template functions inside structs nvcc drops __device__ declaration?
Hi all,
Here is a simple piece of code with templates that works fine :
#include "stdio.h"
template<int n>
struct mystruct{
 __device__ __host__
  void foo(int * res)
    *res = n;
__global__  void g_test(int * res)
  mystruct<1> ms;
  ms.foo(res);
extern "C"
void  test()
  int h_res;
  int * d_res = 0;
 cudaMalloc((void**)&d_res, sizeof(int));
  g_test<<<1, 1>>> (d_res);
  cudaMemcpy(&h_res, d_res, sizeof(int), cudaMemcpyDeviceToHost);
  cudaFree(d_res);
 printf("%d\n", h_res);
 return;
But if I modify the template a little to move the template from the struct to the function inside, the compilation is not possible anymore in Device mode (it still works in emulation mode) :
struct mystruct{
 template<int n>
  __device__ __host__
  void foo(int * res)
    *res = n;
  mystruct ms;
  ms.foo<1>(res);
The device declaration seems to have been droped somewhere, here is the error :
I know templates are not officially supported in cuda v1.0, but will this be possible in a future release?
