation view on the left-hand side, and then select “TegraStats” utility from the drop-down.
njal
May 11, 2018, 7:51pm
3
Thanks @dusty_nv - here is the newest documentation as far as I can understand. It’s from March 2018.
There are still some parameters which aren’t explained in depth in the documentation - e.g.
BCPU
MCPU
PLL
Tboard
Tdiode
PMIC
thermal
VDD_IN (input voltage - 2028 means 20.28v?)
VDD_CPU (cpu voltage - 153 means 1.53v?)
VDD_GPU (gpu voltage - 153 means 1.53v?)
VDD_SOC (SystemOnChip voltage - 382 means 3.82v?)
VDD_WIFI (Wifi chip voltage - 0 means 0.00v?)
VDD_DDR (DDR Memory voltage - 212 means 2.12v?)
Furthermore, the documentation contains parameters that aren’t used by tegrastats anymore - e.g. NVDEC
It would be great if the documentation could be updated/improved and made accessible through man , –help or otherwise made easily available online.
Screenshot from the documentation:
NVENC (aka MSENC) and NVDEC are shown only when active.
You may activate these from another shell for example running:
gst-launch-1.0 -ev nvcamerasrc ! 'video/x-raw(memory:NVMM)' ! omxh264enc ! h264parse ! omxh264dec ! nvvidconv ! 'video/x-raw' ! xvimagesink
BCPU to thermal are temperatures in Celsius degrees. (PMIC showing 100°C is usual, albeit not true).
You may also check sysfs contents of /sys/class/thermal/ for details (you may check https://devtalk.nvidia.com/default/topic/1021313/jetson-tx1/use-c-language-get-cpu-thermal-sensor-temperature-tx1-/post/5198956/#5198956 and https://devtalk.nvidia.com/default/topic/1031414/?comment=5247276 ).
VDD_IN to VDD_DDR are voltages to different parts (I think indeed these are in centiVolts).
