I am using tegrastats to monitor the power consumption of the Jetson Nano by running the command:
tegrastats --interval 10 --logfile ./output_logFile.txt &
I indicated 10 ms in the command below, but is there a lower limit that tegrastats can accept for the interval value ? The main limitation will come from writing to the logFile, so if I indicate a value that is too small with respect to how fast the Jetson can append data to the file, will tegrastats use a default value (and what value would it be?), or it will just append data as fast as possible: the 10ms interval will thus not be respected and the time step between two values will roughly corresponds to the time needed to append new data to the file ?
Thanks for your help !
Yves-Marie Raiffaud
