Tegrastats on TX2
Hi
This is my output from TX2 Tegrastats:
RAM 1893/7854MB (lfb 12x4MB) CPU [0%@1113,0%@1346,0%@2036,0%@2061,0%@2035,0%@2036] EMC_FREQ 12%@1866 GR3D_FREQ 0%@1300 APE 150 MTS
RAM 1893/7854MB (lfb 12x4MB) CPU [0%@1113,0%@1346,0%@2036,0%@2061,0%@2035,0%@2036] EMC_FREQ 23%@1866 GR3D_FREQ 0%@1300 APE 150 MTS
RAM 1893/7854MB (lfb 12x4MB) CPU [0%@1113,0%@1346,0%@2036,0%@2061,0%@2035,0%@2036] EMC_FREQ 25%@1866 GR3D_FREQ 0%@1300 APE 150 MTS
I want to calculate memory bandwidth during run time with this info. Do you think using this formula is right?
(emc_freq%1866) MHz * (128/8) bytes bus width * (2) DDR4 multiplier
For example:
the first line output will be: (0.12*1866)MHz * (128/8)bytes * 2 = 716544 MB/s
If not, can you tell me where I am going wrong?
Cookie007,
The maximum bw for our DDR4 is 59.7 GB/s.
I’ll try to find out some tools for you.
Cookie007,
Sorry that I just noticed that those tools are for internal use only. I cannot release it to you.
Any special usecase that needs to check the bandwidth?
I want to stream 5 cameras on TX2 and save it to a file; but it seems to keep crashing. I wanted to check how much memory bandwidth my code utilizes for saving the file from stream and see if there is anything to optimize it.
Hi Cookie007,
Do you use USB cameras? How do you connect your cameras to TX2?
I use the Leopard Imaging MIPI cameras for TX2 :https://leopardimaging.com/product-category/nvidia-jetson-camera/nvidia_tx1tx2_camera_kit/
Hi Cookie007,
Your issue is not same as this thread. Please start a new thread.
