Hi:
How would I tell pCC which version of ld to use if I have multiple versions installed?
Bobby
Hi:
Bobby
Hi Bobby,
You can simply add “LDDIR=” on your link line or you can create a “~/.mypgcpprc” file and add “LDDIR=”. The linker’s name can be changed by setting “LD”.
Hope this helps,
Mat
Example:
pgCC hello.cpp LDDIR=/usr/local/binutils-2.18/bin LD=ld-2.18
% cat ~./mypgcpprc
LD=ld-2.18
thanks!i’ll try that out
